Author Topic: CB750 K0 Leak after rebuild - ***Solved! I think***  (Read 12607 times)
Offline Simpson
  • I ain't no
  • Aged to perfection
Re: CB750 K0 Leak after rebuild - solved I think
« Reply #50 on: April 22, 2013, 06:55:11 PM »
So I just got my top end put together.
Without starting the engine, just turning the engine over getting oil back into the system I have this oil leak.
The only possible scenario I can think of is a problem with the puck seals.
Does that sound right?
1970 CB750 K0
1975 CL/CB 360 Mix
Offline Simpson
  • I ain't no
« Reply #51 on: April 22, 2013, 07:00:26 PM »
So finally I got the motivation to pull the engine out yesterday. Turns out the bolts that go though the center pucks under the cam towers were a shade under torque. The other end of the hole dumps into the cylinder center air cooling passage. I simply tightened them up and reassembled. So far no leak.
1970 CB750 K0
1975 CL/CB 360 Mix
Offline Simpson
  • I ain't no
Re: CB750 K0 Leak after rebuild - ***Solved! I think***
« Reply #52 on: April 30, 2013, 06:08:45 PM »
Well, still no leak and I'm dancing!  :)
1970 CB750 K0
1975 CL/CB 360 Mix
« Reply #53 on: May 01, 2013, 05:28:46 AM »
Well done! Its a great feeling when you think you have eliminated all the leaks  -I hope it lasts for you!
Offline Simpson
  • I ain't no
« Reply #54 on: May 01, 2013, 04:51:44 PM »
I've been so excited, been furiously cleaning the engine since. Now that the oil residue is not attracting dirt it looks darn sparkly. Wife says I'm obsessing. i say sfter being haunted with leaks for a few years now, it's a well deserved choir I enjoy.
1970 CB750 K0
1975 CL/CB 360 Mix
« Reply #55 on: May 01, 2013, 05:18:32 PM »
I can relate to that. I dream of a leak free bike!
« Reply #56 on: May 01, 2013, 06:06:06 PM »
Me too. ::) ;) ;D
Offline Simpson
  • I ain't no
« Reply #57 on: May 02, 2013, 08:31:31 AM »
Me too. ::) ;) ;D
BTW Mike, this head went to you last year after a port and valve job. Just like to report all is good!
1970 CB750 K0
1975 CL/CB 360 Mix
