Author Topic: Dyno cover removal  (Read 981 times)
78CB750F1
Dyno cover removal
« on: May 15, 2006, 12:51:31 AM »
Is there an easy way to remove the dyno cover?  I have taken out the screws but can't seem to pop it out and there isn't a place to pry it out.  Do I have to remove the inner dyno cover as well and push it out from the inside?
Offline cben750f0
Re: Dyno cover removal
« Reply #1 on: May 15, 2006, 01:01:02 AM »
i just give is a light tap with a rubber mallet, dont bash into it.... you just need to jar it to break the gasket seal, hope this helps..peace
78CB750F1
« Reply #2 on: May 15, 2006, 01:02:57 AM »
Thanks!  I will give it a try.
