Author Topic: big engine trouble  (Read 5783 times)
Offline phi
big engine trouble
« on: July 08, 2011, 03:52:11 AM »
Hi guys.
Recently I bought a new bike, a K5. The head gasket was leaking, so I pulled the engine to fix it. It turned out that I have a bore on 67 mm., which adds up to somewhere around 900 cc. plus the head cc.
 However happy I am about this, it has after reassembling given me a new problem: at around 5000 RPMs the engine backs out and start to stumble. I suspect it`s not getting enough air, as the carbs are original with stock jetting. The question is: Do I need bigger carbs to get this monster running decent, or is it possible for me to re-jet the originals to a usable degree.
The cam appear to be normal, the head has been polished, the valves are stock size.
I'm looking for torque and reliability, not neccesarily top end power.
wow, did you see that old Honda?
Offline MoMo
  • Ride like you're invisible
Re: big engine trouble
« Reply #1 on: July 08, 2011, 04:12:45 AM »
Did you have this problem before replacing the head gasket?....Larry
Offline phi
« Reply #2 on: July 08, 2011, 04:49:51 AM »
I never rode the bike before I bought it because of the blown gasket.
Offline MoMo
« Reply #3 on: July 08, 2011, 05:39:40 AM »
If the bike hadn't been ridden for a while, the carbs most probably need a complete cleaning. Timing is spot on? What clearance did you set the valves to?  Stock exhaust?  Stock air filters? Make sure the routine things are good before you go fiddling with the jetting.
« Reply #4 on: July 08, 2011, 05:55:48 AM »
Lots of other issues per Photolar, but basically, you should get the stock carbs to work, rejetting definitley necessary.  FYI:  CCs in the head are not counted as they are constant. The measurement is for "displacement" so its the number of cc's displaced that marks the engine size.
Yours is 888.8, (as is mine, but i am running VM29 Mikunis) which is often rounded to 900 for marketing purposes. That size with stock cam and valves, and a ported head and small carbs, would favor torque mid-range over higher RPM performance, I think. Should be a sweet ride.
http://www.nightrider.com/biketech/calc_displacement.htm
Offline phi
« Reply #5 on: July 08, 2011, 07:09:28 AM »
The valve clerances are set to stock meassurements, 0,5 mm for intake and 0,8 mm for exhaust, the timing and point gaps are spot on, 0.35 mm. It has a 4-1 exhaust and stock airfilter. every thing else is stock.
« Reply #6 on: July 08, 2011, 07:21:18 AM »
You may be lucky. If the faltering begins at 5000 rpms, that's about where the main jet kicks in. They are easier to change. Guessing you'll need to go up a step or two. If 130s, go to 135 etc. Main jets are in increments of 5.
Trial and error or more "professionally" , read the plugs.
But strictly speaking, the slow jets, (low rpms), the needle postion (mid rpms) and the main jets (higher rpms) may all need tweaking.
Offline mlinder
  • "Kitten Puncher"
  • Stop Global Tilting now!
    • Moto Northwest
« Reply #7 on: July 08, 2011, 07:57:35 AM »
Check ignition timing.
Check ignition advance.
Check cam timing.
Check for carb boot leaks.
What are you running for a filter and airbox? Anything?
« Last Edit: July 08, 2011, 08:04:25 AM by mlinder »
No.
Offline phi
« Reply #8 on: July 08, 2011, 08:55:21 AM »
the main jets are 120 as stock. Where should I start? 140? 150?
Would I gain anything by replacing with cb 900 carbs?
Offline mlinder
  • "Kitten Puncher"
    • Moto Northwest
« Reply #9 on: July 08, 2011, 09:01:45 AM »
Check and answer these questions:
Check cam timing.
If you are running stock intake, stock jetting from the k0's (120's, which you have) is fine. Could even be rich, with an otherwise stock k5.
No.
« Reply #10 on: July 08, 2011, 09:05:55 AM »
No I'd go a step at a time. 125s are next.
Don't know if the CB900 carbs are a bolt up switch or not, doubt it. You want torque, I'd stick with the smaller carbs, generally speaking.
Offline mlinder
  • "Kitten Puncher"
    • Moto Northwest
« Reply #11 on: July 08, 2011, 09:11:49 AM »
If his intake system is stock and he has 120's on a k5, it's probably slightly rich, depending on his altitude.
He needs to check the things I told him to, and comment on his intake setup, before rejetting.
No.
« Reply #12 on: July 08, 2011, 10:01:39 AM »
Well i agree with checking those things out. Assuming they're OK... he's got a stock air filter, ported head, 4-1 pipe, with 888cc.  Never seen a big bore with a pipe that didn't want more fuel.   I vote he needs to go richer, but hey its not the hill I want to die on. Easy to try both.
