Author Topic: How pitted is TOO pitted?  (Read 6164 times)
Offline jstfkndi
« on: August 23, 2012, 07:23:26 AM »
So I have been working on the front brake of my CB350F and finally decided to put a new caliper seal in it. When pulling out the piston, a friend of mine asked me how it looked and said if it was pitted, it would not be good to use. It seems ok, but there is light pitting. So hom much pitting is too much? I am trying to get some pics up soon for any answers. Maybe someone has used some that were worse and it turned out ok?? New piston is about $94...and that is if I can find one!!
Offline jstfkndi
Re: How pitted is TOO pitted?
« Reply #1 on: August 23, 2012, 07:26:23 AM »
Here is the worst of it.
Offline iron_worker
« Reply #2 on: August 23, 2012, 07:34:56 AM »
#7 From the link below is 44 Euro ($55). You'd have to pay shipping but I think it would be a bit cheaper overall.
http://www.cmsnl.com/honda-cb350f-four-germany_model14635/partslist/F06.html#results
I don't think I'd use it. Looks like if the seal sits on the pitting it will definitely leak. You really want your front brakes to be working properly!   :o
IW
Offline Magilla
  • My bike: 1976 CB750F
« Reply #3 on: August 23, 2012, 07:48:24 AM »
How well did it work before you started to "fix" it?
1972   Honda CB350
1972   Yamaha 500
1982   Yamaha 650
1988   Harley Sportster 883
1983   HD FXR Shovelhead
2003   HD Heritage Softail
2006   Victory Vegas Jackpot
1980   Honda CB650
1976   Honda CB750K
1982   Honda CB750
1964   Honda CA95
1982   Kawasaki 550
1974   Honda CL360
1975   Suzuki GT550
1981   Honda CB750
1981   Honda CB750
1970   Norton Commando
1972   Yamaha U7E
1970   BMW R50/5
1976   Honda CB750F
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #4 on: August 23, 2012, 07:49:23 AM »
Those look deep and not cosmetic. Phenolic may be in your future.
Offline BeSeeingYou
« Reply #5 on: August 23, 2012, 08:56:27 AM »
If you don't want to pay for a new one try this:
Clean with acetone and fill them with JB Weld and then shave off any excess with a thin razor blade that will conform to the curve of the piston.  You have to be very neat and precise but it works for me.
« Last Edit: August 23, 2012, 08:58:10 AM by srust58 »
« Reply #6 on: August 23, 2012, 09:16:30 AM »
Right. The pits occur in the part exposed to the environment. No problem if you're using the old pucks.
The problem comes if you wnat to replace the pucks. Then you'll have to push the piston in to allow room for the new unworn pucks. That will put the pits in the area of the seal, and you'll have problems.
Pistons are readily available and shouldn't cost that much. I just bot some, have one for sale.
« Last Edit: August 23, 2012, 09:18:44 AM by MCRider »
Offline jstfkndi
« Reply #7 on: August 23, 2012, 09:23:12 AM »
They didn't work before. I did a master cylinder rebuild and put new pads in. The piston will compress but will not release. I couldn't see much evidence of leaking, but it is hard to tell because there was grease behind there and it could have mixed with that, but no drippage. I haven't tried it with then new seal yet because I don't want to waste anymore brake fluid (not that it is that expensive, it just freaking gets everywhere). I guess it can't hurt to try it again, but frick man! I turn around and this thing needs a part that they no longer sell anywhere!!
Offline jstfkndi
« Reply #8 on: August 23, 2012, 09:26:47 AM »
Thanks for the link iron worker. I checked it and it will be 77 euro with the shipping, so about what I expected to pay, but at leaast I can get it :) I might as well just give this bike my wallet!
And I am sorry I have not heard of phenolic. What is it?
And would JB Weld stand up to the corrosive properties of the brake fluid? Funny thing is...this is the solution I was thinking of before I asked! That stuff can cure about anything!
