Author Topic: One Kick Wonder - I want my bike to start 1st kick everytime  (Read 7731 times)
Offline chewbacca5000
  • I polish covers!
« on: December 28, 2011, 06:39:58 PM »
I don't know what it is maybe I just got Fonzie envy, but would love it if I could get my 73 CB750 to start 1st kick every time.  Is there anyone who is willing to share their secrets on how to turn my bike into a 1 kick wonder.
Thanks!
DH
Re: One Kick Wonder - I want my bike to start 1st kick everytime
« Reply #1 on: December 28, 2011, 07:28:16 PM »
Completely clean fuel SYSTEM.
NO GAS PISSING CARBS, fuel levels EQUAL and CORRECT in bowls.
Dwell and timing DEAD ON with clean points and good condensers
Known GOOD plugs gapped to spec w/ no deposits
Coils and wires that don't arc/leak, new or tested good plug caps
Fully charged battery
Properly functioning charging system
Compression within spec for ALL 4 cyls.
Valves set to spec and cam chain tensioned correctly
Chokes adjusted in unison to open/close simultaineously
Fresh fuel helps.
My k5 will usually start warm with about 1 revolution of the crank
but that's with the button. The starter turns so briefly, you really
have to listen for it. What you're asking for is possible, but more likely to happen with a warm engine. just my .02
PS.....cleaning ALL electrical connectors of the entire bike's wiring
goes a long way in ensuring good voltage to everything, which includes/benefits the ignition system.
« Last Edit: December 28, 2011, 07:46:08 PM by DH »
72500john
« Reply #2 on: December 28, 2011, 07:34:35 PM »
dang..sounds like the quest for the holy grail!! dont expect too much in cold weather though..these things are not that freindly. but after warmed up mine starts like a dream. good luck!!
« Reply #3 on: December 28, 2011, 07:42:49 PM »
Kick,what is Kick---"We don't need know stinkin' kickers"----  :D
  • I polish covers!
« Reply #4 on: December 28, 2011, 07:48:33 PM »
No in Syracuse we get a good taste of cold so I am thinking  the grail hunt is on!  I guess all the guys out there who say their CB750 starts first kick every time are full of it.
ekpent,  LOL we don't need no stinking kickers.
Offline BeSeeingYou
« Reply #5 on: December 28, 2011, 08:04:31 PM »
My F1 will start on the first or second kick every time.  It's a low mileage bike with a spotless fuel system and I keep it in a good state of tune.  Running original points ignition. That one started on the third kick after a 25 year slumber.  My 79 XS with high miles can take 5 or 7 kicks sometimes more.  I suspect the compression is a bit below specs and maybe needs a thorough going over.
On the other hand I picked up a rough low mileage 75 XS650 last plated in 1990 that started on the third kick and on the first kick after that till I disassembled it. ;D  How hard can it be?  Three seems to be the magic number. ;)
« Last Edit: December 28, 2011, 10:55:34 PM by srust58 »
Offline rbmgf7
  • 2>4
« Reply #6 on: December 28, 2011, 09:01:20 PM »
Ether.
Offline Steven.Burns
  • Beer and Bikes
« Reply #7 on: December 28, 2011, 09:07:35 PM »
Today I was screwing around with my bike and I had a low battery do I reached for the kick start with my hand  and put all my weight into it and she started up 1st kick (well push with hand) but the bike was somewhat warm still  ;D
usually starts within 1-3 kicks though!!
1978 CB750F3 -Scrambler/ tracker or something of the sort  http://forums.sohc4.net/index.php?topic=97025.msg1083788#msg1083788
Offline w1sa
« Reply #8 on: December 28, 2011, 09:43:39 PM »
I agree with the three kick rule....... after all it normally takes 1 to 2 kicks on a dead cold engine for it to be breathing air and fuel (with or without choke).......turn the key and fire on the third.....always puts a smile on my face.... :D
Offline cameron
« Reply #9 on: December 28, 2011, 11:21:33 PM »
1) obv, good tuning.
2) AGM Battery
3) a 'primer kick' or two with the key off. . .like w1sa mentions.
