Author Topic: Clutch Cover Full Disassembly?  (Read 693 times)
Offline gonzobrian
« on: September 23, 2011, 03:29:55 PM »
The aluminum engine covers on my 750 have been chromed in the past.  Now the chrome is badly flaking off.  I have found that most of the time it is cheaper to buy used non chromed parts instead of having the originals de-chromed.  This is not the case for the clutch cover for a sand cast as it only has 9 holes to mount instead of 10.
Which brings me to my question.  I need to fully disassemble the cover before I send it off but it has a center insert that appears to be pressed in see below.  But before I go hammering away I wanted to ask has anyone removed this insert circled in yellow below, and how did you go about it?
Offline gonzobrian
Re: Clutch Cover Full Disassembly?
« Reply #1 on: September 25, 2011, 05:45:35 AM »
Bump.  Any one remove this center piece?  It was definitely removed when it was chromed back in the day.
Offline Greggo
  • Somebody's
  • Helmets Save Lives. Period.
« Reply #2 on: September 25, 2011, 06:19:16 AM »
I'd add 'sandcast' to the title of this thread, and for the most help, I'd take the issue over to the SOOC (sandcast only owners club) forum.
Offline Patrick
« Reply #3 on: September 25, 2011, 06:49:30 AM »
That comes out. I just switched the roller assembly from one clutch cover to another a couple weeks ago. It taps out, but I cannot predict how much force will be needed to remove yours.
Patrick
1970 CB750 K0
1982 VF750S Sabre
1987 VT1100 Shadow
1979 Yamaha XS11
1969 Yamaha DT1B
etc.
Offline gonzobrian
« Reply #4 on: September 25, 2011, 07:43:04 AM »
Patrick
Thanks very much.  Should I heat it up first with a torch?
Offline Patrick
« Reply #5 on: September 25, 2011, 07:51:24 AM »
You shouldn't need to. On the donor clutch cover that part came out easily. On the recipient the old one took some persuasion.
1970 CB750 K0
1982 VF750S Sabre
1987 VT1100 Shadow
1979 Yamaha XS11
1969 Yamaha DT1B
etc.
Offline gonzobrian
« Reply #6 on: September 25, 2011, 08:22:49 AM »
Cool thanks.  Out of curiosity why was it replaced?  Do they go bad?  How do you know?
Offline Patrick
« Reply #7 on: September 25, 2011, 08:30:37 AM »
I didn't really have a good reason to change mine. I had a clutch cover with a fully functional, but a bit discolored by age, assembly. I had another with a shiny, new-looking assembly. The better cover had the lesser assembly, so I put the shiny one in the nice cover. Like I said, since you can't see it when the clutch is assembled, the switch was pretty pointless, except to use the nicer looking parts.
Patrick
1970 CB750 K0
1982 VF750S Sabre
1987 VT1100 Shadow
1979 Yamaha XS11
1969 Yamaha DT1B
etc.
« Reply #8 on: September 25, 2011, 10:36:49 AM »
The butt end of a pin is visiblle. That pin fits into a hole in the cover. It is all friction. Hold the cover with that side pointing down and tap it with a mallet. The piece should just fall out. No effort or heat needed. I've had mine out many times.
Take it out to send cover off for polishing so it doesn't get lost.
