Author Topic: Thinking of Buying a 1978 CB750F... Chain Adjustment Question  (Read 12480 times)
Offline dhall57
Re: Thinking of Buying a 1978 CB750F... Opinions? New Pics!
« Reply #75 on: January 08, 2012, 11:00:36 AM »
Looks like you've got a good solid 750F there and it just needs some TLC and you'll be good to go. And at $500 you stole it. Great buy. ;D Don't worry to much about the weeping oil around headgasket area because its pretty much a standard issue on these older SOHC4's my K6 is the same way. Yours is probably only minor like mine. Do a search for paper towel trick. That Mac pipe is just like the one that's on my 750K6 also
« Last Edit: January 08, 2012, 11:10:42 AM by dhall57 »
1970 CB750KO
1971 CB500KO-project bike
1973 CB350G- project bike
1974 CB750K4-project bike
1974 CB750K4
1976 CB750K6
1977 GL1000
1997 Harley Wideglide
Offline fatmatt650
  • Part Deux
« Reply #76 on: January 08, 2012, 11:12:52 AM »
That rack is quite an eyesore! You should yank that p.o.s. off and send it to me! ;)
Offline Graydude
« Reply #77 on: January 08, 2012, 11:33:20 AM »
Damn!  That is one nice bike!  You have the deal of the century on your hands.  $500?  Criminal.
Offline 2wheels
« Reply #78 on: January 08, 2012, 12:02:38 PM »
Nice looking bike
Thanks for the pictures of the luggage rack.
I see your not having much of a winter in Sask either.  I'm just hoping winter doesn't start and then drag into April.  That would effect the riding season   >:(
1970 CB750 K0 (I can't believe I tossed my duck tail seat in the trash 30 years ago)
Offline Imago
  • 1978 CB750F
« Reply #79 on: January 08, 2012, 12:07:23 PM »
It's been above freezing every day this week and is projected to do the same on some days for the forseeable future. Around here some years it gets to minus 40 (-40 is where fahrenheit and celsius meet).
Global warming? Good for riding but not so good for folks near the equator.
Glad the pics help.
« Last Edit: January 08, 2012, 12:30:56 PM by Imago »
Offline Imago
  • 1978 CB750F
« Reply #80 on: January 08, 2012, 01:17:34 PM »
You sure that is a Mac exhaust? Doesnt appear to be...
One thing about the PO, he kept every bill he ever had and gave me a file folder full of stuff from day 1.
That included the exhaust system he put on a few years ago which on the bill was listed as an 801-1301. When I "googled" that number, there she was, a MAC 4 into 1. It's almost too quiet.
« Last Edit: January 08, 2012, 01:19:44 PM by Imago »
Offline FuZZie
« Reply #81 on: January 08, 2012, 04:53:06 PM »
That is a nice find and a great deal, so where are you with this.... rider, restore or you have some build ideas?
Offline Imago
  • 1978 CB750F
« Reply #82 on: January 08, 2012, 05:21:16 PM »
This is the second bike I picked up since the fall. The first is a 1976 CB750K that needs quite a bit of work.
I think this CB750F will be my rider while I cafe (or something) the K. The K has been butchered up a bit anyway, you can see photos of what the PO did to it this other thread: http://forums.sohc4.net/index.php?topic=96106.msg1070083#msg1070083
This F is too close to stock for me to go messing with it too much. I like the look of it. The most I might do is put a GL1000 front end on it so I can use both my Lester rims, and get rid of the comstars. The jury's still out on that though.
First thing is getting it running properly.
« Last Edit: January 08, 2012, 05:24:30 PM by Imago »
Offline FuZZie
« Reply #83 on: January 09, 2012, 05:31:52 AM »
Cool I like it as is, even the comstars.
Offline Imago
  • 1978 CB750F
Re: Thinking of Buying a 1978 CB750F... Opinions? New Question...
« Reply #84 on: January 27, 2012, 08:24:12 PM »
I'm going to need a new chain and sprockets.
Any thoughts on # of teeth, and chain size/type will be appreciated, as well as good (read: inexpensive) sources.
I'm leaning towards a non o-ring chain.
I'll mostly be commuting about 40 kms on a 4 lane hghway with the occasional foray much further afield.
Also, anyone have a bracket for the Vetter III fairing that came with the bike?
Offline Doggie
  • CB550F, CB650c, CB550k, Cb750K
« Reply #85 on: January 27, 2012, 09:18:16 PM »
Great looking bike...I'm working on a '78 CB750K that I picked up in running order for $790.00.  Needed a seat and a battery. You got a great deal with all the extras too!!
                                          Good Luck, Doug
Offline Imago
  • 1978 CB750F
Re: Thinking of Buying a 1978 CB750F... Chain Adjustment Question
« Reply #86 on: April 23, 2012, 08:38:19 PM »
I pulled and cleaned the carbs on the weekend, and got it running and idling quite well. After I pulled and cleaned the slow jets, it idled well but much higher than it should... is this common with plugged slow jets?
What a great feeling to go for my first ride on my new (to me) bike after at least 15 years of being without! I had forgotten how much fun it is. It's also a great feeling to know you've done the work yourself and thanks to those who provided such great advice. I never would have thought of pulling the pressed in slow jets without this forum. I changed the oil, installed a NOS chrome spin on filter and put in a new GEL battery.
A question... when lubricating/adjusting the drive chain I removed the cotter key, loosened the big axle nut on the right side but was unable to loosen the big nut (without a cotter key) on the left (looking from the back) and bent the adjusting bolt on that side trying to tighten the chain. Do both these big axle nuts get loosened when adjusting the chain, or just the one with the cotter key?
Offline kap384@telus.net
« Reply #87 on: April 23, 2012, 09:08:17 PM »
Left side is actually the head of the axle.  By removing the nut it should be loose enough.   Try persuading it loose by hitting the end you removed the nut from with a hammer.  Surprised its that tight. Normally just take out he cotter pin, loosen off the nut, back off jam nuts and tighten up chain.
Great find by the way.  I should have the mount for a Windjammer SS that came of my 'F' if you're interested.
Where abouts in SK?
« Last Edit: April 23, 2012, 09:16:06 PM by kap384 »
1965 Honda CB450K0
1972 Honda CT70K1
1975 Honda CB400F Supersport
1977 Honda CB750F2 Supersport
1978 Honda XL100
1979 Honda CBX Supersport
1982 Honda VF750S Sabre - Adventure Bike modified
1983 Honda CX650T
1995 Honda VFR750
2016 Honda CRF1000L Africa Twin
2015 KTM 200 XC-W
1963 Suzuki T10
My 1977 CB750F restoration - http://forums.sohc4.net/index.php?topic=66779.0
My 1975 CB400F restoration -
http://forums.sohc4.net/index.php?topic=145196.msg1651779#msg1651779
'More Stock Than Not' thread - http://forums.sohc4.net/index.php?topic=90807.500
My CT70 Resurrection - http://forums.sohc4.net/index.php?topic=145221.0
Best Motorcycle Tool Ever - https://www.engduro.com
Offline Imago
  • 1978 CB750F
« Reply #88 on: April 23, 2012, 09:30:22 PM »
We overlook the Big Valley Jamboree grounds near Craven. I could use that Vetter mount... do you have any use for a Kawasaki mount? I'll wack the axle from the cotter pin side and see if I can free it. Thanks!
