Author Topic: Gas tank ? 550  (Read 1162 times)
Offline messeduptriple
Gas tank ? 550
« on: February 02, 2012, 07:32:33 AM »
I need to take the cap off for powdercoating. What is the easiest way to get that pin out? Or that rubber circle under the cap..I think I just need to get that out. If I take that pin out what kind of pin is that and how do I get it back in???
76 550
Thanks
Sent from my PC36100 using Tapatalk
Offline toytuff
  • "watching the pinheads"
Re: Gas tank ? 550
« Reply #1 on: February 02, 2012, 07:42:41 AM »
If you look inside the cap behing the gasket you will see four (4) star shaped clips. Use a angled pick and it will work out.
As far as the pin I'll wait for replies as I have wondered about this also.
tt
Re: Gas tank ? 550
« Reply #2 on: February 02, 2012, 07:50:52 AM »
You mean bend them out?? How will I reinstall it...will it be a pain??
Offline toytuff
Re: Gas tank ? 550
« Reply #3 on: February 02, 2012, 08:27:03 AM »
There like a spring clamp. they will fight you, trust me. Wedge one up, put a small screw driver in there, wedge another one. I have done two (2). Both fought me but I won.  ;)
tt
Re: Re: Gas tank ? 550
« Reply #4 on: February 02, 2012, 09:50:22 AM »
tt
nice!
Reinstalling??
Offline mjstone
  • I'm definitly not a
Re: Gas tank ? 550
« Reply #5 on: February 02, 2012, 10:00:19 AM »
The  pin is a long rivet.  Some have driven them out, but you have to be careful not to bend the tabs.  Others have carefully drilled them out.  You would have to replace the rivet if you drill it out, but might be able to reuse the rivet if its driven out.  Hondaman offers a stainless bolt and acorn nut kit to replace the rivet.
MJ
1972 CB500Four (Honda)
1973 CB500Four (Oliver)
Re: Gas tank ? 550
« Reply #6 on: February 02, 2012, 03:05:05 PM »
I'm wondering if I just try to take out the rubber part and say f it! ? What does that rubber part do? Will I need to replace it or what's its purpose?? Just curious if I can cut a corner and not replace that.
Offline mjstone
Re: Gas tank ? 550
« Reply #7 on: February 02, 2012, 05:29:19 PM »
The rubber part is your caps gasket.  It keeps the gasoline from leaking out of your tank.  You need it and it should be in good condition.  If it is cracked you need to replace it with a new one.  Pry out the part that toytuff told you to, its easy to get out and pops right back in.
MJ
Re: Gas tank ? 550
« Reply #8 on: February 02, 2012, 09:31:38 PM »
Got it out! Thanks guys!
