Author Topic: CB 750 Handle Bars Help  (Read 4657 times)
Offline hondaluv
« on: January 27, 2012, 10:16:56 AM »
I am a newbie to the Honda world after many years of BMW and need help!
Now I have a 1974 CB 750 which I like with one exception, the handle bars. I am not used to the high bars on the US version as I am used to the flat bars of my BMW's. I have seen pictures of European CB750's and they have a lower flat bar.
Can I fit the European bars and if so where can I get them and do I need to change the cables to fit the lower bars?
Thanks
Offline fishslayeryo
Re: CB 750 Handle Bars Help
« Reply #1 on: January 27, 2012, 10:34:22 AM »
Howdy and welcome! There's alot of gents out here with a ton of knowledge...I'm just spitting out what I've learned from reading around here. For bars think they were lower in europe and Japan. I got a set of superbike bars, suits me better. Most you have to cut the holes for the wiring, etc. Got mine from Z1 for 15bucks, link below. Don't think you need to worry about shortening your wires, maybe just the brakehose I'm not sure about, if so there's a gent who does sweet stainless lines, which I have...but my bikes down to a frame rt now:)
http://www.z1enterprises.com
Regards,
Yo Han
'71 CB750 K1...work in progress:)
Budget Build: http://forums.sohc4.net/index.php?topic=100525.0
Fishing is much more than fish. It is the great occasion when we may return to the fine simplicity of our forefathers.  ~Herbert Hoover
« Reply #2 on: January 27, 2012, 10:36:24 AM »
Link to brake lines...he'll make them any length you want and already knows the correct lengths for superbike bars etc.
http://slingshot-cycles.com/
~Yo Han
Offline hondaluv
« Reply #3 on: January 31, 2012, 02:58:26 PM »
Thanks, I looked at the Z1 web site and they have exactly what I was looking for.Now I can also sort out the brake line issue too.
Stephen
Offline Bankerdanny
  • Endeavor to persevere
« Reply #4 on: January 31, 2012, 03:59:33 PM »
Easily. I put them on my 550. Bikemaster GP Touring.
Offline Danno
« Reply #5 on: February 01, 2012, 01:56:53 AM »
euro bars or beach bars as they are called in the states sometimes they are also called drag bars
my 74 550 came with them and I hear you about the higher bars I can't stand them either
Offline bikerbart
« Reply #6 on: February 01, 2012, 03:43:42 PM »
Thats the first thing to go for most of us,I put "M' bars on mine
Offline dhall57
« Reply #7 on: February 01, 2012, 04:08:36 PM »
These are the bars that the PO but on my KO. I like them,  it gives the bike a sporty feel. But Im sure I'll go back to the factory bars sooner or later.
1970 CB750KO
1971 CB500KO-project bike
1973 CB350G- project bike
1974 CB750K4-project bike
1974 CB750K4
1976 CB750K6
1977 GL1000
1997 Harley Wideglide
Offline Really?
« Reply #8 on: February 01, 2012, 07:34:47 PM »
To make the holes in the bars, use three note cards.  Tape them around the bar ends and in the center.  Mark the top so you have an idea of the top center.  You can punch, cut or mark the holes, move them to the new bars and mark and drill and/or grind out the holes.  Camfer the edges so you do not cut the wires.  You might use a blow dryer to soften the tubing a bit when you pull the wires through.  I oblonged the holes for the pin on each controller.  It allowed me to rotate the controllers a bit so I can even them out.  Do not use the controller to pull the wires out of the old bar if you don't have to, unless you want to fix it later. All of the extra wire I stuffed in the headlight.  The end on the MC might hit the tach or come real close.
The Wife's Bike - 750K5
The Kid's Bike - 750K3
« Reply #9 on: February 01, 2012, 08:26:24 PM »
"Superbike" bars here too. You may be able to use existing cables by rerouting.
Offline lucky
« Reply #10 on: February 01, 2012, 09:00:05 PM »
Thanks
Go to Cycle Exchange and order their Superbike bars. They are between the stock bars and the clip ons. They only have about a 2.5 inch rise.
Moderate bars.
