Author Topic: 14mm Master Cylinder for a 350F?  (Read 774 times)
Offline veloracermike
« on: November 24, 2011, 07:36:32 AM »
Is a 14mm front brake master cylinder sufficient for a 350F?  I think the stock size is 16mm.
Thanks
MH
Offline fmctm1sw
Re: 14mm Master Cylinder for a 350F?
« Reply #1 on: November 24, 2011, 07:59:51 AM »
I'm pretty sure I have 14mm pistons in all my bikes.  I posted a thread a while back when I ordered the wrong one.  Title is "how not to mess up buying a master cylinder rebuild kit" or the like...
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline d9canada
« Reply #2 on: November 24, 2011, 08:02:48 AM »
In answer to your question, I am not sure about the master you are thinking about using.  But I have two options for you.
First, I did see an original for sale on FleeBay the other day if you are interested. I think the seller is mikescp or something similar from Salem OR and the part may have been at his store.  The problem is that this sort of parts accumulation is very pricey by the time you ship each little bit.  Plus you have to bet that you can get it apart, rebuild it and make it work.
Another alternative is what I am doing.  I'm putting a whole 550 front end on with tapered rollers in the steering head.  The forks are 35mm and more sturdy. And I'm twinning the disks up front.  I know it's not true to original but other than the twin disks and aftermarket headlight ears, it will be pretty close.
Brian
CB350F to CB900C
GL500
GL1000
CBX
02 Sportster 883
64 Suzuki M15D Sovereign 50cc
