Author Topic: 76 CB750F normal blinker/signal operation  (Read 692 times)
Offline speedtribe
« on: June 25, 2011, 12:47:57 PM »
Sorry guys but my search and reading skills are just not cutting it today....
I replaced my front and rear turn signals and brake light (I know, I know....) and they all work fine...as long as I don't turn the ignition switch to "RUN" When I do that, the blinkers don't flash. Flashing blinkers won't do me much good if I can't use them with the bike on :)  I haven't tried it with the bike running since the gas tank is getting redone at the moment.
Is it normal to not flash if the ignition is set to "Run" and the bike is not running?
Offline Gearheadgreg
  • Jamestown Rhode Island
Re: 76 CB750F normal blinker/signal operation
« Reply #1 on: June 25, 2011, 02:45:48 PM »
well.......my 78F does the same thing, but once the engine is running they blink? yes my battery is new, i think my turn signal oil is low?   ;D
2001 Honda Supercharged Valkyrie   <iframe width="480" height="360" src="http://s1218.photobucket.com/user/meloafer/embed/slideshow/"></iframe> Just having some fun
Offline speedtribe
« Reply #2 on: June 25, 2011, 03:29:17 PM »
Awesome! Thanks for the info. Time to get the wiring all tucked back in place and get the tank done.
Offline TrueSpin
  • Not Really An
  • 1978 750F3
« Reply #3 on: June 25, 2011, 05:07:27 PM »
Chances are it's a matter of not having the right load on the flasher unit, assuming you still have the old thermal unit in there.
I replaced mine with a standard DOT-552 electronic unit, and no more flashing issues.
With the correct load it should flash down to like 11.5~ volts, regardless of whether the engine is running. If you have the wrong load in one end, it may flash too slowly or only above 13~ volts. Goofy stuff.
« Reply #4 on: June 25, 2011, 06:56:18 PM »
Truespin, that DOT-552, Is that something that can be purchased at the Auto parts store or at the Honda dealer? TIA.  ??? after 32 years just figured the gasket leaked all the oil out.
Offline TrueSpin
  • Not Really An
  • 1978 750F3
« Reply #5 on: June 25, 2011, 07:19:18 PM »
I scored mine at the local AutoZone for $6.99.
Edit: they keep them in the same aisle as the blinker fluid. ;)
« Reply #6 on: June 25, 2011, 07:27:02 PM »
Most Excellent!! it was blinking real good today at a stop, just had to hold the RPM up around 4000......kinda noisy everybody was staring at me!  :o  but seriously thanks for the info, one more thing off the list.  8)
