Author Topic: Scary! (Front sprocket came off - now fixed!)  (Read 6118 times)
Offline lucky
Re: Scary!
« Reply #25 on: August 24, 2011, 02:05:21 PM »
No chain guard, but I may put it back on now!!! :(
Wrong. With the chain guard on the chain gets bunched up inside the chain guard case sometimes and that can break the case. The 78's had a thicker case in that area.
With the chain guard off the chain can have a place to escape.
It all depends how close the chain guard is to the chain.
Four things you were very lucky about.
#1 The master link was right there for you.
#2 You did not ask your girl friend to help you push the bike up a hill.
#3 The bike did not go down as a result of the sprocket getting loose.
#4 It was night so not many people saw you broke down.
Offline Tugboat
  • Puppet
    • PseudoMoto
Re: Scary! (Front sprocket came off - now fixed!)
« Reply #26 on: August 24, 2011, 03:31:46 PM »
Fun fact: right after it happened, while I was sitting there on the side of the road contemplating what to do next, a woman pulled up to the light at that intesection, rolled down her window and asked: "What year is that?"
Old, I said, glaring. Then she pulled away.
Offline lucky
Re: Scary!
« Reply #27 on: August 27, 2011, 12:26:41 PM »
Hi gang.I have used clip links for 40 years and have never experienced a failure.The chains of today are so much better than years ago I doubt any machine would do one in!My DID gold chain requires the side plate to be pressed on before the clip is installed and I believe this is more than adequate.It pisses me off that a clip link is no longer available for this chain that I can find.
You do NOT have to buy a "O" ring chain!!!
Just buy a regular #530 chain But NOT O ring type.
Offline City Boy
« Reply #28 on: August 28, 2011, 04:53:48 AM »
Well that's fine Lucky but how does that help me with the chain that I do have that I am quite happy with and will likely outlast me?
'52 Kiekhaefer Mercury Rocket Hurricane KG4H
'70 750/RC 1000 Original Owner
'83 1100F
Offline rbmgf7
  • 2>4
« Reply #29 on: August 29, 2011, 02:19:45 PM »
That's funny. Same thing happened to me when I had my 77 KZ400. Either coincidence with operator error or maybe there's something up with the retention system (if i recall correctly, it's just two M6 bolts which hold a backout plate?)
Offline Danno
  • 74 CB550,75 GL1000,76 KZ400,77 GL1000,73 CB750
« Reply #30 on: October 11, 2011, 07:24:23 PM »
I just pulled one of your D.I.D. master links apart broke the clip then the cap came off then the link started to pull apart when I got stopped
when you own a motorcycle the wife does not have to find you handy she just has to find you
« Reply #31 on: October 11, 2011, 08:16:06 PM »
Tugboat,
      You sure got blessed on that mechanical "save" & kept it w/ the rubber side down; YEAH ! It seems to me with that type of lock nut & locking (single)tab washer,
that torquing it down real hard like you did with locktite was the best fix.
        keep them good wheels rolling !
