Author Topic: My Idea to Relocate Wiring Into a Saddle bag.  (Read 4618 times)
Offline Magilla
  • My bike: 1976 CB750F
Re: My Idea to Relocate Wiring Into a Saddle bag.
« Reply #25 on: November 01, 2012, 08:39:43 AM »
I'm still stuck wondering why.  Do you want to open up the mid section of the bike like a Cafe Racer style?  Is that what is causing you to want to hide your electronics in an ammo box?  I'm not saying don't do it or that it would be stupid to do it, I'm just trying to understand the motivating force behind this.
This entire project goes against conventional thinking.  Not that, that is a bad thing but its hard to wrap your head around.  Opening up the mid section tends to be a Cafe thing.  You want it to look as bare bones as possible.  Adding side bags goes against this line of thought.  Adding side bags usually is about adding additional storage to your bike.  Filling them with electronics goes against this line of thought.
So in the end it will be a Cafe style bike with side bags that cant be used because they are already full.  Sounds screwed up but who knows, maybe it will be cool.  Be sure to post some pics when your done.
1972   Honda CB350
1972   Yamaha 500
1982   Yamaha 650
1988   Harley Sportster 883
1983   HD FXR Shovelhead
2003   HD Heritage Softail
2006   Victory Vegas Jackpot
1980   Honda CB650
1976   Honda CB750K
1982   Honda CB750
1964   Honda CA95
1982   Kawasaki 550
1974   Honda CL360
1975   Suzuki GT550
1981   Honda CB750
1981   Honda CB750
1970   Norton Commando
1972   Yamaha U7E
1970   BMW R50/5
1976   Honda CB750F
Offline NewOldSchool
  • Apprentice
« Reply #26 on: November 01, 2012, 10:27:46 AM »
This is what I was getting at as well. Just curious and can't understand the train of thought.
The electronics are also put in a protected spot on the motorcycle. A simple low side which could be easily ridden away from could potentially rip everything off of the bike.
Not putting miles on your bike is like not having sex with your Girl Friend so she'll be more desirable to her next Boy Friend.
Offline nitsua93
« Reply #27 on: November 01, 2012, 10:53:28 AM »
I don't even know why you care about my motivation :P I do like the open style, even if it's not a café. I'm also going to have just one saddle bag. I think it'll look good. If not I can restore it to the way it was.
Sent from my HTC One X using Tapatalk 2
Offline mono
  • Definitely no
« Reply #28 on: November 01, 2012, 12:50:29 PM »
i dunno if the 10-ish lbs will make a big difference, but having everything in a single side bag will throw off the balance of the bike.   just had to say it, as it's a safety thing (potentially).
Offline WarwickE36
« Reply #29 on: November 01, 2012, 01:04:04 PM »
I must say I am curious as to the desire as well.  I get some flack on here from time to time for my outlandish ideas but usually I have good reason for doing something out of the ordinary.  Without providing the members here with a reason for doing something you are unlikely to get a lot of help.  If rewiring is something you aren't very comfortable with you may find out this projects end result was not worth the headache.  I think THAT is the point everyone is trying to make.  If there isn't a benefit i.e. aesthetic, function, efficiency... why bother to put in the time, money, and considerable headache to do it.
I am all for doing things in an unconventional way.  I usually just have a reason (and no problem sharing it.)
That being said, I can see an open style bike with bags being cool.  I don't think open style and cafe are synonymous ... brat style and chopped come to mind immediately.  If you are going for an old school semi chopped look (even if you are extending rake and fork length)  I think a bag under the headlight might look neat... you could probably find a way to relocate electronics into that compartment... that being said relocating the battery means extending cables which means you need to go down in gauge to keep heat down and allow proper current flow.  A single side bag could work too and I would urge you to consider a decent aluminum heat sink instead of a block of wood to separate your electronics from your storage.  Maybe over that put a false bottom that allows for an air gap between it and your heat sink.
I would be wary of installing a fan facing down.  Even people who try not to ride in the rain get caught from time to time.  Water + electronics = problems.  Even with good weatherproof connections water has a way of getting into things and causing issues.  I wouldn't say don't use a fan but I would probably try to keep it away from the ground and rooster tail from any rain that decides to find its way into your setup.  If I was going to use a soft bag I think I would either reuse an ammo box or make my own box to put in it to keep things staying put instead of slapping around which could cause chaffed wires.
If you wan't any other advice or info let me know
« Last Edit: November 01, 2012, 01:05:44 PM by WarwickE36 »
" Why does anyone get offended by what someone does to their own bike? I dont get it. "
You made me think about it after I cheered knowing someone else would like to know what these control freaks are up to.
 Every time any owner strips whatever precious Honda part the horrified purists parts go up in value. That's not the part that bothers them.
 What bothers them is they sat up late at night, their breast full of wonder and estrogen, unable to sleep, dreaming about their lovely darling and all her glory... and next thing you know someone else doesn't share their emotional deluge and their reaction is they must spread their mind museum as far as they possibly can, taking over as much of the real world as possible.