1976 CB550F
« Reply #10 on: December 28, 2011, 11:26:33 PM »
She starts on the first kick when warm.  Didn't try it cold yet.  I have Pamco and hotter coils, never had her really running with points.
Offline Deltarider
  • I'm back
« Reply #11 on: December 28, 2011, 11:45:32 PM »
Ride it everyday.
CB500K2-ED Excel black
  • I polish covers!
« Reply #12 on: December 29, 2011, 06:04:46 AM »
Ok, from what I am hearing unless your bike it in perfect tune it's going to take 1 or 2 primer kicks or twist if carbs are equipped with accelerator pump to get the bike to start on first kick cold.
  • I polish covers!
« Reply #13 on: December 29, 2011, 06:09:08 AM »
Can you try to kick it over cold and see if it starts with one big Fonzie style kick?  Would love to know if the Ultimate Pamco can turn a CB750 into a 1 kick Wonder.  From what everyone here is saying primer kicks or throttle twist with accelerator are necessary.  Give it a go and report back to us.
Offline phil71
« Reply #14 on: December 29, 2011, 12:47:06 PM »
my bike starts with 0 kicks.
  • I polish covers!
« Reply #15 on: December 29, 2011, 07:22:40 PM »
Phil you must be the SOHC master.  Best answer yet.  Bet you just will it to start, or it starts on it's own like a Honda version of Christine.  Just not the same without the radio playing those erie old tunes though.
Offline bjatwood
  • I never claimed to be an
  • 1973 CB750-K3
    • Minbikers Proboards
« Reply #16 on: December 29, 2011, 07:37:25 PM »
My K3 will start with a push of a button everytime! I have kick started it, but at 50+ in age...I don't digg that coolness much  ;)
Brian
#24193
I believe that the Finest things are the most thoughtfully made, not the most expensive!
http://minibikers.proboards.com/
  • I polish covers!
« Reply #17 on: December 29, 2011, 08:30:12 PM »
Yeah I hear what your saying and I am only pushing 40.  Watching me try to kick over my cb750 is like watching a six week old puppy take a trip to the Christmas tree farm.
« Reply #18 on: December 29, 2011, 09:03:01 PM »
who ever has owned an old xr600 or tt500/600?they should be the guys wanting a first kick starting engine,i had a mid 80s xr600,rode it to the shops,then it wouldnt start,,kick kick #$%*en kick,choke on/off fuel tap on/off,,the pulser coil had died.
Offline Kong
« Reply #19 on: December 29, 2011, 09:18:52 PM »
Every honda-4 I'ev ever owned or ever know of that was kept in a good state of tune started on first kick every time.  There is no secrete to it, just keep it tuned right and use the choke.
2002 FXSTD/I  Softail Deuce
2001 Acura (Honda) CL Type-S
1986 Honda Rebel, 450
1978 Honda CB550K
1977 Honda CB550K
« Reply #20 on: December 29, 2011, 09:33:33 PM »
 Acellerator pump helps.. leaking intake tubes will make it harder.
 The one I am riding now has a tired original motor, 3 yr old points, year old plugs,  still can start with 1 kick in 30 degree weather, if I charge the sworeout battery...
« Reply #21 on: December 30, 2011, 12:06:37 AM »
youve never had a big single thumper kong?only their actual owners can start them,hot or cold,if you swap rides it wont start for the non owner,swap it back and it starts first prod of the kicker.
« Reply #22 on: December 30, 2011, 09:56:15 AM »
big singles and twins, need technique, fours just need movement.. a lot can be started by hand.. even H-Ds
« Reply #23 on: December 30, 2011, 02:51:09 PM »
Thanks!
Install my Ignition, and pull the choke closed if cold. Works for me... :)
Offline fayettebr
« Reply #24 on: December 30, 2011, 06:00:56 PM »
I've got a '72 motor so I have to kick. The po swapped to PD carbs. It's a first kick starter hot/cold and needs very little choke.......but I'm currently working to find the cause  of the engine missing at 3500 rpm and up....so in my case 1st kick does not= run good!