« Last Edit: August 23, 2012, 09:29:18 AM by jstfkndi »
« Reply #9 on: August 23, 2012, 09:28:11 AM »
I may have mispoke, CB750 pistons are readily available, maybe not CB350F.
Anyway. Pistons not releasing is 99% of the time a problem with the return hole in the master cylinder being plugged with debris, often from the inside of the hose breaking down. many threads on this problem.
Offline jstfkndi
« Reply #10 on: August 23, 2012, 09:30:53 AM »
I hear you. I am positive I did the master cylinder right and cleaned out everything. The caliper has been apart and it wasn't clogged up, but got a thorough cleaning as well. Guess I should look at my lines...
Offline Tugboat
  • Puppet
    • PseudoMoto
« Reply #11 on: August 23, 2012, 09:42:46 AM »
Don't reuse that one. Get a new piston.
« Reply #12 on: August 23, 2012, 09:44:18 AM »
The piston IS reusable.
Don't worry about leaks, it won't.
Don't worry about braking action.  That will be fine, also.
The only possible issue with that piston *might* be retraction.
The square section seal goes (distorts) parallelogram during brake application.  When pressure is released the seal returns to square and pulls the piston back with it.
When the seal encounters piston pits, it changes how the seal is shaped at the pit area and that has an effect on it's retraction ability.  A few pits have very little impact on the this ability.  But, the detriment increases with the population and depth of the pits.
I wouldn't think that the small amount of pitting shown in the picture would be noticeable, and I've reused pistons with far more pitting successfully.
If it has any problem, it will show up as a dragging brake.  (Realize there are other causes to dragging brakes, too.)
The second issue with the pits is the loss of the plating and susceptibility to further corrosion.  However, if you fill the pits with the proper Dow Corning high vacuum pure silicone grease.  Water can't get at the de-plated steel and corrosion is thwarted.
Certainly a new piston won't hurt.  But, there is still service life in the one pictured, imo.
« Reply #13 on: August 23, 2012, 09:51:07 AM »
many of us have been fooled by the MC. Did you clean that hole with a very fine wire? That's about the only way you can be sure. Or air pressure.
First hand experience: I cleaned (soaked in my parts washer) my MC twice, it was oly when i concentrated on THAT tiniest of holes with a wire did i get results.
Offline jstfkndi
« Reply #14 on: August 23, 2012, 09:51:24 AM »
Ok, thanks! I feel I may have bought the wrong grease then. It is a standard run-of-the-mill from Advanced. Does it have to be the Dow High Vacuum? And perhaps a place I could obtain it or is it a online item only? I am going to go through the line whilst they are empty and see if there are any compromises. What in the lines should I look for? Flex? No flex? I mean, I know they pump up and don't leak :)
Offline jstfkndi
« Reply #15 on: August 23, 2012, 09:53:24 AM »
Guess it can't hurt to check it again. I really don't want to take the wholething apart, but in order to clear this hole, does the MC have to come all the way apart? Freaking C-clip was a pain!
And thanks for all the quick replies!
« Reply #16 on: August 23, 2012, 09:58:45 AM »
If its like the CB750 (my first hand experience) no it doesn't have to come apart. You would want to get it level (turn the HBar to make it so) soak/suck all the fluid out of the reservoir. (This may not even be necessary) There should be two holes visible in the floor of the reservoir. The tiny one is it. Many use a teeny guitar string. I found a strand of electrical wire from an AC ext cord would fit. Run it in and out. Should get 1/4 to 1/2" penetration to be sure its not blocked.
Now if that works, you've got to realize that crud is still in there, and may eventually make its way back. At least you know what's up.
Offline jstfkndi
« Reply #17 on: August 23, 2012, 10:01:31 AM »
Wooord!
Offline Teatimetim
« Reply #18 on: August 23, 2012, 10:09:02 AM »
I allways find it amazing when your working on something, and you think about say pitting, then come to this forum, and the question is already being asked and answered.
