Author Topic: Torque, torque....SNAP!!  (Read 7941 times)
« on: May 11, 2005, 07:13:41 AM »
Hi all,
Well I got my torque wrench last night from Sears and then rushed home to start torquing down my CB750K2 engine - from the bottom (upturned engine)...it was all going well and I got as far as #12 bolt in the sequence according to the Clymer manual (this is one of the 10mm bolts at the front of the engine  just behind the oil filter) and I had trouble reaching 14.5ft/lb (the low end of the recommended torque value....when as you guessed it...the bolt snapped!! Damn!! So its broken off just at the link between the smooth shaft and the thread so all the threaded part is still in there....
......my question is - I know that I should really separate the cases and have a machine shop drill out the broken shaft and then re-tap the hole with a slightly bigger thread....but what if I just left it as is....there are 6 bolts across the front of the engine and if one is not perfect will it really matter?? Would it leak here given the amount of Hylomar gasket I have there?? Has anyone been here before??? Advice/experience?
Or does anyone know a good machine shop in the Boston area that could reliably do this work??
Thanks for any help with this,
Cheers
Andy
Re: Torque, torque....SNAP!!
« Reply #1 on: May 11, 2005, 07:40:44 AM »
Drill a hole in the stump, and use an Ezee out to remove the broken bolt and buy a new one and it's fixed
Yep- it should spin right out. Once the head breaks off there's no stretch on the bolt.
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #2 on: May 11, 2005, 07:47:19 AM »
Did you lube the bolts with anything?
« Reply #3 on: May 11, 2005, 07:48:36 AM »
Thanks for the replys...do I need to split the cases again? Or can I drill carefully down the hole? :-) What is an Eez out exactly and how does it work? Sorry no experience with it before. Thanks again, Andy
Lumbee
« Reply #4 on: May 11, 2005, 07:49:09 AM »
...sorry to hear that man...I feel u'r pain.  I can't say I have alot of experience with the bottom end, but 2 things to think about.  #1-These mills are pretty durable and its very conceivable that you could get away losing one bolt.  #2-Weigh the time/cost of machining against picking up another motor/case.  Any time I start looking at putting more than a few hundred bucks in one of these motors you have to keep in mind that they are out there, complete for a $100 or less..
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=4548613041&category=35595&sspagename=WDVW
...this one is in NY...not far from u...$35, use the case and keep the rest for parts...
...just my 2 cents... ;D
...lowes/home depot guys can explain the "easy out" to you...basically its a reverse bit.  U drill the middle of the spripped bolt out, then insert the "easy out" bit and back the bolt out...
« Last Edit: May 11, 2005, 07:51:27 AM by Lumbee »
« Reply #5 on: May 11, 2005, 07:49:33 AM »
Bob, the bolts had some grease on them but now Im thinking not enough. Cheers, Andy
Offline Glenn Stauffer
  • Administrator
    • The SOHC/4 Owners Group
« Reply #6 on: May 11, 2005, 07:55:01 AM »
I've also heard of using a reverse twist drill; as it cuts into the bolt, it will often twist the broken off stub out of its hole.  You'd have to go to a machine shop supply place to find one.
Has anyone tried this tool in place of the typical easy-out:
http://www.aldn.com/drillout/
--Glenn
« Reply #7 on: May 11, 2005, 08:16:48 AM »
You MUST  replace that bolt if it is an 8mm thread 12 mm spanner size as they are main bearing bolts. If its a 6mm thread 10mm spanner you will probably get away with leaving iy.
« Reply #8 on: May 11, 2005, 08:30:26 AM »
Its the 6mm thread 10mm bolt that got snapped :-( Thanks for the feedback. I think Im going to try and get it with the Ezee out as suggested. Thanks for the feedback. Cheers Andy
gerstle
« Reply #9 on: May 11, 2005, 09:49:19 AM »
beware the ez out!  When everything is good with an ez out, it's good.  When it hits the fan with an ez out (like it snaps in 2), it really hits the fan.  You can't drill through an ez out.  I've had an ez out break off when i didn't think i was putting too much pressure on it, and i know plenty of others that have had similar problems.  Take your time and be patient, if you feel like you're pushing it and not getting any where, stop.
« Reply #10 on: May 11, 2005, 10:15:37 AM »
Thats good advice! thank you!
Cheers
Andy
Offline frostypuck
« Reply #11 on: May 11, 2005, 01:18:39 PM »
I have the reverse drill bits, and am willing to bring them to Andy's to try to fix his broken bolt issue, but, the way I look at it, if the bolt shank is 6mm, and I have to drill out half of it anyway, why not just drill it out and then run my M6 tap thru the remainder. I have also snapped eez-e outs, and my reverse drill bits haven't done 100% great job in the past. Espescially thinking that the bolt may be cross threaded, hence the reason for it not making it to torque.
Thoughts?
Chris (Andy's amatuer mechanic) in Boston
Boston, MA, USA
Offline Einyodeler
  • Midnight bugs taste best!!!
