YES! And it was a major pain in the ....
 I have a thread on here somewhere about a hanging idle problem. I had cleaned the carbs multiple times, synched them over and over, had a pro take a look at them, etc., etc.
 Then, one day I pulled a set of parts carbs out of the junk yard. In it were the stock Keihin jets. I immediately noticed a difference.
 Installed the stock Keihin jets and all my issues went away. Not only are the aftermarket jest shorter, but the emulsion holes are in a different pattern and of a different size.
 You can re-use jets. They rarely, if ever, wear out unless someone's been mucking with them. You can use the gaskets, needle valves and O-rings from the rebuilt kits, but I HIGHLY recommend using the factory jets.
