Author Topic: First post, pics (A LOT) and a few questions to ask ('73 CB500 Four)  (Read 18543 times)
Offline wowbagger
  • Not much of an
Re: First post, pics (A LOT) and a few questions to ask ('73 CB500 Four)
« Reply #50 on: June 08, 2013, 05:50:37 PM »
So, now that you did all that work for the clutch rod, I found that Ronnie's Cycle in MA has brand new ones in stock. I bought one but they said they had two left. 413-743-0715 is the number.
« Reply #51 on: June 08, 2013, 05:52:50 PM »
i remove the centre stand,i just slip it on for chain or rear wheel service less all the spring etc,i had to do this to mine for it to clear the 4-1 when its used.
« Last Edit: June 08, 2013, 05:58:26 PM by dave500 »
Offline nIkbot
  • nIkbot
  • '73 CB500
« Reply #52 on: June 17, 2013, 09:46:37 PM »
Getting everything together, all the Hondaman equipment and new running lights all seem to be in order.. go to throw some fuel in the tank to test for leaks, flow is nice, but all four carbs overflow tubes and the airbox overflow are running.. :(
Perfect fuel in tank
Perfect fuel in lines and filters
Piss from overflow tubes
Does this mean carb rebuild? or is there something I'm missing?
Hoping that them sitting in fuel over night might clear up what ever gunk is messing with the floats.
Pepcock was off all night and woke up to near a full pint of gas from the overflow lines... I'm at a loss and not looking forward to having to pull the carbs if thats the only answer.
« Last Edit: June 18, 2013, 08:58:09 AM by nIkbot »
'73 CB500 upgrades a'comin
Offline nIkbot
  • nIkbot
  • '73 CB500
« Reply #53 on: June 19, 2013, 01:31:23 AM »
just finished cleaning and adjusting floats... No more overflow.
tomorrow morning is putting the battery on and giving the first kick.
Nervous night to wait through now... whats left of it at least.
« Last Edit: June 28, 2013, 10:38:16 AM by nIkbot »
Offline db22
  • Old and in the way.
« Reply #54 on: June 19, 2013, 06:51:58 AM »
Following . . . good luck on that first kick.
1975 CB550K (rider)
1975 CB550K (shaping up, slowly)
I may be goin' to hell in a bucket, but at least I'm enjoyin' the ride. . .
Offline nIkbot
  • nIkbot
  • '73 CB500
« Reply #55 on: June 19, 2013, 09:25:16 PM »
shiiiiiit.
Owell. New flasher here friday.
No spark so far it seems and no headlight.
LED running, brake and (solid light blinkers) work. Can hear all the hondaman relays flipping when juice is put on the circuit.
Offline nIkbot
  • nIkbot
  • '73 CB500
« Reply #56 on: June 28, 2013, 06:25:53 PM »
Recovering from an abdominal hernia surgery so not much progress has been made.
I acquired an LED rated flasher unit and now have full LED running/brake/turn working, quite exciting.
Started to make the new inner fender.
I wanted to make a new one out of fiberglass, so I wouldn't have to cut the original up to meet my needs.
Pleased with the result so far, now to strengthen it up in key spots, cut the top half off at the mark and build it out under the tail, then find an appropriate gel paint.
I was able to test my repair/mini fab I have been dreading.
When rebuilding the handlebars, I stupidly lost the kill/run/kill switch copper bushing that sits above a spring to make contact with the board. I fabed a new one out of a copper washer I had laying around. Cut a small piece off and used some duck noses to flatten and straighten it out. Took a little fitting but i went together seemingly alright.
Today I was able to get under the gas tank and test the Black/White tracer into the coils and found that this little fab is in fact working perfectly. I was quite excited then quickly reminded that this now means I have no clue as to why I don't have a spark.   :/
I really am getting antsy to get this fired, everyones help so far has been invaluable.
What are the steps forward in trouble shooting, that I can take to try and figure this one out?
« Last Edit: July 06, 2013, 06:32:12 PM by nIkbot »
Offline nIkbot
  • nIkbot
  • '73 CB500
« Reply #57 on: August 25, 2013, 11:53:06 PM »
Hey all, hope everyone has had a good past few weeks.
i finally started back up tinkerin on the bike. Got to do some work with dad and now have a very strong spark across all four cylinders.  No fuel is making into the cylinders tho. So I reluctantly pulled the carbs today.
One of the carb synchronization springs snapped as soon as I touched the nut holding it down. Fabbed up another out of a soldering iron stand.
Found a couple of the main jets where completely blocked off.
Gave everything a soak and a scrub.
Now I have two more problems that any answers/tips on would be greatly appreciated.....
First, three of the four bowls have cracked overflow tubes.
Found this forum post, http://www.kzrider.com/forum/3-carburetor/512328-overflow-pipe-crack. Has anyone here tried this fix?
Second, I bought four carb rebuild kits, they are Keyster company and for CB500 71-73... But I noticed that the slow jet is a different size/different sized holes, but the same threading and both are marked #40? Is this of no consequence? or should I clean up and throw the original slows in there?
Thanks again for the help everyone.
Offline LesterPiglet
  • 1977 CB550F2
« Reply #58 on: August 26, 2013, 02:44:32 AM »
Did you pull and clean the emulsion tubes? I don't see them in your picture.
Offline Scott S
« Reply #59 on: August 26, 2013, 03:29:35 AM »
 Use the Keihin slow jets! Those aftermarket jets gave me FITS in my CB500 carbs. In fact, use ALL of the original jets and needles if possible. Make sure you clean the emulsion tubes. I would use the aftermarket gaskets, needle valves, O-rings and maybe the seat valves. Otherwise, the stock stuff is better unless it's damaged.
