Author Topic: Anyone had to loctite Transmission bearing CB 750 ?  (Read 1132 times)
« on: July 11, 2012, 06:58:46 AM »
 The bearing in the case below the clutch, right countershaft bearing is loose in a case I have. its the opposite end of the shaft you take the bearing holder off of when you split the cases.. Anyone had to loctite or fix one before ?
Offline lucky
Re: Anyone had to loctite Transmission bearing CB 750 ?
« Reply #1 on: July 11, 2012, 01:44:31 PM »
Doesn't it have a locating pin in the bottom half of the case for the bearing??
If not red Loctite should do the job.
Offline Nikkisixx
« Reply #2 on: May 02, 2013, 07:06:19 PM »
Cough Cough - why is this post dusty?
I have run into the same issue. The bearing that drives into the lower case, next to the shifter drum, is loose.  I can slip it in with my grubby little fingers.  Bearing measures 47mm on the nose and the old bearing required a slide hammer to remove.
754 it has been over a year, did locktite work? I am considering installing with locktite and peening a couple of spots.
« Reply #3 on: May 03, 2013, 12:12:22 AM »
I never ended using that case yet. Red loctite will hold. I was just wondering if it happened often.
