Author Topic: Front Fork Bearing Kit?  (Read 1554 times)
Offline tonymasone
« on: March 14, 2012, 05:27:56 AM »
I just removed my triple tree for powder coating and I'm looking for a kit that has new bearings or a different type of bearing for stock configuration.
Thanks!
74' CB750
bollingball
Re: Front Fork Bearing Kit?
« Reply #1 on: March 14, 2012, 06:03:51 AM »
http://www.cyclexchange.net/Frame%20Page.htm
These can be bought from many places. Shop around
Ken
Offline CycleRanger
  • No comment about being an
« Reply #2 on: March 14, 2012, 06:58:28 AM »
Thanks!
Check out the tapered bearing kit from http://www.allballsracing.com/.
Many, many of us have installed them with no issues.
Offline Tugboat
  • Puppet
    • PseudoMoto
« Reply #3 on: March 14, 2012, 07:56:26 AM »
+1 All Balls is great
Offline tonymasone
« Reply #4 on: March 14, 2012, 12:28:51 PM »
Ken
These neck bearings, how are they installed? Do they have to be pressed in?
74' CB750
bollingball
« Reply #5 on: March 14, 2012, 12:43:11 PM »
Start with reading this.
http://forums.sohc4.net/index.php?topic=1516.125
There are a lot of post here on this site Look at FAQ and tips and tricks
Ken
Offline nancy
  • CB750 K2'ish - SOLD!! Triumph Sprint GT2011
  • No worries matey..
« Reply #6 on: March 14, 2012, 12:54:32 PM »
New tapered headstock bearings are well covered on this site on various articles, inclusive of pics.
In answer to your Q. = bearings are easily installed with aid of mallet and suitable sized drift - such as the old bearing casing. There will be a subtle size change from the stock balls...meaning a gap of about 2mm at the fork ear base...unless you do something tricky to sort that out. I didn't, but he gap is not noticeable excet to purist.
Note - the top of the tree doesn't have a deep recess - so the new tapered part sits up proud.
All old bearing parts can be worked out with drift. Putting bearings into freezer and tree into pie warmer may help to install. Get quality bearing grease and use it plenty. Don't be tempted to bash on the new bearing at all.
When tightening up - do the 1st retaining nut up to hand tightness. DON"T crank it up with a socket or wrench. Although...you can crank it down to begin with..just to seat the bearing - but not too hard - pressure on the bearing is not good for it...loosen it back off and retighten by hand...The top chrome nut does all the holding down - torque that one down. Test the bars fall freely form centre point to left and then right. Don't tighten everything up 1st time...as you will likely go back and adjust the locking nut to loosen or tighten some more. I put on a leather glove to tighten..and finally used a hammer and chisel to "tap" another 1/16 turn to get it just right....once I had the bars etc all back on.
Needs to be rechecked after 1st few rides. Likely might need a tighten after 200 miles or so. Easily done without a teardown...just crank up the front offf the ground, remove bar mount and loosen all 4 tree bolts and stem bolt to allow you to TAP the top tree up with a soft mallet to get access to the retaining nut.
Regards
Mark
