Author Topic: Key # not in the Honda key code book?  (Read 9342 times)
Offline Dimitri13
  • 1974 CB550K
« on: October 23, 2011, 04:43:53 PM »
Well, mere hours before I planned on getting my key copied with the two blanks I had to order (no one here carried it), I lost the key.
I found the key code # on both the ignition and seat lock, but when I took that code to the dealer, and even a professional locksmith, they couldn't find it in their books/database/whatever.
I know it's a Honda key code, because I've found NOS keys on eBay, as well as NOS ignition sets.
Is there any way to get a replacement cut, by providing them with the actual cut #s the code # points to or something? I need a key ASAP, which is why I didn't just order a NOS one.
Bike is '74 CB550, and the key code is T9927.
Re: Key # not in the Honda key code book?
« Reply #1 on: October 23, 2011, 05:32:13 PM »
I just bought one at an old dealer by the number only. It was pre-cut.
Offline MoMo
  • Ride like you're invisible
« Reply #2 on: October 23, 2011, 05:36:09 PM »
Try www.hondakeys.com .  He is a member here and seems to have a keys for most anything...Larry
Offline chickenman_26
    • Motorcycle Consumer News
MCN DTF
Offline Gman
« Reply #4 on: October 23, 2011, 07:40:34 PM »
I have to recommend HondaKeys - I just bought 2 sets of keys from just #'s this summer from him (ignition and seatlock/steering lock).  He is good people - answered my questions w/o pushing his service, then came through for me.  Good luck!
Gman
'76 CB550K
Stock airbox, MotoGPWerks 4-1, HondaMan ignition, Lesters
« Reply #5 on: October 24, 2011, 04:22:00 AM »
I usually just go to Home Depot or Lowes and match the key profile to a blank.  From the blank it  is easy enough to file a new key at home to match the old one.
Offline d9canada
« Reply #6 on: October 24, 2011, 02:18:51 PM »
I had keys cut from the code recently and they told me that only the last three digits matter.  Hope this helps.
Also there is a note on the SOHC4 site about key cutting.  Instead of opening the switch as shown, here's a hack.. wipe the blank with a Sharpy, then put it in the lock and wiggle it back and forth.  This will wipe some of the ink away where the key needs to be grown away.. use a Dremel to make small relief, re-ink the blank and repeat.
Brian
CB350F to CB900C
GL500
GL1000
CBX
02 Sportster 883
64 Suzuki M15D Sovereign 50cc
Offline Gman
« Reply #7 on: October 25, 2011, 06:24:54 AM »
To clarify - I'm 99% certain the keys I got from HondaKeys were not cut to order.  They are NOS or equivalent numbered factory keys that he just pulls from his supply.
'76 CB550K
Offline MoMo
« Reply #8 on: October 25, 2011, 06:05:19 PM »
He does not cut, all are NOS-at least that is what he said in an email...Larry
Offline VTCBike750
« Reply #9 on: October 26, 2011, 07:12:26 AM »
Hey my 750 fork lock takes the T9927 key. got it off ebay.
-Adam
1972 CB750 (current project)
http://forums.sohc4.net/index.php?topic=87951.0
Offline Dimitri13
  • 1974 CB550K
« Reply #10 on: October 26, 2011, 03:00:43 PM »
I already ordered a set of NOS keys.
But my dilemma was that nobody could cut a key with the code, because it wasn't in their database. The Honda dealer didn't have any TXXXX, or 9XX in their database. Even with the last 3 numbers, it only went up to 8XX.
