Author Topic: intermittent ignition (i think?!?!?!) problem?  (Read 1146 times)
Offline 000jeremy
« on: November 08, 2011, 06:39:06 PM »
On the way back from a long trip (1500k plus miles)  at highway speed I felt my bike lurch and lose power...sounded like 2 cylinders went out.so I pull over look around for a few minutes and fire it back up - everything is fine.  It happens again maybe 20 miles later.  I pull over and wait a bit then start up again - everything fine for another 20 or so miles.  I do this a couple more times till I get home...it seems to go away in stop-and-go traffic and lower speeds.  Everthing is fine, very light riding for the next month or so.  Now I commute 20miles round trip to work with about 40 percent highway and its back.
2 cylinders seem to cut out, usually on highway, but just briefly and then it kicks back in...once in a while sometimes it seems to get stuck on 2 cylinders so I pull over and it seems to come back after a short while.
I replaced my dyna s about a year ago after it crapped out so Im hoping that its not to blame...again.  Im sure its a timing/ignition thing because of how sudden it is and it is clearly 2 cylinders dropping out at a time.  Should I be resetting the timing on the dyna frequently?  Could it be something else?  I did put a lot of miles on the bike this summer so maybe it is due.
Thanks in advance for the input:
77 cb550f
new plugs and wires and dyna s within the past year
Offline raymond10078
  • Just learnin' as I go . . . .
Re: intermittent ignition (i think?!?!?!) problem?
« Reply #1 on: November 08, 2011, 06:43:49 PM »
« Last Edit: November 08, 2011, 07:31:40 PM by kandrtech »
1978 CB750A (upgrading very, very slowly)
Past bikes - Honda: SL350, CX650C, CB900C, CB1000C, CM450A; Kawasaki: several 1972 750 H2's; Suzuki: TC90J.
Bikes I want: CX650ED, a mid-sized japanese V-twin with ABS.
« Reply #2 on: November 08, 2011, 06:46:32 PM »
77 cb550f
Here we go again; another dyna s failure. :o :o :( :(
