Author Topic: The latest addition: 1975 CB750 for $300  (Read 22203 times)
mrjack55
« on: November 20, 2011, 04:16:48 PM »
Hey guys today I got a chance to look at a K5 750 that a guy was selling locally for $300.00  Well, need less to say I bought it.  Tomorrow I will pick it up and begin the work.
It is a one owner bike, and it has been garage kept most of the time.  It's in really nice shape.
The bad:  75K miles.  It has a rusted frame.  On the left side, under the engine, there are a a few spots that go through.  Also, It has been repainted, and the headlight ears are not the original ones and they are painted.  Not to mention, he had a windjammer on it for most of it's life, so there are a few taps into the harness.
The good:  It started and ran...on 3 and 4, but it ran.  1 and 2 stayed pretty cold.  The carbs look good and are pretty clean.  I'm sure they just need a good cleaning. It's a one owner bike.
I'll post more once I get it home tomorrow.  Should be fun.
Re: The latest addition: 1975 CB750 for $300
« Reply #1 on: November 20, 2011, 04:34:36 PM »
Congratulations mate, that must be the bargain of the week! Over here in Oz I'd pay at least ten times that for a bike in the same condition. Cheers, Terry. ;D
Offline dhall57
« Reply #2 on: November 20, 2011, 04:39:50 PM »
mrjack, great find and great price for only $300. Yes the bargins are still out there ;D
1970 CB750KO
1971 CB500KO-project bike
1973 CB350G- project bike
1974 CB750K4-project bike
1974 CB750K4
1976 CB750K6
1977 GL1000
1997 Harley Wideglide
Offline Rigid
  • She likes a
    • KingCustomCycles
« Reply #3 on: November 20, 2011, 04:42:30 PM »
Are you going to repair or replace the frame?
Online CycleRanger
  • No comment about being an
« Reply #4 on: November 20, 2011, 04:47:54 PM »
mrjack, great find and great price for only $300. Yes the bargains are still out there ;D
Indeed. He stole that at $300.  :)
Offline bjatwood
  • I never claimed to be an
  • 1973 CB750-K3
    • Minbikers Proboards
« Reply #5 on: November 20, 2011, 04:50:16 PM »
Nice score, you can replace or fix that frame easy enough.
Brian
#24193
I believe that the Finest things are the most thoughtfully made, not the most expensive!
http://minibikers.proboards.com/
« Reply #6 on: November 20, 2011, 05:24:09 PM »
If i found rust like that anywhere on a frame i WOULD NOT attempt to fix it. It will probably have more rust you can't see and on a 220KG bike i would not risk it at all. Frames are cheap, and you sure as hell got that bike cheap enough, so my advice would be to get a better frame and enjoy the ride without having the fear of a frame failure in the back of your mind.... ;)
Offline Greggo
  • Somebody's
  • Helmets Save Lives. Period.
« Reply #7 on: November 20, 2011, 05:31:52 PM »
$300?!  SCORE!
Offline Trav-i
  • Has finally become an
« Reply #8 on: November 20, 2011, 05:34:12 PM »
Awesome deal man!  I recently missed out on an all orginal 3600mi 77 supersport for $400.  Old guy that had it sold it the day before I heard about it for $700.  Oh well you win some, you lose some.
Forum member #9962
1992 GL1500 Interstate
« Reply #9 on: November 20, 2011, 05:54:53 PM »
Deal!
Offline MoMo
  • Ride like you're invisible
« Reply #10 on: November 20, 2011, 06:12:55 PM »
For this area that is a great deal.  Did you get a title?  If so, 300 for a 750 around here is a steal.  The suggestion to replace the frame is almost impossible in PA, unless one were to fill in the new frame numbers and stamp in the original-but I didn't suggest that ::)...Larry
Offline wedoo2
« Reply #11 on: November 20, 2011, 06:18:25 PM »
+1
But a heck of a deal.  Give you $400 :D
Some days the sun is too loud.
« Reply #12 on: November 20, 2011, 06:42:32 PM »
$500!
Offline Roach Carver
« Reply #13 on: November 20, 2011, 06:44:48 PM »
I have seen these frames have issues exactly where you are talking about. I had one that was not a rust through issue, but an issue of water getting into the frame and settling in that area where it freezes in the winter and splits the tube. I repaired one by having another section layed over the damaged area and stitched down segmentally. not a constant bead all the way around if that makes sence?
« Last Edit: November 20, 2011, 06:47:06 PM by Roach Carver »
« Reply #14 on: November 20, 2011, 06:45:51 PM »
I have seen these frames have issues exactly where you are talking about. It is usually not a rust through issue, but an issue of water getting into the frame and settling in that area where it freezes in the winter and splits the frame. I repaired one by having another section layed over the damaged area and stitched down segmentally. not a constant bead all the way around if that makes sence?
skip weld?
