Author Topic: CB750 K3F - AKA The Red  (Read 163693 times)
Re: CB750 K3F - AKA The Red
« Reply #475 on: September 05, 2022, 01:22:09 PM »
The set of new to me Ikon shocks - thanks again, Hondaman -   resisted all shop hack solutions.  So i spent several hours making a tool from an old axle. I even hardened it in oil bath. I am glad I did, it took 4 feet pipe to losen up the nut.
The plan is to rebuild the shock and get a set of springs for Red.  The sidecar and my fat ass makes her bottom out too easily.
It ain't pretty, the 1/2" nut lets me use a bolt for handle.
« Last Edit: September 05, 2022, 01:26:11 PM by 70CB750 »
« Reply #476 on: December 08, 2022, 01:03:05 PM »
Just documenting.
« Reply #477 on: December 12, 2022, 10:57:19 AM »
How does Red like the hack?!
Offline Alan F.
« Reply #478 on: December 12, 2022, 11:15:32 AM »
Looks good.
« Reply #479 on: December 13, 2022, 06:03:21 AM »
It keeps her warm, she has to work harder than solo bike.   :D
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #480 on: December 13, 2022, 06:58:24 AM »
You need the top box with the side car?
Nice looking setup.
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline Alan F.
« Reply #481 on: December 13, 2022, 08:17:39 PM »
Good question, does the sidecar seat tilt forward to access storage behind?
« Reply #482 on: December 14, 2022, 07:24:15 AM »
The top box is handy and I am used to it.
The back of the seat in the sidecar can be completely removed.  In theory it is locked - but my lock was busted, I have to bring new one from home/Czech.
Offline grcamna2
« Reply #483 on: December 14, 2022, 10:24:55 AM »
If it was me,I would find a tiny hubcap for the sidecar wheel  :)
75' CB400F/'bunch o' parts'
« Reply #484 on: December 14, 2022, 10:35:49 AM »
It needs it, doesn't it? I was thinking about machining down CB750 sprocket hub but it would be too much work and weight.  I should find and cut out some 6061x1/4" for it.
Offline grcamna2
« Reply #485 on: December 14, 2022, 11:08:59 AM »
I think you might find one from another vehicle;now it's on your 'radar' so you see one.
A fancy wheelchair type vehicle perhaps  :D
I'm thinking a vintage car,something from the 60's may have a small hubcap to fit right over there;Honda S800 ?  :)
« Last Edit: December 14, 2022, 11:34:32 AM by grcamna2 »
Offline grcamna2
« Reply #489 on: March 13, 2023, 05:38:56 PM »
Red had a flat front tire. Nothing dramatic, i was just checking pressure at home and it was 15psi.
Turns out the new valve I installed when replacing the tire was leaking. I usually run NAPA 90426 valves in my Comstars, but this time I used a different type.  Luckily  the rear wheel and the sidecar wheel are still NAPA.   Tonight I dismounted the front tire and installed NAPA valve from my road kit.  Gotta buy more of those and toss all the new type valves.
« Reply #490 on: March 14, 2023, 07:20:14 AM »
My K4 front tire was totally flat last week. I mentioned it to my buddy and he said to check the valve with a little water after inflating. Sure enough, it had a leak. I removed the core and wet the ring, reinstalled and has been good since.  Guess it just dried up and leaked.
« Reply #491 on: March 14, 2023, 07:29:58 AM »
Thats a good tip, thank you.  Mine was leaking between the rim and the valve.  I use these to run tubeless tires on Comstars not intended to be tubeless. This was my first issue ever with this "illegal conversion".
« Reply #492 on: March 14, 2023, 09:23:29 AM »
My 78 CX has Comstars and they are marked Tubeless. Are yours marked Tube?
« Reply #493 on: March 15, 2023, 03:12:14 AM »
Interesting, I believe for CB750 they went tubeless in 1979.
My wheels are 78 and there is no marking on them.  I did a lot of research before I went that route, but it worked out well.  The only difference from tubeless rims is the valve hole. Some people tap it and use a valve from water tank, but that NAPA valve works for me.
Offline grcamna2
« Reply #494 on: March 15, 2023, 11:30:50 AM »
I've changed a few tires on different wheels and added valve stems to wheels.
I notice there is a difference between wheels that are marked 'tubeless tire applicable' and those that are not.
The wheels that are marked Tubeless have very wide bead surfaces inside with a designated 'lip' on the inside edges of each bead shoulder that makes it a bit more difficult to 'seat' the beads initially when installing the new tire.
The Tubeless designation on the wheels has a safety feature in case the tire was to have a blow-out and instantly run flat while a person is riding it:the tire stays 'seated' when that happens. I haven't had that happen to me,and God help me if I did..  :o
A tire could conceivably lose bead contact as I'm describing which would wrap the tire up around the rim in a strange way and expose the metal rim surface to the road;to me that's a 'worse case scenario',especially on a Front while I'm going around a corner.
I had a set of Suzuki mags which comes on the GS1100E that is meant to have tubes installed and these wheels have very small bead surfaces inside the rim with no inner 'lip' on the edge. I installed metal valve stems into them and mounted a pr. of Metzeler tires and they held-up well,the metal valve stem had a slow leak,which was a problem;I had never considered what would happen if I was to lose All the air in the tire at once.. although that rarely happens.
« Last Edit: March 16, 2023, 09:23:36 AM by grcamna2 »
« Reply #495 on: March 16, 2023, 04:24:44 AM »
I never compared tube and tubeless Comstars but I believe the only difference is the valve.  The rim is pretty deep, it actually takes some effort to unseat the bead.
Offline grcamna2
« Reply #496 on: March 16, 2023, 09:21:04 AM »
I remember drilling-out and chamfering a valve stem hole on one of my non-tubeless tire aluminum wheels in the past;to accept a larger O.D. and better sealing rubber valve stem...  ::) I hope it hasn't caused anyone problems.
« Last Edit: March 16, 2023, 09:27:22 AM by grcamna2 »
