Author Topic: So... this is bad, right? *Update on post #9*  (Read 6065 times)
Offline Dimitri13
  • 1974 CB550K
Re: So... this is bad, right? *Update on post #9*
« Reply #25 on: September 24, 2012, 02:59:50 AM »
Split the cases finally. Took forever (who knew you had to remove the pistons to get the top case off? selective reading, of course). It was dark already so I wasn't able to look at everything, but a quick glance revealed the primary chain has about 1/2" of slack, and one of the con rods has a ton of free play on the crank. I couldn't see anywhere where the primary or cam chain ate into the case (will be 100% sure tomorrow), so is it possible the amount of shavings in the oil pan is from the bearing getting gradually chewed up? What are the bearings even made out of?
Thanks for all the help so far guys. Will post more pictures tomorrow as well.
Offline fastbroshi
  • Puppet
« Reply #26 on: September 24, 2012, 03:24:02 AM »
That doesn't sound good.  Definitely warrants more inspection.
Just call me Timmaaaaay!!!
Offline trueblue
« Reply #27 on: September 24, 2012, 03:32:37 AM »
The bearings are made of white metal on a steel backing, I'm not sure exactly the metal composition of the bearings, I think they are an aluminium alloy of some sort.  It looks like bearing material in the picture of your sump.  If you spin a bearing it doesn't take long to chew it to pieces and makes horrible noises, sort of like someone hitting on the inside of your engine with a large hammer.  Also if you can feel movement in any of the rod bearings the bearing is shagged.
1979 CB650Z
Offline Dimitri13
  • 1974 CB550K
« Reply #28 on: September 24, 2012, 03:47:58 AM »
Oh, and one of the intake valves is stuck in the guide. It looks like the top got hit and has spread out just a bit, making a lip that won't go past the top of the guide.
Is it okay to sand off the lip to get it out?
What do I use to clean off the carbon from the chamber, piston tops, and valves?
Offline trueblue
« Reply #29 on: September 24, 2012, 04:04:15 AM »
Use a small file to remove the burr and a wire buff to clean the carbon off.
1979 CB650Z
Offline Dimitri13
  • 1974 CB550K
« Reply #30 on: September 24, 2012, 04:13:21 AM »
A wire buff... Like a wire wheel? Can I just take it to my bench grinder?
Offline trueblue
« Reply #31 on: September 24, 2012, 04:21:25 AM »
Yeah a wire wheel, you can use one attached to a bench grinder, but it is not the best for the head, it is a bit rough on the aluminium.  You are better off using one attached to a drill or die grinder to clean the chambers.
1979 CB650Z
Offline Dimitri13
  • 1974 CB550K
« Reply #32 on: September 24, 2012, 04:34:13 AM »
Alright. I have a wire brush attachment for my drill. Valves and pistons on the bench grinder are fine?
Offline trueblue
« Reply #33 on: September 24, 2012, 04:41:00 AM »
Valves are fine on the bench grinder with a wire wheel, pistons are ok, just be very gentle with them and take your time.
1979 CB650Z
Offline Dimitri13
  • 1974 CB550K
« Reply #34 on: September 24, 2012, 04:41:24 AM »
Will do.
Offline CBGhia
« Reply #35 on: September 24, 2012, 05:08:15 AM »
If you have a brass wheel, I would use that.
