Author Topic: CB750 stock carbs with headwork, Wiseco 836, and Megacycle 125-65  (Read 7658 times)
Offline brandEn
Re: CB750 stock carbs with headwork, Wiseco 836, and Megacycle 125-65
« Reply #25 on: September 27, 2013, 07:53:01 AM »
found em
http://www.knfilters.com/search/product.aspx?prod=rc-2314
I can get a set of 4 from Amazon for under $100
Offline Medyo Bastos
  • Gusto mo titi ko?
    • project
« Reply #26 on: September 27, 2013, 08:52:20 AM »
the first thing i noticed was no more goofy sucking sound you hear with cheap pods!
« Reply #27 on: September 27, 2013, 04:05:54 PM »
I hate that sound, sounds like  4 cylinder blow job..... :o 8)
« Reply #28 on: September 28, 2013, 06:17:55 AM »
Nice sound :-) If you hear the inlet that much your 4-1 must be too silent :-)
All years with 4-1 made me to miss the 4-4 pipes and the wonderful sound during deceleration.
Well made 4-4 set would be fine. Shorter ones with racing look and good breathing, maybe stainless steel.....
EDIT: I had to visit my garage and open my old dirty carbs to check.
A little bit more than I thought.
Mains 147.5!
pilot 40
Air screws  1/2 turn out.
I remember that I checked the mains at full speed and reduced throttle just a little bit. If the bike accelerated by reducing the throttle I changed mains to bigger. Also checked the plugs, kill switch at full speed.... The bike went well, mostly long touring vacations to north Italy, Spain with 2 much younger and slimmer persons + bags with luggage + tent_sleeping bags.
3 holidays. High speed all days long, mostly 150-200km/h according to the speedometer. I have blurry memories when driving in heavy rain passing trucks on Autobahn in Germany, could not see that much, reduced speed and saw the needle at 160-170km/h :o
If I should use the carbs today, I should upgrade the pilots and test the mains again.With gasoline of today with extra ethanol it might be OK and not too rich.
I hope my VM29's are not too lean, only 127.5, pilots 25, otherwise as CB750 spec.  Maybe I'll upgrade to 130.
« Last Edit: September 28, 2013, 02:09:28 PM by PeWe »
« Reply #29 on: September 28, 2013, 09:01:04 AM »
Oval KN filters today. Maybe better flow when they are bigger?
These fits the VM29's
http://www.knfilters.com/search/product.aspx?prod=rc-2454
« Last Edit: September 28, 2013, 02:07:52 PM by PeWe »
Offline wiskey
« Reply #30 on: October 03, 2013, 06:34:53 AM »
I believe they are the same ones i used. I have stock '77 carbs and similar engine build.
Without a dyno or A/F meter I have no idea how close my tuning is, with that said  I think I'm pretty close.
One tip I can give is how much of a difference a re-oil with K & N filter oil made to my bike. I'm sure many will point this out as a lean condition but carb #1 and #4 do seem to dry out much quicker. A quick spray and the bike just runs and sounds much better.
Also get the Morgan Carbtune. It's expensive (~$100usd) but a very nice kit and I contribute a lot of how my bike runs to having the carbs properly synced.
