Author Topic: Flux wire welder..  (Read 1020 times)
Offline toytuff
  • "watching the pinheads"
Flux wire welder..
« on: January 21, 2013, 03:00:27 PM »
OK, this is Harbor Freight stuff. Some good, most junk.
I really don't need one BUT if I do it's nice to have.
To buy or not to buy? That is the question.
tt
Offline Hasenkopf
  • Really, I'm not an
  • This space for hire.
Re: Flux wire welder..
« Reply #1 on: January 21, 2013, 04:56:52 PM »
looks like a good deal, if it does in fact have variable feed speed.  good enough to stick two bits of steel together!
I like berries.
Offline ofreen
« Reply #2 on: January 21, 2013, 05:01:27 PM »
Few things are as annoying as trying do a decent welding job with a cheap welder.
Greg
'75 CB750F
Offline Elan
    • Vital Motor Parts
« Reply #3 on: January 21, 2013, 06:48:24 PM »
I bought this about a month ago. Quick answer: its worth it. I bought it because the cat converter on my car cracked, so it was either $200+ for a new one, or this.
Now, obviously the basics:
1. you get what you pay for
2. welding is a skill.
This is a great starter, or to have in the shop for random little tasks. It runs on a 15amp circuit which is a huge plus. Being on 110 it can't weld anything too thick. no solid stock. But  to make brackets, repair stuff, and stuff where you can smooth out your ugly beads with the grinder, perfect.
I was psyched after i fixed my cat, and have used it on a few other things. Going back, i probably would have gone for the slightly more expensive one to have more control of the power (its just a low/high switch as opposed to a variable knob) and the better one can use stainless wire.  Also I read to not bother with the wire it comes with and buy better stuff, loses and home depot stock lincoln wire.
Also the mask it comes with is a joke, but fine for your first job or two.
76 750k
Offline jamesb
« Reply #4 on: January 21, 2013, 07:36:36 PM »
I've had mine for 5 or more years and like it my only problem with it is the feeder wheel will wear out and not feed the wire through. I replaced it once because it was under warranty. Now I have a small c clamp that helps feed the wire other than that I have welded tons of stuff with it. Lots of exauhst pipes. Panels on cars intact I just used it Sunday for my rear fender on my chopper I have gotten my $100.00 worth. it's cheap enough to practice on and then in the future but a better a d bigger one
Offline cougar
  • Stamping Ground, Kentucky U.S.A.
« Reply #5 on: January 21, 2013, 09:33:36 PM »
Welder, LOLOL ! Be fore-warned once you buy a welder and get used to it you'll want a bigger ONE !!   ;D    ...cougar...
I'm not prejudice, I'll weld anything that pays! Knowledge that is shared is Never Lost!!   Right is right, wrong is wrong! The truth is the truth and a lie is a lie! DEAL WITH IT ACCORDINGLY !!!   I HATE "DIAL-UP"
« Reply #6 on: January 22, 2013, 03:59:48 AM »
Exactly!  Save yourself the frustration and get a real welder, just 110V MIG is plenty.
Offline rb550four
« Reply #7 on: January 22, 2013, 05:35:24 PM »
Yeah, I did the Harbor Freight Welder, good for starting and learning the basics. Fixed lots of things around the shop ie cars ,trucks ,bikes, welded the snowbike together with it but , Now I want one with gas, and a stick set up, wanting to take night classes to learn the skill and lose any bad habits.
Side note: about 10 years ago I bought a hot wrench,( cutting torch).How handy was that! Had to sell it, cut every dam thing in the yard.
« Reply #8 on: January 22, 2013, 05:48:57 PM »
So whatta ya gonna do, Toy?
Offline toytuff
« Reply #9 on: January 22, 2013, 05:54:21 PM »
Just wanted to see what others thought.
Sounds like a 110 Volt Mig is the way to go. I don't need one but then again I don't have one.  ;D ;D ;D
tt
