Author Topic: effort required to kickstart a 1973 cb500  (Read 1904 times)
Offline phaedrus314
« on: June 03, 2012, 01:01:50 AM »
Hi all and thanks in advance.
I realize this is a very subjective question but how would you categorize the amount of effort to kickstart a 73 cb500?  I ask because I just looked at a 72 cb350 twin and noticed that it required noticeable more effort to kick over than my 500 does.
Is an easy kickstart an indication of any problems?  Low compression (bike starts easily but haven't had it out on the road yet and didn't compression test as it started easily and seems to run well...)
Offline LesterPiglet
  • 1977 CB550F2
Re: effort required to kickstart a 1973 cb500
« Reply #1 on: June 03, 2012, 01:05:41 AM »
The more cylinders the engine has the easier it is to kick.
« Reply #2 on: June 03, 2012, 01:09:35 AM »
one quarter of a 500 is 125 thats under compression at any one time,,one half of 350 isnt much more,,the kicker gearing probably comes into play and the compression ratio of the 350 twin may be higher?they have a domed piston.
Offline phaedrus314
« Reply #3 on: June 03, 2012, 11:50:56 AM »
Ok, so would you consider the kick effort on a cb500 to be easy?  I am 5'9, 155ish and was surprised at how easy it was the first time i tried it.
Offline strynboen
« Reply #4 on: June 03, 2012, 11:58:52 AM »
500 and 550 can be kickt of a 90 years women..they just vant to start.....if all teknik are ok..
honda 550 1978 k3
« Last Edit: June 03, 2012, 12:02:12 PM by strynboen »
i hate all this v-w.... vords
« Reply #5 on: June 03, 2012, 12:15:35 PM »
ive started them by hand for a laugh.
Offline tory b
« Reply #6 on: June 03, 2012, 01:14:29 PM »
   Untell I realized the black powder coated bars on my 500 where causing my lack of electric start,I kicked it for a year.Even by hand.My 100 lbs 13 year old son could start it no problem.
1975 CB400F
1973 CB500
1982 CB900F
1983 GL1100 W/Vetter sidecar
www.vintagericeburners.com
Offline xsmooth69x
« Reply #7 on: June 03, 2012, 01:33:07 PM »
I can kick strategy mine just using "the force"  thanks yoda
1975 CB550 (FINISHED?!?!?)
Offline Gordon
  • 750K1, 550K2
« Reply #8 on: June 03, 2012, 02:03:44 PM »
I have to be careful in the garage.  If I fart near my 550 it will kick-start! ;D
Okay, so it's not actually that easy, but if it's a hot day or the engine is already warm it's usually running before I reach the bottom of the kick.
Offline phaedrus314
« Reply #9 on: June 03, 2012, 05:36:26 PM »
Thanks all.
