Author Topic: Keihin Carb drain screw leaking  (Read 15012 times)
Offline scotty
« on: January 21, 2013, 06:07:24 PM »
I drained the bowls on my carbs, and one of the drain screw looks a little un-semetrical at the end, and it won't seal now.  I think some part of it broke off.  Anyone know where I can buy a drain screw for these Keihin PD46C?  And if that doesn't work, can I just glue it in with JB weld or something?
Re: Keihin Carb drain screw leaking
« Reply #1 on: January 21, 2013, 07:10:22 PM »
Is the gasket seal still there and unbroken for the drain screw?
Offline brewsky
« Reply #2 on: January 22, 2013, 02:43:52 AM »
You can get them here:
http://www.siriusconinc.com/pro-detail.php?pid=&product_id=1371
Either the price really went up or there is a mistake in the page!
I got a set of 4 from them not too far back and I believe $20 was for the set, not individual screw. Might want to contact them to clarify.
« Last Edit: January 22, 2013, 02:50:29 AM by brewsky »
66 CA77
78 550K
78 CB750K
02 FZ1
09 GL 1800
Offline Bru-tom
« Reply #3 on: January 22, 2013, 09:11:21 AM »
i had the same issue with mine. i went to a local bolt and nut supplier, got some brass screws, went to a o-ring and bearing supplier, got some fuel resistant o-rings, total equivalent to $0.50. shop around before you fork out ridiculous amounts of money for simple things. ;)
Offline neilc
  • old school biker,other bike is a 2003 vtx1800c
« Reply #4 on: January 30, 2013, 02:47:56 PM »
Ya mine don't drain if I back off on the screw either
Offline mrrch
« Reply #5 on: January 31, 2013, 09:57:43 AM »
The drain screws on some Honda power equipment carbs match up. See if your local dealer has a stash of old carbs (we save the old carbs for spare parts/came in handy when I needed a couple of drain screws)
my build
Offline Jore
« Reply #6 on: January 31, 2013, 07:03:37 PM »
This interests me, but I think my problem is different.
I've noticed that if I leave the petcock open with the bike off, number 2 carb starts dripping gas from the drain pipe, at first I thought the screw was loose, but it's not. I recently replaced the O-rings on all 4 of them.
1975 CB400F owner
-Having a vintage motorcycle is like having a moody girlfriend.
My 466 build: http://forums.sohc4.net/index.php/topic,146494.0.html
« Reply #7 on: January 31, 2013, 08:02:55 PM »
Its probably a float needle and seat that is not sealing perfectly.Not really a problem when riding and probably not an issue when you turn off the petcock when not riding as recommended for these bikes.
Offline Jore
« Reply #8 on: January 31, 2013, 08:38:38 PM »
so can I ignore it? or what can I do?
1975 CB400F owner
« Reply #9 on: January 31, 2013, 10:30:15 PM »
On the PD46 carbs the drain screw operates like a valve, the tip is kinda pointy, machined, and blocks an orifice located at the bottom of the bowl.  The fuel exit path is into the bowl overflow drains. Other, earlier, Cb550 carbs behave differently.  If the bowl seat is f'd up, perhaps it can be reconditioned buy a machine shop ( or replaced).  If the screw tip is jacked, it won't seal, either.  Maybe the tip can be machined down, or simply replaced.
I don't know what kind of carbs the thread hijacker has, and they are NOT all the same.   So, I can't diagnose that problem.
Offline Jore
« Reply #10 on: February 01, 2013, 12:12:19 AM »
Really sorry for the thread hijacking.
But my carbs are also keihin (not sure of the type,there on a 75 400)
1975 CB400F owner
« Reply #11 on: February 01, 2013, 01:08:50 AM »
...and this thread began about 78, CB550 Carbs
Anyway, yours is unlikely a drain screw problem, as your carbs are a different design than the PD46.  For yours, either the float valve is leaking from debris, uneven wear, the float height is set for too high a fuel level, or the float pivots are binding/sticking.  May also be a bowl gasket out of place and hindering float movement.
Does it behave differently if the bike is on side stand or main stand?  (Helps narrow down some issues.)
Anyway, it is routine to shut the fuel valve off when the bike is parked.  Modern bikes have engine vacuum operated fuel shut offs.
Offline Jore
« Reply #12 on: February 01, 2013, 08:20:35 AM »
Sorry once again.
But I might as well ask. I only have a side stand, so no idea what would happen on a centre stand.
1975 CB400F owner
Offline jas67
« Reply #13 on: February 19, 2013, 05:19:02 AM »
So, on the CB400F, should the fuel exit via the overflow tubes when the drain screws are open, or does it come out around the drain screw, making a mess of the engine cases.
