Author Topic: Is this fixable?  (Read 1519 times)
Offline techy5025
  • 1969 Diecast and Sandcast 750's
Is this fixable?
« on: July 02, 2006, 12:23:42 AM »
A few of the fins on my engine have suffered from some
prior garage rash.  Is this fixable....hopefully on the bike and
without reaching for a tool that has large tanks attached?  ;D
Maybe some sort of metal mender??  ???
Pic provided...
Jim
1969 750 K0 (Reborn)
1969 Sandcast 750 K0 (Reborn)
2003 CBR600F4I
Offline 750goes
  • it will live
Re: Is this fixable?
« Reply #1 on: July 02, 2006, 01:08:27 AM »
By the looks of it, I wouldn't try to re-bend it back into shape or straighten with a pair of grips or anything - it will probably just snap off,
I suppose if you could heat it through enough to make it malleable you might have a chance, but I think you may just cause yourself more grief if you try...
How old is that aluminium alloy anyway ?? :)
Offline techy5025
« Reply #2 on: July 02, 2006, 01:10:13 AM »
This is a sandcast....1969 engine....so maybe I will leave it and
call it "character".  ;D
Jim
2003 CBR600F4I
Offline 750goes
  • it will live
« Reply #3 on: July 02, 2006, 01:20:25 AM »
Congratulations, do with it whatever takes your fancy. Whatever you do it's yours not anyone elses.
I don't have any remedies..
good luck with whatever you decide to do.. :)
rt
« Reply #4 on: July 02, 2006, 03:39:40 AM »
If you're into a purely cosmetic 'engine-in-situ' job you might try some of that heavy duty industrial alloy putty to rebuild/reshape your fins. Any professional repair involves taking out-/dismanting the engine, careful expert welding and excessive use of Dremel-ish tools.
On the other hand: your bike is 36 years old and has to have some 'battlescars'; If your bike runs fine I'd go for the 'character-option' until an engine rebuild is due anyway.....  ;)
Offline puppytrax
« Reply #5 on: July 02, 2006, 05:58:18 AM »
I would just take a Dremel and then do some file work to straighten out the lines and leave it go. Nobody who doesn't know bikes will know what you did, and those who do will know why...   ;D
...stock 1972 CB500 '500 Four' undergoing re-assembly...
...Stock 1972 CL450 'Scrambler' also being re-assembled...
Offline DammitDan
  • Prodigal Son
  • It lives!
« Reply #6 on: July 02, 2006, 07:53:32 AM »
Took my mind a few minutes to get around that one  ;D
CB750K4
Offline puppytrax
« Reply #7 on: July 02, 2006, 07:56:57 AM »
Sounds like a Yogi-ism, don't it???  :D