Bikes I own:
1974 CB550K
1971 CB450
Offline jstfkndi
« Reply #19 on: August 23, 2012, 10:43:38 AM »
Teatimetim, dealing with the same issue I presume? ;)
« Reply #20 on: August 23, 2012, 11:11:57 AM »
I feel it does have to be the one and only for this app.  No petroleum based product has the no-creep, no-bleed at any temperature property.  If it finds the pads and rotor, there go your brakes!
I bought mine from a local industrial supply business. 10-15 years ago.  I saw some posts a while back where it was purchased online and in small quantities.
This caliper design is NOT like the ones found on cars.  What is appropriate and acceptable there is NOT appropriate and acceptable for the SOHC4 brakes.
Ever open a brand new pack of rubber bands, take one out and stretch them?  Notice that the first stretch has more resistance that following stretches?
That's a property of rubber.  It loses some resilience and adherence to original shape as it is "worked".
The rubber brake lines are reinforced with embedded woven fibers to keep them from blowing up like a balloon when under pressure.  Still the they do flex a bit, and the repeated flexing causes fatigue, whereby they flex even more.  It does this at a certain pressure, and as you hand creates more pressure some is diverted to the expanding the lines rather the applying the pressure to the pad/rotor.
Unless you fins cracking in the rubber lines externally, the only way to determine if you rubber lines have reached end of life is an actual pressure/performance test.
The old ones will work, the new ones work better.
I have seen a failure mode where the inside of the rubber line chunked off and became a one way valve.  You could apply the brake, but it wouldn't release.  I only found this cracking the joint bolts at strategic places to relieve the pressure build up.  It was a lower line in this case, and the cure was a new line.
I can recommend SS brake lines.  These have a more rigid inner liner that is very resistance to expansion under pressure.  This allows all of the pressure built up by hand to be directed to the pad rotor.  The lever is harder, and the hand pressure modulation during braking has a much more precise feel.
Offline Tugboat
  • Puppet
    • PseudoMoto
« Reply #21 on: August 23, 2012, 11:37:25 AM »
I have a tube of the Dow Corning vacuum grease.. found it online last year. Cost like $40!! But, small price to pay to make sure grease doesn't melt at high temps and ruin my pads (as stated above). Thanks for the insight TT.
Offline lucky
« Reply #22 on: August 23, 2012, 12:01:10 PM »
Brake parts can get over 500ºf easily,and disc brake grease is good to 1000ºf.
Offline steam-powered man
  • Not the eggman, Not the walrus, I am the
  • Where are you going? I was going to make Espresso
« Reply #23 on: August 23, 2012, 01:15:46 PM »
haven't gotten to the brake yet on my project, but i am curious and found that bikebandit.com lists the same part number for cb350f and cb550k and others.  then i did a search and found a stainless steel piston for $38 plus $6 shipping on ebay.  the ad says the piston fits these bikes:
CB350F (72-74)
CB350G (73)
CB360 (74)
CB360G (74)
CB360T (75-76)
CB400F (75-77)
CB450 (72-74)
CB500 K0-K2 (71-73)
CB500T (75-76)
CB550F (75-77)
CB550K (74-78)
not a bad price for new, stainless.  ebay seller has 11,753 happy customers.  i may go this route is needed.
searching for a dr350se
« Reply #24 on: August 23, 2012, 01:25:00 PM »
Disc brake grease will still lubricate at 1000 F, as it's specification indicates.   But, it will not stay put at that temperature.  It will weep, liquify, and creep into both the caliper pad and rotor of the SOHC4.   The Dow corning Silicone grease will not.
So, pay attention to the material properties that are required.  The SOHC4 caliper and rotor does NOT need lubricant.  It needs a water barrier that won't be dissolved in water and stays exactly where it is placed under elevated temperatures.  Honda used when new and specifies the silicone grease in the shop manual.  And, there are very good and specific reasons for doing so.