FYI: Avg altitude of Denmark is about 150ft. Highest point about 500+ ft.
« Last Edit: July 08, 2011, 10:04:03 AM by MCRider »
Offline phi
« Reply #13 on: July 08, 2011, 10:07:10 AM »
I may not be expressing myself accurately, for that I beg for forgiveness. As you may have noticed, English is not my native language.
I have checked and adjusted the engine, then rechecked. It starts by the slightest bump of the starter. it idles smooth and takes the gas without hesitating or stumbling. It runs perfect, the torque is strong and accurate.
But when it under load reaches 4500-5000 RPM, it starts coughing and is no longer responding. When I lower the RPMs it will again run smoothly. Maybe the advance, but when checking, it seemes to respond as it should. Maybe the ignition, but it is timed as it should be. The intake is as mentioned stock, even the filter. The boots are brand new, and checked with etherspray.
Offline mlinder
  • "Kitten Puncher"
    • Moto Northwest
« Reply #14 on: July 08, 2011, 10:12:47 AM »
Isn't stock jetting for a k5 a 105? He's at 120, which aint stock. Bigger bore with stock cam and intake can actually cause the mixture to run richer with stock jetting. Higher vacuum with the same intake restrictions will often pull more fuel through the jets.
No.
Offline mlinder
  • "Kitten Puncher"
    • Moto Northwest
« Reply #15 on: July 08, 2011, 10:14:32 AM »
You've checked the engine.
Does this mean you've checked that the advance is working?
No.
Offline mlinder
  • "Kitten Puncher"
    • Moto Northwest
« Reply #16 on: July 08, 2011, 10:45:59 PM »
Moved here for more help for this fellow.
No.
Offline Danno
  • 74 CB550,75 GL1000,76 KZ400,77 GL1000,73 CB750
« Reply #17 on: July 08, 2011, 11:35:30 PM »
i would move the jets back to 110 and did you say 4 into 1 exhaust most 4 into 1 are restrictive (tight) you may need to drop it back even further to 105 but i doubt it but the problem you are having sounds like a combination of too big a main jet and too restrictive exhaust on the plus side it sounds like the slow jet is right on but i would lean out the idle screws a half turn this may help make up for the restrictive exhaust
when you own a motorcycle the wife does not have to find you handy she just has to find you
« Reply #18 on: July 09, 2011, 12:46:45 AM »
i think the slow jet is too rich,try the next size down,,its easy to try without resync etc,,the stumble of richness can feel like a lean out,especially if you open the throttle and it goes good once again,the rpm at those revs easily equal an only partly open throttle with no load,under load itll go ok.,id go for the stock main jet and one lower slow jet.,jets dont "kick in" at a certain rpm,,they kick in at throttle position,do you have the stock air box and filter or separate pod type?
« Last Edit: July 09, 2011, 12:53:41 AM by dave500 »
Offline Gearheadgreg
  • Jamestown Rhode Island
« Reply #19 on: July 09, 2011, 04:00:56 AM »
What condition is your Air filter Old or New ? stock or Pods?  Edit you didn't comment if your Air filter was New just it was stock ? Mine was stock also when i purchased my F3,.......Can't imagine why the PO was having tuning issues,,,,
« Last Edit: July 09, 2011, 05:56:38 AM by Gearheadgreg »
2001 Honda Supercharged Valkyrie   <iframe width="480" height="360" src="http://s1218.photobucket.com/user/meloafer/embed/slideshow/"></iframe> Just having some fun
Offline Tintop
« Reply #20 on: July 09, 2011, 04:47:34 AM »
Gee guys, try reading the thread, the OP has answered all the setup questions multiple times.
My .02 - try running it with the filter removed from the stock air box.  An older stock paper one can look great, and still cause excessive restriction because the element has absorbed water.
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
« Reply #21 on: July 09, 2011, 05:47:50 AM »
If you have really set the valve clearances at .5 and .8 thats 10 times what they should be
« Reply #22 on: July 09, 2011, 06:20:25 AM »
He stated .5MM, I'm assuming he dropped a 0 as .002" = .05MM.  He's from Denmark = metric.
Offline sick_seven_fifty
« Reply #23 on: July 09, 2011, 06:48:30 AM »
I think he understood that it was in metric...that's why he said it was ten times more than it should be. (.05x10=.5)
« Reply #24 on: July 09, 2011, 06:52:59 AM »
Oops you're right.  Apologies.
So I'm back to assuming he said .5 and meant .05mm and as we all know we shouldn't assume.
