Author Topic: look at my primary chain!!!  (Read 4119 times)
Offline xsmooth69x
« on: September 09, 2011, 01:52:13 PM »
anyways in another thread it was mentioned i should drop the oil pan and check the "play" in the primary chain. anyways i checked my main motor and this is what it looks like
the video and the pictures are my main motor only
cb550 loose primary chain :(
sorry about the background noise pawnstars was on jtv playing on my laptop  :P
sitting
pulled up
from the other side
sitting
pulled up
sitting
pushed down
then you can kinda see some scratched
oddly though i looked at my other parts motor and the chain is definitely loser but id doesn't have any chain rubbing like the picture above of my pain motor.
its nice that the oil filter screen in both motors where nice and clean. also there was so metal or debris in the oil pan, just a little slug
« Last Edit: September 09, 2011, 01:54:23 PM by xsmooth69x »
1975 CB550 (FINISHED?!?!?)
Offline xsmooth69x
Re: look at my primary chain!!!
« Reply #1 on: September 09, 2011, 03:14:03 PM »
bump
Offline xsmooth69x
« Reply #2 on: September 09, 2011, 07:08:43 PM »
bump!!!!!!!
dave500 twotired  :)
Offline fmctm1sw
« Reply #3 on: September 09, 2011, 07:10:29 PM »
I've seen a couple recent posts about primary chains and it has me interested (aka worried).  So you can see where it's chewing into your case?
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline xsmooth69x
« Reply #4 on: September 09, 2011, 07:27:21 PM »
well dave500 posted pics on what it looks like when it rubs on the bottom case
unfortunately i dont have my case apart so i cant see inside of it. all i have is my pan dropped.......
another thing is like..... did all the cb550 owners on this forum replace their primary chain? i mean i cant imagine none of these motors are low millage........
« Last Edit: September 09, 2011, 07:29:20 PM by xsmooth69x »
« Reply #5 on: September 09, 2011, 10:19:04 PM »
under power the top is pulled as tight as hell which lets the bottom section that you were rattling get even slacker,try and wrangle a mirror up there to spot the area it might be rubbing on,go to the dentist and have some teeth pulled out or drilled and gansta gold teeth fitted(i like solid chrome myself) then when hes not looking steal the little mirror they use,,,i think that chain looks past its use by date,,i know its a major job but you want to just ride the bike and not have any issues once its on the road,,you have a spare engine see how you go taking it apart?every single piece has to be washed and cleaned almost germ free before reassembly,,its a sort of plan A becomes plan B thing so while its apart the cam chain should be done,replace any sloppy bearings,look at the dogs on the gears and forks etc,each and every seal replaced,you can get away with reusing bearings etc if they are good,,the primary chain is a case wrecker if its let go too long.
« Last Edit: September 09, 2011, 10:22:50 PM by dave500 »
Offline Danno
« Reply #6 on: September 10, 2011, 01:56:00 AM »
he is right I have 30,000 miles on mine and it is not anywhere as loose as that but it does make some noise in neutral but then they all do
« Reply #7 on: September 10, 2011, 02:17:26 AM »
itll rattle worse if your carbs are out of sync,,and/or your idle is too low or its idling cold and #$%*ty,they shouldnt rattle idling,if it does and all else is good it needs replacing.
Offline xsmooth69x
« Reply #8 on: September 10, 2011, 03:27:50 AM »
ok then how about this.....
im going to put the bike together and ride it for the last 2 months or so before it starts snowing.
then ill carry my engine into the basement and do a complete engine tear down and rebuild it. ive spent enough money sparing no expense on anything else ill completely rebuild the engine to spec (throw in a cb650 cam and tach drive)
is there some sweet aftermarket parts i can throw in the motor that will make it faster? (that isnt outrageously priced)
Offline WarwickE36
« Reply #9 on: September 10, 2011, 06:46:14 AM »
looks pretty shot man.  maybe not quite as loose as mine, but pretty close.  DO it now.  Its a #$%* but the consequences of not doing it are far worse later down the road.
Check my motor rebuild thread and watch my videos to compare.  its hard to tell without actually being there to feel the play.
« Last Edit: September 10, 2011, 06:50:17 AM by WarwickE36 »
" Why does anyone get offended by what someone does to their own bike? I dont get it. "
You made me think about it after I cheered knowing someone else would like to know what these control freaks are up to.
 Every time any owner strips whatever precious Honda part the horrified purists parts go up in value. That's not the part that bothers them.
 What bothers them is they sat up late at night, their breast full of wonder and estrogen, unable to sleep, dreaming about their lovely darling and all her glory... and next thing you know someone else doesn't share their emotional deluge and their reaction is they must spread their mind museum as far as they possibly can, taking over as much of the real world as possible.
Drink fast, drive slow, but ride it like you stole it
1974 Cb550 with style
2004 SV650s
Offline xsmooth69x
« Reply #10 on: September 10, 2011, 11:48:04 AM »
yes i saw your thread and i book marked it.
like i said i will be rebuilding that engine.
but of now i have 2 months or so before snow comes so i was just saying ill ride it till then. when i get it running ill listen to the motor to see if the chain is hitting anything.
« Reply #11 on: September 10, 2011, 01:55:08 PM »
you might not hear it,the case is soft.
Offline WarwickE36
« Reply #12 on: September 10, 2011, 02:12:23 PM »
Well the choice is yours...
I personally wouldn't want to pull a motor twice.  If you saw my thread you will notice I pulled the motor on August 25th and am already back riding.  I spent most of that time waiting on parts.  With diligence and parts ordered soon you could have a month and a half of riding time with a motor that isn't going to destroy itself.
2004 SV650s
Offline Lostboy Steve
« Reply #13 on: September 11, 2011, 07:31:05 AM »
How long did that screwdriver sit out in the yard?
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
