Author Topic: Oil Light Always Off  (Read 997 times)
Offline Analysis
« on: September 09, 2011, 03:18:50 PM »
Hi guys,
After my rebuild everything was going well (500km in) but now the oil light is always off. I tested the light and it works and I made sure the connection from the light heads into the engine - but without any oil pressure (engine is off) the light is still off and doesn't turn on. Switch issure? Should I check connections along the side?
Thanks!
Offline CycleRanger
  • No comment about being an
Re: Oil Light Always Off
« Reply #1 on: September 09, 2011, 06:15:54 PM »
Light bulb, wiring, switch.  :)
« Reply #2 on: September 09, 2011, 06:28:32 PM »
The old what model of bike and year question  :P  As mentioned look at the easy stuff first and work your way back. Expose the actual light and socket,give it a wiggle,change the bulb etc.  and work your way back. Just played with a couple of oil light issues recently.
« Last Edit: September 09, 2011, 06:38:13 PM by ekpent »
Offline Bodi
« Reply #3 on: September 10, 2011, 08:23:21 AM »
If you know the light is good, use a bit of wire to jumper from the wire going to the oil pressure switch to ground. Light on? bad switch. Light off? bad wiring plus maybe (not likely) a bad switch.
Offline Analysis
« Reply #4 on: September 12, 2011, 10:28:28 PM »
Light on after shorting to ground aka bad switch. How do I find this?
« Reply #5 on: September 13, 2011, 12:32:45 AM »
NEED TO KNOW WHAT BIKE!!!!
Offline Analysis
« Reply #6 on: September 13, 2011, 05:12:45 PM »
Sorry '74 CB750K.
Offline rklystron
  • I have not failed. I've just found 10,000 ways that won't work. Thomas A. Edison
« Reply #7 on: September 13, 2011, 07:44:31 PM »
Bad switch, replace. Part number 35752300020 SWITCH,NEUTRAL , Or go to a bone yard and pick one up.
1970 CB750 K0 (Bought in 73)
1972 XL250 (Bought new in 72)
1973 ST90 (Free)
1975 XL250 (Free)
1975 Rickman CR750
1982 CBX1000 Pro-link
1975 CB750 DRAG BIKE
1977 Custom Built CB750 Sturgis Bike (GL front end).
1977 CB750 F2 (Big Resto)
1977 CB750A (Auction Buy)
1978 CB750 K8 (My San Francisco ride)
1984 VFR750 (Bought New)
