Author Topic: CB750K2 -Tsubaki Omega o-ring chain 102 links is too long :(  (Read 1297 times)
So this is strange...yesterday I changed the chain on my K2 since the old RK chain had a tight link at one section of the chain. I had bought a Tsubaki Omega o-ring chain  - 102 links. Written on the box very clearly.  When we went to put it on turns out it was too long and after adjustment its already at 3/4 of the way on the markers so hardly any room for adjustment! Counted the chain and sure enough its 102 links???
This is a stock K2 with stock swingarm, 48 rear and 17 front sprockets. Wheel is stock size. Chain that came off was a 102 and it was not this far adjusted when it had to be replaced. What gives?? I have used Tsubaki Sigma chains in the past with no issue. Very bizarre!
Any ideas?
thanks
Andy
« Last Edit: July 03, 2011, 02:33:37 PM by andy750 »
Offline Gordon
  • 750K1, 550K2
Re: CB750K2 -Tsubaki Omega o-ring chain 102 links too long!!??
« Reply #1 on: July 03, 2011, 06:59:56 AM »
AFAIK, stock chain length should be 100 links.
« Reply #2 on: July 03, 2011, 08:46:25 AM »
76 and down should be 100 links.
 Tsubali are pre-stretched I believe may make it look even longer.
 I think I put a 100 link on a 74 750, and it was all the way forward, and tight, I dont think it was prestretched. (When they are not on a cheap chain they usually need adjustment very quickly)
« Reply #3 on: July 03, 2011, 02:32:56 PM »
Clearly I am idiot! I have been ordering 102 or 104 link chains for years in the belief it was 102 links. I even searched the forum before ordering and found my old posts about chain length! I just checked my parts manual for a K5 and sure enough 100 links....
I stand humbled...thanks for the correction Gordon and 754!
cheers
Andy
Offline Nortstudio
  • Not nearly an
  • Just getting started...
    • MotoPreserve
Re: CB750K2 -Tsubaki Omega o-ring chain 102 links is too long :(
« Reply #4 on: July 03, 2011, 05:51:09 PM »
Andy, did you do a mod to get the o-ring type to work, or do 750s have no trouble with them?  I know the 550s have the issue of not being able to accept them.
I thought I had read somewhere about a mod though, just curious if you had any experience with this.
Scott
1976 CB550K...in progress
1975 CL360...eventually custom
2009 Husqvarna TE610
a blog about wrenching in Brooklyn, NY
“Success is dependent on effort.”
~Sophocles
« Reply #5 on: July 03, 2011, 06:14:04 PM »
Hey Scott
The 750 has no clearance issues with o-ring or x-ring chains...only the 550 has issues. Sorry!
Andy
« Reply #6 on: July 03, 2011, 06:46:27 PM »
Hay Andy, you think there is such a thing as too long?  ;D ;D ;D ;D ;D
