Hi Bert
Because these rods are 1.5mm (.060") longer, the two areas of the pistons that I expected would need some modifying are the piston edge and also the valve reliefs.
Initially, I assembled the top without a base or head gasket just to get a benchmark to work from.
For the head to sit flat onto the block, the pistons had to drop .040" into the bore.
To get the piston dome to fit into the combustion chamber, the edge of the pistons had to be cut in square for clearance. (See earlier pics)
I've just finished checking the valve to piston clearances and the valve reliefs will need to be opened up a bit more.
The exhaust valve is contacting the piston and the intake has about .050" clearance.
This was checked with a .020"base gasket, a .050" head gasket and zero lash.
Here are some photos.
Also one of the camshaft that I've been checking with which has a fairly aggressive grind.
Intake Side
Exhaust Side
Ivan Tighe Camshaft
Specs:
Lift - .370
Intake - 36/59 deg @ .040"
Exhaust - 66/36 deg @ .040"
