SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
SOHC/4 Shop
Home
Help
Login
Register
Donate
Tech Forums
SOHC/4 Bikes
Topic:
Right turn jerking - transmission likely
« previous
next »
Print
Pages:
1
2
All
Go Down
Author
Topic: Right turn jerking - transmission likely (Read 4735 times)
dave500
Really Old Timer ...
WHAT?no gravy?
Re: Right turn jerking - transmission likely
Reply #25 on:
March 02, 2013, 04:50:49 AM »
forks can also wear on one side more than the other,one side pushes in,the other out and into the other gear depending.
Logged
rtbmrgl
Expert
Got Points! Roseville, Ca
Reply #26 on:
July 30, 2013, 12:14:47 PM »
This is an old thread and problem I sure has been fixed. This is problem is very sililar to my '72 CL350. When taking off from a stop there is a slip or clunk in the clutch area. Bottom line, the rivets attaching the gear to the clutch basket were loose. It would only be felt when taking of when there is high torque demand to the rear wheel.
I hope you fixed the problem.
Logged
thanks, Mark
Roseville, Ca
Got Points!
1973 CB500 back yard find 1243 orig mi,
http://forums.sohc4.net/index.php?topic=124285.0
1976 CB750 Restoring,
http://forums.sohc4.net/index.php?topic=132997
camelman
Man... Myth... Legend
Master
Reply #27 on:
July 30, 2013, 12:45:49 PM »
The rivets are probably fine. There is a hard rubber bushing in there that has probably decomposed. The rivet goes through the center of the bushing and had worn a slot in it as the bushing aged.
Logged
1972 350f rider: sold
1972 350f/466f cafe: for sale
1977 CB400f cafe:sold
1975 CB400f rider: sold
We've got to cut it off... and then come down on rockets. (quoted from: seven minutes of terror)
70CB750
Labor omnia vincit improbus.
Northern Virginia
Reply #28 on:
July 30, 2013, 02:07:10 PM »
I ride with minimum use of 2nd gear, the fix is in rebuilding the transmission and I want to build my K3F before I take apart the K0.
K3F is going slowly due to limited funds, but you can ride without using 2nd much
Logged
rtbmrgl
Expert
Reply #29 on:
July 31, 2013, 10:21:08 AM »
Interesting, the rivets seem to be tight, I thought there might be rubber or a spring behind the plate.
I have another housing I'm going to try.
thanks for the info.
Logged
thanks, Mark
Roseville, Ca
Got Points!
Bootlegger56
Butch
Hot Shot
Nuthin' taps ya out quicker than cole corn likker!
Reply #30 on:
July 31, 2013, 02:10:35 PM »
What kind of shocks installed on the bike? If they are the stock style is the pre load at minimum or maximum? Is there a fender or fender liner clearance issue?
Logged
Ya can travel near or ya can travel far; but no matter where ya go thar ya are!
750 K5
550 K1
754
Reply #31 on:
July 31, 2013, 03:14:03 PM »
Is chain alignment good?
Ifit isout oneside of sprocket teeth willbe very shiny,the other dirty.
Logged
Kelowna B.C. Canada
Print
Pages:
1
2
All
Go Up
« previous
next »
Tech Forums
SOHC/4 Bikes
Topic:
