Author Topic: torque spec for front axle holding screws?  (Read 10356 times)
Offline Mingo
« on: August 09, 2012, 05:26:26 PM »
I can find the spec for the axle holding nut in the manual, but not for the four vertical screws that hold the axle in place. What are those torqued to?
Also, the little arrows on the two pieces that bolt onto the bottom of the forks, and hold the axle on--those arrow go towards the front of the bike, right? That would make sense, but then I'm wondering if they might indicate the direction of the wheel's turning, which would be the opposite way.
Offline CycleRanger
  • No comment about being an
Re: torque spec for front axle holding screws?
« Reply #1 on: August 09, 2012, 05:43:24 PM »
Not sure about the exact torque but the caps should oriented like so:
Offline Mingo
« Reply #2 on: August 09, 2012, 05:56:19 PM »
Thanks. That's helpful, especially the "gap at rear" part. But what are the torque specs. Seems like this would be pretty important.
Offline RFogelsong
« Reply #3 on: August 09, 2012, 06:54:39 PM »
This past summer when I replaced the front tire on my 550 my friend who helped had a manual of some sort for a 750 that said 25 ft-lbs.  That's what we torqued them to and it's been fine since.  Someone else can give a more definitive answer (maybe with a source, and this is going from memory), but at least it's a starting point
« Last Edit: August 09, 2012, 07:07:25 PM by RFogelsong »
-Rob
Hondas past/present:
SOHC1:'74 CB125, '78 XL125
DOHC2:'71 CB450K
SOHC4:'73 350F, '75 400F, '75 550K
DOHC4:'81 900F, '01 1100XX
V4:'85 VF1000R, '86 VF500F, '08 VFR800
Offline jtb
  • An unlikely
« Reply #4 on: August 09, 2012, 07:02:20 PM »
They're 8mm studs, I'd torque em to the manual spec for 8mm bolt/nut on page 1-4 of the manual, 13 to 18.1 ft lbs.
1977 CB750F
1985 V65 Sabre
Offline onepieceatatime
1965 CA77
1972 CB750K Ol' Sarge
1974 CB450K7
1977 CB750K7
1977 CB750K7
1980 CB650C
1982 CM450A
1997 GL1500SE
Online scottly
« Reply #6 on: August 09, 2012, 08:20:10 PM »
Tighten the front nut first, so the closed end is solidly butted up against the bottom of the fork leg.
Offline SohRon
« Reply #7 on: August 10, 2012, 06:28:38 AM »
+1
Those arrows should point to the front when properly installed. Others have tried to convince us that the gap should face the front, but I think those little arrows are a pretty definitive indication that Honda wanted it oriented to the rear.
If you don't have it, get a Honda manual. All of these torque specs are available there.
« Last Edit: August 10, 2012, 06:47:34 AM by SohRon »
Offline CycleRanger
« Reply #8 on: August 10, 2012, 06:42:33 AM »
Heh, I think the multiple illustrations from multiple Honda manuals are also a pretty definitive indication that Honda wanted the gap oriented to the rear regardless of what the "others" say... ;)
Offline SohRon
« Reply #9 on: August 10, 2012, 07:00:43 AM »
Me, too, but it's hard to fly in the face of authority and hands-on experience. I suspect Honda tried the gap front position as a short-term experiment that was quickly abandoned for the "correct" orientation. No photo or drawing I've ever seen from Honda shows the gap in front; all have it at the rear.
Offline liPPy
  • 1978 cb750k
« Reply #10 on: August 10, 2012, 07:21:31 AM »
This has been discussed before :) HondaMan says the gap should be at the FRONT not the back. See this thread on the subject back in 2009:
http://forums.sohc4.net/index.php?topic=61497.0
Not again...  :o
When I started as a honda mechanic, circa 1969, I was assigned for the first 3 months to be the Assembler of new bikes out of their crates (it was a shop tradition, to teach you about the bikes). ALL of the Hondas came with the gaps in the front, despite what the various manuals said, straight from the factories. It was a point on the cheklist, done by the shop manager, after the assembly. I did get it wrong on a few at first, and was reprimanded, so it was always easy to remember after that.
A mechanical stress analysis will show that the forces involved in a bump incident will enter the rear stud with far less shear (i.e., strees vector enters at an angle) if the faces meet flat. In real life, the studs are so big that I doubt anyone would ever shear one off: I once changed oil on a California rider's bike (at our Illinois shop) who was on a cross-country two, two-up, and one of the nuts on the front cap was missing altogether! There was no damage, and he never noticed until I pointed it out and sold him a nut and the two washers. It was bolted flush on the back side, front one missing.
Popcorn anybody?  ;)
Offline SohRon
« Reply #11 on: August 10, 2012, 07:29:37 AM »
It's already been discussed.
« Last Edit: August 10, 2012, 07:32:45 AM by SohRon »
Offline CycleRanger
« Reply #12 on: August 10, 2012, 07:33:03 AM »
Popcorn anybody?  ;)
Regardless, the later, perhaps revised, documented procedure is to install with the gaps to the rear. ;)
I'd like to see the setup guide for the early 750K.  Anyone have it?  Hino?
Offline SohRon
« Reply #13 on: August 10, 2012, 07:49:15 AM »
Popcorn anybody?  ;)
+1  The whole bike was an experiment.
Offline LesterPiglet
  • 1977 CB550F2
« Reply #14 on: August 10, 2012, 08:56:00 AM »
I think just use common sense tightening those nuts, unless you are hamfisted. Never used a torque wrench on them yet.
Offline lucky
« Reply #15 on: August 10, 2012, 09:09:21 AM »
Thats what I did. Seemed right. I also used blue Locktite.
Offline lucky
« Reply #16 on: August 10, 2012, 09:12:00 AM »
My 1978 had dots punched in the casting that lined up.
Offline paulmac
  • Keep the shiny side up.
« Reply #17 on: August 10, 2012, 08:52:58 PM »
Front axle holding nut torque settings are: 13 - 16.6 lbs-ft. and the gap is at the rear of the fork.