Drink fast, drive slow, but ride it like you stole it
1974 Cb550 with style
2004 SV650s
Offline Toxic
« Reply #30 on: November 01, 2012, 01:23:19 PM »
I know you said one saddle bag but what if you use two and put the oil bag in the other
That would look cool
Kind of a low slung bagger look
Just a thought but its your bike do your own that's what being a biker is partly about
What you must do is post pics of your progress
Offline nitsua93
« Reply #31 on: November 01, 2012, 02:30:42 PM »
I haven't made any progress yet :p Does anyone have a picture of a cb750 with relocated wiring? I'd like to see one on the stock body, not brat or cafe.
Offline lucky
« Reply #32 on: November 01, 2012, 02:55:00 PM »
I've been reading a few posts on wiring and tucking. I got the idea to put the battery,regulator,fuses, etc. Into a saddle bag. Obviously it would need air flow so I'd put 12v computer fans in the bag where I'd make vents. What's your idea on this? I don't see anything wrong with doing it this way, so please give me some input.
Sounds like an interesting idea.
Hope no one steals the saddle bag.
Offline DustyRags
  • I'm not skilled, I'm just a
  • Just try it and see what happens
« Reply #33 on: November 01, 2012, 03:29:28 PM »
If they do, they'll get a hot surprise when they clip it off! ;D
1976 CB550K- sold
2005 Kawasaki Vulcan 500- sold
2000 CB750 Nighthawk - sold
1975 XL350 - crashed
2004 Suzuki Vstrom 650 - sold
Offline lucky
« Reply #34 on: November 01, 2012, 03:55:49 PM »
what about mounting the stuff on the saddlebag frame work, and then just put the bag over it all.
Offline Lavis500
  • Why don't you go ask a
  • "Don't plan vast projects with half-vast ideas"
« Reply #35 on: November 01, 2012, 04:56:09 PM »
I can understand wanting to open up the center frame work for aesthetic reasons; I did the same thing to my Suzuki Savage.  That was just moving the battery, though.  Speaking of which, do you plan on moving the battery, too?
If you want to use ammo cans, they aren't really expensive. They are certainly cheaper than ANY saddlebag you can find - including everything on Jafrum.  The metal makes them much easier to manipulate and customize, IMHO.
http://www.cheaperthandirt.com/product/ZAA-095
Another idea:  Take the plate with everything mounted as is, and bolt it to the inboard side of the interior of the ammo can.  You could cut slits on that side, and if you're fancy maybe even punch the material out to make a wind deflector type opening.  You could get the same effect from cutting larger openings and bolting on a deflector.  Just make a nice little metal shelf to slide over your electrical plate and voila!  Out of sight, out of mind.  Drill a hole at the bottom of the box and route all of your wires through there.  Don't forget about your fuses!  They NEED to remain accessible.
You wanted an idea, so here you go.  I'm curious to see how you go about this.
"Whatever it is, I swear I didn't do it!"
'73 CB500 - Sally
Offline Magilla
« Reply #36 on: November 01, 2012, 05:05:25 PM »
Somewhere out there is a future owner of this bike who is going to want to beat you silly.
Nice Dodge Dart in the Foster Grants
1972   Honda CB350
1972   Yamaha 500
1982   Yamaha 650
1980   Honda CB650
1976   Honda CB750K
1982   Honda CB750
1964   Honda CA95
1982   Kawasaki 550
1974   Honda CL360
1975   Suzuki GT550
1981   Honda CB750
1981   Honda CB750
1972   Yamaha U7E
1970   BMW R50/5
1976   Honda CB750F
« Reply #37 on: November 01, 2012, 05:06:18 PM »
I think its not the best idea, if you drop the bike on the wiring side, major problems, it doesn't take much to rip off a saddle bag in a spill and normally you would just be down a bag, in this case you down a complete bike till you fix everything which may include replacing parts as well...  Its not very common for the wiring to be damaged on a "normal" bike after a collision. In my opinion its a lot of work for zero gain and could create more problems than its worth including sparks from damaged wiring igniting spilled fuel......
Offline FlyBoy
  • 1977 CB550K
« Reply #38 on: November 02, 2012, 01:53:16 PM »
i say go for it. be a daredevil. try something new. its your bike, so build it how you want to. no body ever got famous for doing exactly what everyone else is doing.
« Reply #39 on: November 02, 2012, 02:35:05 PM »
And thats exactly what everyone is doing....
Offline Cabilao
  • Diving and Driving
    • Sea-Explorers Watersport
« Reply #40 on: November 03, 2012, 12:41:33 AM »
oil tank right side,wiring left side and luggage onthe tank. sound like a plan! 8)
before:
Kreidler RMC(50cc)
CB400N(first bike)
RD350LC(more than one)
XS850(great bike)
CB900F(wish i still have it)
FZR1000(too fast)
Rickman CR900(sold for a good price)
now:
Rusi 125
CB 125 CL(just for fun)
Yamaha XTZ 125
CB750P7(mystery bike)
77/78 cool 2 member
Offline matt mattison
« Reply #41 on: November 03, 2012, 04:14:59 AM »
Cool idea for a show bike. But for a bike used regularly, I would have some concerns about those parts being exposed to damage etc.
1975 CB550F
2011 MV Agusta Brutale 1090RR
