Author Topic: Speedometer squeal...?  (Read 902 times)
Offline bjatwood
  • I never claimed to be an
  • 1973 CB750-K3
    • Minbikers Proboards
« on: September 12, 2011, 08:54:14 AM »
Hi guys, My K3 speedo has a high pitch intermittent squeal that emits from it after 20 to 25 miles of riding. I know I am going to have to take it apart. But, what should I look for when I'm in there?
Brian
#24193
I believe that the Finest things are the most thoughtfully made, not the most expensive!
http://minibikers.proboards.com/
KingCustomCycles.com
Re: Speedometer squeal...?
« Reply #1 on: September 12, 2011, 09:19:33 AM »
That is a brass bushing inside and it wears slightly emitting the squeel.  I have had it go away with riding.  It can be disassembled, lightly lubed, and reassembled.  Go to the home page and use the search function in the upper right hand corner of the screen.  A few threads on this in the past.
Offline bjatwood
  • 1973 CB750-K3
« Reply #2 on: September 12, 2011, 05:24:05 PM »
Thanks King!
Just what I was looking for.  8)
Brian
#24193
Offline Nortstudio
  • Not nearly an
  • Just getting started...
    • MotoPreserve
« Reply #3 on: September 12, 2011, 07:14:44 PM »
I was probably part of one of those threads.  I had the most awful squeal, and on the advice of TT, ended up just leaving it out until the winter was over, and it went away.
Good luck.
1976 CB550K...in progress
1975 CL360...eventually custom
2009 Husqvarna TE610
a blog about wrenching in Brooklyn, NY
“Success is dependent on effort.”
~Sophocles