I ask this, because I have two CB400F's, one very pretty, one not-so-much.    When I drained the carbs on the not-so-nice one, I expected the fuel to exit via the drain tubes, but it came out around the drain screws, on all four carbs, making a mess of the engine cases.     Because of this, I haven't yet drained the nice one, so the fuel has been sitting there for half the winter getting stale (it does have stabilizer in it), because I didn't want o make a mess of the engine.   I guess I make some sort of catch tool to put under them to drain the fuel into.    I'm thinking some sort of small funnel with a side exit to a hose that I can put into a gas can.
Classic Honda:
1976 CB400F
1975 CB400F (project)
1975 GL1000
1968 CL175 (1 nice one, one project)
1967 CB77
1967 CB160 (2 of 'em, both projects)
1967 CL160 project
Triumph: 2017 Thruxton R
BMW: 2016 R1200RS, 1975 R90S, 1973 R75/5, 1980 R100S
Ducati: 2013  Monster 796, 2013 848 Evo Corse SE track beast, 1974 750GT, 1970 Mk3d 450, 1966 Monza 250
Moto Morini: 1975 (titled 1976) 3 1/2 Strada, w/ Sport clipons.
Moto Guzzi: 2017 V7III Special,  1977 Le Mans, 1974 Eldorado
Offline lucky
« Reply #14 on: February 19, 2013, 06:49:44 AM »
A leak can also be caused by a cracked overflow tube in the float bowl.
You will need a magnifying glass to see the crack. Even if you are NOT old.
But since you did not tell us what year the bike is it is hard to say.
The 77-78 carb float bowls had a different type drain system.
They had a drain screw but it did not have to be completely removed to drain the bowl.
« Reply #15 on: February 19, 2013, 12:00:17 PM »
The drain screws don't effect the overflow pipe drain channel on your carbs.  They drain where they screw (sounds dirty, heh heh)
What I use is the tray from an Entenmanns coffee cake offering.   I simply endure the torture of emptying the tray prior to it's main purpose.  ;)
Offline MoMo
  • Ride like you're invisible
« Reply #16 on: February 19, 2013, 12:03:32 PM »
You most likely have a cracked drain pipe as Lucky said...Larry
Offline jas67
« Reply #17 on: February 19, 2013, 12:05:53 PM »
Great idea!   I like Entenmann's baked goods.   I'll pick some up on the way home tonight, and the tray will be available for use by the weekend.
Classic Honda:
1976 CB400F
1975 GL1000
1967 CB77
1967 CL160 project
« Reply #18 on: February 19, 2013, 12:08:02 PM »
The drain screw on the non-PD carbs does not have to be completely removed, either.  The brass plug has cross drilled holes. So, in theory,  you only have to unscrew enough to pull the oring off the bowl to drain the carbs.  However, sediment often blocks the small cross drilled holes, and the oring sometimes sticks to the bowl.  In these cases, the plug must be removed completely.
« Reply #19 on: February 19, 2013, 12:16:59 PM »
i just bunch a ball of rag under those screws and soak it up as they empty,you dont have to fummble with spilling fuel from a dish then,,the same way you drain holley carb bowls once the bowl screw comes out.
Offline jas67
« Reply #20 on: February 19, 2013, 01:01:36 PM »
I'd rather drain the fuel into a container to safely dispose of.    What do you do with the fuel-soaked rag when you're done?
I was thinking some kind of "gutter" made from a piece of PVC pipe with caps on the ends, and a small barbed fitting connected to it with a piece of hose on it, so the fuel drains out of the the "gutter" into a closed container via the hose.    This way, I don't have the hazard of fuel sloshing around in a large flat tray.
Classic Honda:
1976 CB400F
1975 GL1000
1967 CB77
1967 CL160 project
« Reply #21 on: February 19, 2013, 01:13:08 PM »
wow,i love the over thinking of the simple act of draining a cup of fuel,the rag mostly dries out and i throw it away once its fully soiled from say wiping down a filthy drive chain etc.
« Reply #22 on: February 19, 2013, 01:30:58 PM »
next time you smash your hands sliding that motor back in and have to go to the ER, 'borrow' one of those kidney bean-shaped vomit trays (emesis basin) and cut one side down to slide right in and fit under the drains.
luckily my wife is a RN.  she loaned me one  ;D
its also painless to pick one up at a drugstore or staples for less than $1.00
gas can go right through a coffee filter and into your mower.
« Reply #23 on: February 19, 2013, 01:52:09 PM »
no #$%*, what did you guys do when you were kids?  Around my neck of the woods it went something like this..."Hey lets use this gasoline to make flaming pentagrams in the street again...I don't want to mow the lawn..."
Offline Tugboat
  • Puppet
    • PseudoMoto
« Reply #24 on: February 20, 2013, 10:21:30 AM »
+1!!!
