Author Topic: Number of chambers on the 341 exhaust  (Read 637 times)
Offline plippo
  • A but crazy about Honda's
« on: September 11, 2011, 04:58:04 AM »
Guys,
need a clarificaiton here. See a previous consideration from Hondaman:
HondaMan:
What mainjet size do you have? On a K2, I would expect either a 100, 105, or 110: the early K2 had 110, the "middle" of the production had 105, and just before the K3 appeared, they had 100, along with the short-production 7-chamber exhaust pipes. You can see how many chambers your mufflers have by counting the little spotweld dimples along their length: inside the pipe, there is a baffle at each dimple. The HM341 pipes came in 4, 5, and 7-baffle versions: the set I bought last year (new) has 5, for example. My original ones had 4 baffles, the carbs had 110 mainjets. When I replaced the pipes in late 1972 because of an accident I had, they were the 5-baffle types, and I had to go to a 105 mainjet: Honda had also done this in production about that same time. Today, at altitude, I run with 100 mainjets (6000 feet where I live), and I don't have the carbon issues.
see attached pics - which dimples do I count?
Cb750 K0, 1, 2, 6, F1
Cb500 K0, 1, 2
Cb550 K '78
Cb550 SS F0, F1, F2
Cb400 F1
Cb450 Blackbomber
Cb450 73
CL450 68
CL350 71
GL1000 K0,1,2,3,Z
Cb250 K0
CB125 K0
XL250 K0, K3
VF500
VFR750
Spacy250
they all look good form the distance!
Offline 65Ch3v3LL3
Re: Number of chambers on the 341 exhaust
« Reply #1 on: September 11, 2011, 05:32:36 AM »
He is referring to the rows of dimples. Each dimple is a spot weld. Each baffle in the muffler is a disc and its spot welded all the way around. So where you see several dimples in a row that is one baffle, go along the muffle a little further down and you will see another row, that is another baffle.
1979 CB650
2011 Harley Road King
2008 Harley V-Rod VRSC DX
2012 Sierra Denali 2500HD
1965 Chevelle Malibu SS
1922 Ford T-Model
Offline plippo
« Reply #2 on: September 11, 2011, 06:50:15 AM »
Ok So the first image show 3 rows of dimples, ie 3 chamber. what puzzled me is that he mentions 4,5,7 chamber, but not 3 chambers for early K2...I am rebuilding and found a 105 jet, so I guess I will keep that and test later if it is too lean...?
Cb500 K0, 1, 2
Cb550 K '78
Cb550 SS F0, F1, F2
Cb400 F1
Cb450 Blackbomber
Cb450 73
CL450 68
CL350 71
GL1000 K0,1,2,3,Z
Cb250 K0
CB125 K0
XL250 K0, K3
VF500
VFR750
Spacy250