 Make sure your in tank filter or sediment bowl filter is in good shape. It wouldn't hurt to run an inline filter for a few tanks of gas, but if the stock filters are in good shape, you shouldn't need one.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline wowbagger
  • Not much of an
« Reply #60 on: August 26, 2013, 05:55:52 AM »
For the cracked overflow tubes, there are a couple threads on here with two different methods of fixing. Some have just soldered the crack with good success. Others have used a larger piece of brass pipe and tapped it down over the existing tube. I myself soldered my and haven't had a issue since.
http://forums.sohc4.net/index.php?topic=113169.0
« Last Edit: August 26, 2013, 05:58:18 AM by wowbagger »
Offline nIkbot
  • nIkbot
  • '73 CB500
« Reply #61 on: August 26, 2013, 08:39:36 AM »
That's todays project. I was getting frustrated and tired by 2am last night. Especially after realizing the slow jet and even boots were not correct.
Is there a safe procedure to removing them? I assume remove the top slide and needle and push from top with something soft?
They are in there good... No clue how to loosen them.
CHOPSTICK TO THE RESCUE!
That's crap. Upset I got these keyster packs now. So I guess I will soak and clean the old slows, ever other part seems to match up dead on. I just restored the tank, petcock and have new lines + filters.
Seems to be the common answer is to try and solder. Guess I need to head down to the hardware store and see what my options available are. Or if they even have brass tubing. Do you have any tips on what anti flow to use to not have the overflow fill with solder?
« Last Edit: August 26, 2013, 09:44:21 AM by nIkbot »
Offline Scott S
« Reply #62 on: August 26, 2013, 05:24:45 PM »
 Chopsticks are EXACTLY how I've removed them in the past! It's amazing how gummed up they get...and how much better the bike runs when they're clean.
'71 CB500 K0
'81 Yamaha XS650
Offline nIkbot
  • nIkbot
  • '73 CB500
« Reply #63 on: August 26, 2013, 10:12:07 PM »
"Hey Dad! Can I get some gas?"
>:l  Never. Again.
ON THE PLUS SIDE SHE LIVES!!!!!!!!! needs to be tuned, but runs! Bogs after 4k, won't idle.. BUT RUNS!!!
bonus stewie dance pj's as shop pants.
1973 Honda CB500, First night running.
Thank you to everyone who has helped so far. I'm quite excited its finally running... Upset it had to happen at midnight when I can't continue to tinker, but its a great success!
« Last Edit: August 26, 2013, 10:24:31 PM by nIkbot »
Offline nIkbot
  • nIkbot
  • '73 CB500
« Reply #64 on: August 28, 2013, 10:18:30 PM »
Made seat pan to get by with out of an old chevron today.
The bike will idle on its own now when its warm at ~1200-1300
went for a ride around town that turned into an hour long ride through the mountains.
Offline Tews19
  • I am no
« Reply #65 on: August 29, 2013, 05:54:38 AM »
Very cool bud! Coming a long way and the PJ pants are very stylish......
Is that a yellow 911?
1970 Honda CB750 survivor.
Offline nIkbot
  • nIkbot
  • '73 CB500
« Reply #66 on: August 30, 2013, 10:36:49 AM »
The Porsche I picked up years ago from a client for $300 and a lil electrical work. Cheaper than the CB actually. It's a '77 ROW 911 with steel wide body and whale tail, 2.7L. Picked it up when finances where better, so the main project has been the CB.
Went out for a full day yesterday on the CB, guessing I need to invest in new friction/clutch plates as it slips under hard excellereation, high gear accel and is. Not happy around 3500-4000rpm.
Offline Tews19
  • I am no
« Reply #67 on: August 30, 2013, 01:23:20 PM »
3500-4k is a well documented flat spot. .. These bikes are known for it....
Offline Deltarider
« Reply #68 on: August 31, 2013, 12:55:27 PM »
Can't believe my eyes. Overhere you would't even be able to get a wheelcover for that.
CB500K2-ED Excel black
Offline nIkbot
  • nIkbot
  • '73 CB500
« Reply #69 on: October 08, 2013, 04:46:25 PM »
Still tracking down the fuel flow issue and need to finalize sync/tuning, but got a nice quick ride in today to test the work I did on the vent cap.
https://www.youtube.com/watch?feature=player_embedded&v=yuauXpcY2-w
« Last Edit: October 08, 2013, 04:48:06 PM by nIkbot »
Offline Tews19
  • I am no
« Reply #70 on: October 08, 2013, 07:26:18 PM »
Damn, if that is your property? Well congrats!
Nice video, bike needs to have the carbs synced and the cam tensioner adjusted... Clunky noise would drive me nutz but I am thinking that is most likely the carbs out of sync
Offline Tews19
  • I am no
« Reply #71 on: October 08, 2013, 07:27:38 PM »
What camera you use?
Offline Tews19
  • I am no
« Reply #72 on: October 08, 2013, 07:30:35 PM »
I laughed when I heard yelling around the 530 mark... What were you saying.. Sounded funny as hell
Offline nIkbot
  • nIkbot
  • '73 CB500
« Reply #73 on: October 08, 2013, 09:18:50 PM »
The saying, "My family does well, I have nothing." comes to mind..
I thought the cam tensioner self adjusted? Is this simple to get at and do? I just figured its the horrid sync giving me that clunk.
Cam is a Hero3Black 1080p@60fps. Using the Youtube video stabilization... only mount I can do right now is on the handlebars.
I always worry about riding here in NJ... everyone is always not paying attention or over the line...
The Big Lebowski - OVER THE LINE!
