Author Topic: Is this rotor special??  (Read 1547 times)
Offline slikwilli420
  • Master of Disaster
« on: August 10, 2011, 07:06:00 PM »
I have two rotors, one is like most of the ones I have ever seen and the other has a different center hub. Both rotors are the same bolt pattern, offset, diameter, and thickness. The one with the silver hub is the one that is the same, and the black hub is the odd man out. Ideas???
Offline fmctm1sw
Re: Is this rotor special??
« Reply #1 on: August 10, 2011, 07:09:48 PM »
Maybe I'm not thinking hard enough but is the silver one just media blasted or something?
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
« Reply #2 on: August 10, 2011, 07:30:16 PM »
The one with the black hub has an abrupt step up from the rotor surface and the ribs on the back are totally different. The silver one is like the other rotors I have and does not have that large step.
Offline CycleRanger
  • No comment about being an
« Reply #3 on: August 10, 2011, 07:48:06 PM »
The rotor in the first picture appears to have the characteristics of a K0 rotor, i.e. the abrupt step you noticed.
Like this one.
« Reply #4 on: August 10, 2011, 10:19:27 PM »
KO rotor, goes with a silver caliper.. do someone a favor and dont drill it..
« Reply #5 on: August 10, 2011, 11:49:13 PM »
the boss around the rivett is also different.
« Reply #6 on: August 11, 2011, 05:47:15 AM »
Honestly it was in my hand on the way over to the blast cabinet to take the paint off the hub. Thats when my spider sense went off. It will not be getting drilled or modded in any way. Also came up with a unicorn top triple clamp while scrounging in my parts boxes. Not too bad!!
Offline CycleRanger
« Reply #7 on: August 11, 2011, 06:41:25 AM »
You should tape off the rotor before you blast it. Blue painters tape works fine.
« Reply #8 on: August 11, 2011, 09:42:33 AM »
I have actually read that media blasting the rotor surface is an easy way to deglaze them for better stopping. I think I will blast both parts and then paint the center. The early rotor can go to a new home, as I dont want to cut that one up.
Offline CycleRanger
« Reply #9 on: August 11, 2011, 10:53:14 AM »
yeah, I suppose that would work ok.
I recently repainted the center of my rotor. Masking was a pain but it turned out nice.