1972 CB500 - 1973 CB500 - 1974 CB550K - 1975 CB550F - 1975 CB750F - 1976 CJ360 - 1983 CR480 - 1970 BSA A65T Thunderbolt
Download Motorcycle Shop Manuals here: http://forums.sohc4.net/index.php?topic=17788.0
« Reply #13 on: May 11, 2005, 05:38:03 PM »
14.5 lbs is way to much for a 6mm fastner- more like 7 or 8lbs. It isn't stripped (I hope) just overtorqued. Andy, I'll give you a hand.
Offline kghost
« Reply #14 on: May 11, 2005, 06:14:55 PM »
Yeah, I think he torqued the front bolt I.E. the 10 mm on the front of the engine not the 6 mm on the case halves.
Thats just a bummer, Check all the rest of your fasteners if you think you have a problem. Check the thread portions with a magnifing glass for cracks.
Stranger in a strange land
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #15 on: May 11, 2005, 06:22:17 PM »
Helpful reference to torque values..
http://www.salocal.com/sohc/tech/torquetable.htm
« Reply #16 on: May 12, 2005, 02:54:47 AM »
Just rememberthat when the manual says "Torque the 10mm bolt........." they mean the diameter of the bolts "shaft", not it's "Head". No amount of grease is gonna stop you busting a bolt by over-torqueing it.
Easy-out's suck, and for a 6mm dia screw, if you can't just wind it out you'll probably need to drill the whole thing out and "helicoil" the hole. Cheers, Terry. 8)
« Reply #17 on: May 12, 2005, 06:31:48 AM »
Thanks for all the help and links guys - much appreciated. I had a good look at the bollt last night and  realise now that Ill probably have split the cases again - just hope I can rescue the alternator gasket. Ill have another go this weekend and let you know progress. I leave for Nagoya, Japan next weekend for a 2 month work trip so my time on this is limited :-( If I can just get the engine torqued down and back in the frame Ill be happy :-)
Andy
P.S. I had no idea about different torque settings for the different size bolts - the Clymer manual dosent specifiy this (at least I didnt see it) - it has a photo of the bottom of the engine with torque settings 14.5 - 18.5ft/lb printed in the bottom...I just assumed...oh well live and learn!
Mikeshonda750F
« Reply #18 on: May 12, 2005, 04:33:04 PM »
As with anything, paticence pays in the end. Though the correct torque spec is probably not 12-18lbs, an automotive grade 6mm or 8mm bolt is plenty capable of withstanding 18ft/lbs (Look at torque specs for any modern oil pan (car)... 6-8mm.. usually 18-22lbs).
Most problems with ez-outs comes from not enough of a hole for the bit to square up in the metal causing it to cock sideways and snap off. The #1most important thing to consider when buying an ez-out set is name brand quality. Most people buy a cheapy autozone set and have problems.. get yourself a good quality set... even a sears set would be better than an off brand cheapy set. That said, a left handed drill bit would probably be your best bet. An ezout has left handed flutes that spiral down the shaft, so as you spin it to the left (turning your broken bolt out) the flutes run down the drilled hole and the taper eventually bites in. A left handed drill bit is similar in design, except it is not tapered so it wont wedge itself in the hole and back the bolt out.
I would try a left handed drill bit at a fairly slow speed. Good luck!!
« Reply #19 on: May 12, 2005, 06:31:40 PM »
I agree with the ezout passage but there is no way a 6mm fastner (even marked "9") will survive an18lb pull. If it does it is strecthed to beyond any standards. There is a BIG difference betweem 6mm and
 8mm fastner torque values. I don't want to start a slinging contest but I do know what is correct. :-\
Offline Bill Vaughan
« Reply #20 on: May 12, 2005, 08:59:20 PM »
The warnings about EZ-outs are absolutely on target - when they work, they're great; when they break, you're worse off than you were to start.
For what it's worth, I've had good luck with the Micro Power Extractor Set from Sears (Model 52157).  Same principle as an EZ-out, but a bit finer thread for more bite.  The correct size drill bit is built into the other end.  The set cost about $40.00.
1972 Z50A
1973 ST90
1975 CL360
1971 CB450
1975 CB550
1978 FLH
2003 FLSTS
2006 FLHRSI
Spear
« Reply #21 on: May 13, 2005, 12:04:29 AM »
Talk, talk ..... SLAP!!  Better known as 'contact counselling' for a woman who never shuts up!  ;)
Offline cb650
« Reply #22 on: May 13, 2005, 03:33:20 PM »
Somethin we do at work is if there is a little bit of the bolt still up is put a bigger nut over it and weld them together. Also if drilling out a bolt use a left hand drill.
                      Terry
screwtheman
« Reply #23 on: May 15, 2005, 11:04:08 AM »
Unbelievably, I did the same exact thing last night! Even after having read this thread!!  ::)
It's true, the shop manual basically reads like those smaller bolts should torque at the same reading as the crankshaft bearing bolts. But they do not!! BTW, I got it out with an EZ-Out in about 5 minutes. Watch those shavings from drilling!
Offline kghost
« Reply #24 on: May 15, 2005, 02:12:27 PM »
You gonna change your name to just Screwed? ;D
