Author Topic: Has anyone laced a CB750 18" rear to a front hub?  (Read 1715 times)
Offline tango911
« on: April 25, 2013, 06:27:09 PM »
Im building a set of wheels for a guy and ive never been asked to do this. I would assume i need shorter spokes but ive alwasy used stock.  Any one know a company that will make them for me and not cost a fortune?
Steve
heres the wheels i built for my H1
CURRENT STABLE:
1969 Honda Dream 305 (black)
1974 Mach III kawi 500 smoker
K2 (project)
K2 Original fixer up
K0 original fixer up
2006 CRF250R
Re: Has anyone laced a CB750 18" rear to a front hub?
« Reply #1 on: April 25, 2013, 06:39:36 PM »
Havent done it and wont, but Buch's will make whatever you need. Call...
http://www.buchananspokes.net/
Offline Dave Voss
« Reply #2 on: April 25, 2013, 07:06:12 PM »
The holes for the spoke nipples are drilled at a greater angle from the center of the dimples for rims that are to be installed on drum hubs, so I wouldn't recommend using a rear CB750 rim on a front disc hub, as the spokes will need to be at a different angle for a front disc hub.  There are other applications that used a 18" front rim, years ago I found a 18" x 1.85" rim from a parted-out Kawasaki that I installed on a CJ360T twin front hub, and since it had a (narrower) 18" rim as stock, so the stock spokes worked fine.  It's possible that the CB/CJ/CL360 stock front spokes will work for the CB750 as well when switching from a 19" to a 18" rim, as they use the same front brake rotor, and so the hub may be the same diameter as well.
-Dave Voss
(past) '78 CB550K4
(past) '75 CB550K1
(now) '95 R1100RSL
Offline tango911
« Reply #3 on: April 25, 2013, 07:10:57 PM »
I hadnt thought of the angle of the much bigger rear hub.  Thanks for that!!  I will suggestion he go with the stock size unless he's adimat about having an 18" front rim. Thanks for the extra info!!
steve
CURRENT STABLE:
K2 (project)
2006 CRF250R
Offline lucky
« Reply #4 on: April 26, 2013, 12:22:11 AM »
The outside diameter of the front and rear tire are almost the same even though the rim diameters are different. Check that and you will what I mean.
 Rim Diam Inches + [ (2 x Aspect Ratio x Section Width) / 25.4]=Tire OD on the rim.
« Last Edit: April 26, 2013, 12:27:25 AM by lucky »
Offline tango911
« Reply #5 on: April 26, 2013, 05:45:10 AM »
I hear ya.  this dude just thinks he has to have it. But im going to talk him into running stock or buying new rims if he really wants it.
CURRENT STABLE:
K2 (project)
2006 CRF250R
Offline tango911
« Reply #6 on: April 26, 2013, 07:54:35 AM »
are there places i can order new aftermarket rims that would/could match up?
CURRENT STABLE:
K2 (project)
2006 CRF250R
Offline brandEn
« Reply #7 on: April 26, 2013, 07:58:46 AM »
These guys can do anything you need.