« Reply #15 on: November 20, 2011, 06:47:39 PM »
sounds good ... thats what I would call it.
« Reply #16 on: November 20, 2011, 06:58:47 PM »
I recommended replacement because that is what i would do without hesitation, its piece of mind that i am after... :)
Question, how does the water get in there in the first place.?
« Reply #17 on: November 20, 2011, 07:03:54 PM »
osmosis? or the fancy new reverse osmosis. I dont know....
RR sent you a pm
Offline Hondawggie
  • Flimmy-Flammy, Hambone-Sammy -- I'm a Bigole
« Reply #18 on: November 20, 2011, 07:07:04 PM »
MEIN GOTT I'd buy that fer a doller or $1000 sheesh ONE OWNER?!!
I thought I was the best all-around cheefskafe
$300 that is a deal deal deal there son
pshaw on the mileage
mein gott
Offline Grnrngr
« Reply #19 on: November 20, 2011, 07:21:13 PM »
Very nice!! I'da done it in a heartbeat. Gonna keep it stock or get creative with the frame? That seat sure doesn't look like it has 75k miles on it..
'72 CB750-K2 "PopCycle"
'73 CB750-K2 "Barney"
'77 CB750A
'83 Virago 500 (red)
'83 Virago 500 (black)
mrjack55
« Reply #20 on: November 20, 2011, 07:21:26 PM »
Thanks guys.  I appreciate all your advice.  It was a hell of a deal that I just couldn't pass up.
The only thing I'm not getting is the original HM 341 exhaust.  He wants to sell it separately.  Tomorrow I'll try to offer negotiations.  I get the impression that he wants a bit more than $300 for it.  Regardless, he does want to sell it and I told him that I would post it here.  I'll let you know what happens.
As far as the frame goes, I'm going to check it out with a buddy of mine and see how bad it is.  I'm all for a frame swap, but like Larry said, in this area finding a 75 frame with a title is near impossible.  I do have my titled K7 frame sitting here, but that would kill the whole idea of having a 1 owner K5 that is for all intents and purposes a survivor.
I think the water got into the frame via the Windjammer that was on the bike for years.  If there was a pin-hole of a crack somewhere, the faring could have directed rain water right to it.  IDK, for a bike that was so well maintained and garage kept, I can understand how this would happen.  I try to get some pics of the frame rot.  If I can, I'm going to lean towards welding.  Stay tuned my brothers and sisters.
Offline Hondawggie
« Reply #21 on: November 20, 2011, 08:03:08 PM »
Get creative with a tale of some sort then get them 341 pipes
Here's what I'd start with, I'd be keeping in mind he is shy a bit having sold that nice bike for $300
"My wife is a light sleeper, I really need the 341s, when she gets woke up too early she's a real b_tch all day"
"We just had a new baby and she's a light sleeper, I need the 341s"
"My dog has cancer in her throat and loud noise gets her barking then she bleeds from her mouth"
"my neighbor is crazy I had to buy an electric lawn mower, he hates loud noise and just got back from Afganistan"
get creative and get the 341s dude
« Reply #22 on: November 20, 2011, 08:10:26 PM »
Agreed, you need to get the 341's. Remember, you can sell the exhaust currently on it on ebay for $300!
« Reply #23 on: November 20, 2011, 08:17:56 PM »
mrjack55, that's a real Nice Honda you have there & I hope you are able to "liberate" that O.E. 4 into 4 exh. for it w/o too much pain from the guy.That rear rack you have on it is a very well made USA beauty;did you know that you can find a backrest that was made for that one? I'm presently seeking one out; I have that same rack for my machine & I had a welder modify it to fit & redesign it a bit so that I can use it to hang some nice hard bags in the future;its Strong.
I purchase a Nice Honda here in E.Pa. that looked like an 8 out of a 10, but a lot of front end damage & consequently the frame is bent.I just moved here a year ago for the first time and what you say about the idea of finding a titled frame being tough is correct.I plan on getting my frame straightened because it is titled.I haven't tried doing a salvage type of thing here in Pa. ...as far as trying to register a spare frame that I have installed temporarily just to ride.I bought that as a roller & a bill of sale only, from NJ. I think frames can be replaced just like any other component,but some places do sure have more RED TAPE in the way to keep you begging for approval. I know I'll be better off fixing my frame.
Offline MoMo
« Reply #24 on: November 20, 2011, 08:46:13 PM »
Jack,  I worked at Montgomeryville Cycle and Riff's back in the day.  It was perfectly legal to replace a frame and stamp in the original numbers. To me, it follows that you could buy any frame, restamp it with your numbers-you'd still have your survivor but with a replaced frame. .. Larry
