Author Topic: Castrol GTX, anyone using it? Updated with picture!  (Read 7517 times)
Offline Magpie
« on: April 01, 2013, 10:44:17 PM »
I'm just curious if anyone is using GTX because way back in ancient times when these bikes were new, Castrol GTX 20W-50 was THE oil to use. I had a look at it today and it's not Energy Conserving so it's okay for the wet clutch.
This is not meant to be an oil thread please, I'm just curious is all.
Cliff.
« Last Edit: April 02, 2013, 05:21:00 PM by Magpie »
Offline kghost
Re: Castrol GTX, anyone using it?
« Reply #1 on: April 01, 2013, 10:47:12 PM »
I've used various types of cast roll for years
Stranger in a strange land
« Reply #2 on: April 02, 2013, 12:05:55 AM »
Yes, for a long time.
Offline crazypj
  • I'm brill, me
« Reply #3 on: April 02, 2013, 12:21:37 AM »
It sucked in bikes in the 70's, probably no different today.
My 550 came with it from new and needed new ring after 3 months
Automotive oil will break down real quick, the transmission trashes it (plus the clutch will slip because of the friction modifiers)
« Reply #4 on: April 02, 2013, 12:42:02 AM »
Not all automotive oils have friction modifiers. Pennzoil was very popular back in the day...
Cliff, i can't believe you started an oil thread... :o ;D
Offline CoachDoc
  • 1974 CB550, 2005 GL1800, 1997 Valkyrie Standard
« Reply #5 on: April 02, 2013, 12:48:31 AM »
I used to use it exclusively. Worked fine. Decided to switch to a synthetic without friction modifiers a while back, but I wouldn't hesitate to use the Castrol GTX........ and I'm not a big believer in motorcycle oils vs. automotive oils.
Offline kghost
« Reply #6 on: April 02, 2013, 03:51:26 AM »
I've used it for years both in 10/40 and 20W50 selections and my rings are fine. While likely not the best oil it does the trick. Odd that it only needed one ring and you associate that with the lubricant. Even lesser oil will not destroy a ring in three months unless you circumnavigated the planet?  ;)
rt
+1. I'd be awash in broken rings.
« Reply #7 on: April 02, 2013, 04:22:15 AM »
Has Castrol been owned long by BP?
Their gasoline I am not fond of due to issues which cars I have owned had less performance when using their fuel.
Controversy for breakfast...
Offline 2wheels
« Reply #8 on: April 02, 2013, 05:24:33 AM »
Castrol GTX 20w 50 is all I have ever used in my 750's
Never had a problem.  Both bikes engines have never been opened up.  All original.
1970 CB750 K0 (I can't believe I tossed my duck tail seat in the trash 30 years ago)
Offline Johnie
« Reply #9 on: April 02, 2013, 05:30:12 AM »
Agree with Retro Rocket...Penzoil was very popular back in the day. I used it on all my bikes as did my biker buds and never had an oil related issue. Clutches were always fine and bikes never needed to be opened up. I can not believe Cliffy started an oil thread. :) Is he new here?
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline Scott S
« Reply #10 on: April 02, 2013, 05:34:51 AM »
 My local Pep boys has Castrol motorcycle oil. Been using it for a couple of years with no issues.
 Sorta-kinda related.....a lot of the XS650 guys use Pennzoil automotive oil. It works fine in the XS, but the clutch will start slipping a little sooner than with motorcycle oil. However, the price difference is so great, you can change your oil every 1,000-1,500 miles and still be ahead cost-wise. And you always have clean oil.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
« Reply #11 on: April 02, 2013, 05:35:44 AM »
I use it in summer - motorcycle GTX 20W50.
« Reply #12 on: April 02, 2013, 05:52:44 AM »
C'mon Cliff your a day late on the April fools joke  ;D   Dave500 getting the popcorn ready  ;)
Offline Magpie
« Reply #13 on: April 02, 2013, 07:26:02 AM »
Okay okay!   ;D  This is not meant to be an oil thread please, I'm just curious is all. didn't save me I guess.
The mods can delete this if they see it.
Cliff.
« Reply #14 on: April 02, 2013, 07:44:43 AM »
Cliff, I'll pussy foot around here before they delete this from the kingdom. I've always used GTX until recently, now use their 4T including my race engine. It's supposed to be motorcycle specific?? I trust Castrol.
PM sent
Offline crazypj
  • I'm brill, me
« Reply #15 on: April 02, 2013, 09:30:03 AM »
If there are friction modifiers the clutch will slip (unless you never use more than 3,000rpm?)
The clutch will slip with non- friction modifier oil as well, Honda designed it that way
rt
Was full set, not just one, I missed the 'S' on the end of ring (s)
Valve seals were also worn
It was re-built under warranty
I just don't like GTX, there were better oils for bikes that got ridden hard even back in 70's
I always rode gentle for first 3 miles to make sure engine was up to temp (under 2 k first half mile, under  4k for the rest)
Never believed in letting engine idle for extended periods to 'warm up'
« Last Edit: April 02, 2013, 09:35:31 AM by crazypj »
« Reply #16 on: April 02, 2013, 12:36:47 PM »
« Reply #17 on: April 02, 2013, 01:05:56 PM »
unbelievable castrol rx super,,,err i mean butter!
Offline malcolmgb
  • What am I not? an
  • The BEST 400 four by far
    • malcnet
« Reply #18 on: April 02, 2013, 01:06:38 PM »
BP took over Castrol in 2000, back then it was BP Amoco after the 1998 merger of British Petroleum and Amoco.
Malcolm
1977 CB400F
1973 CL175 K7
1976 XL175 - Sold
1964 CL72
1966 CA78
Offline 750K
« Reply #19 on: April 02, 2013, 01:56:16 PM »
More popcorn Gif's please, I love those.
77 Cb750, 78 Kz1000
Offline deafcaferacer
  • "I'm sorry officer, I can't hear you!"
« Reply #20 on: April 02, 2013, 02:04:49 PM »
popporn?
'73 CB750k engine, hubs, and a '76 tank, on 'a 78 frame. Go figure.
Offline Lostboy Steve
« Reply #21 on: April 02, 2013, 02:22:19 PM »
I run the 10w-40 Castrol Actevo Motorcycle oil. However during break-in I ran a conventional 10w-40 motorcycle oil. I wonder if I should try the Actevo v-twin 20w-50 in the summer. I imagine it would be well suited for higher temps.
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
« Reply #22 on: April 02, 2013, 05:00:38 PM »
« Reply #23 on: April 02, 2013, 05:02:16 PM »
Offline Magpie
« Reply #24 on: April 02, 2013, 05:20:27 PM »
Alright. How do you delete a thread?
Here, let me take you're mind off oil!
