Author Topic: 1978 CB750F bringing it to life  (Read 3463 times)
Offline Soko
« on: May 15, 2013, 09:41:32 AM »
Hi guys,
I got myself 78 cb750f from a barn, it is in very rough shape. My aim is to build cafe racer. I got it last week for 200$. I am not mechanically experienced however I have used few tools. The plan for bike is to be ready for next May. I have attached few picks.
Offline Vinhead1957
Re: 1978 CB750F bringing it to life
« Reply #1 on: May 15, 2013, 01:10:23 PM »
Looks like you have a great project on your hands. A steal at 200.  I treated mine as a learning experience. The problems were there to solve one at a time. Don't rush, getting there is half the fun.
Offline Mercutiojb
« Reply #2 on: May 15, 2013, 04:29:58 PM »
It's got a lot of potential! I'll be watching...
« Reply #3 on: May 16, 2013, 03:25:39 AM »
Good project, how many miles on it?
Offline Soko
« Reply #4 on: May 16, 2013, 04:12:37 AM »
Bike has 25 000 miles.
I have fixed dents in tank as much I could, should I use muriatic acid before I use bondo (everglass by evercoat)?
« Reply #5 on: May 16, 2013, 04:36:01 AM »
Due to the way the 78F was designed, they tend to wear out valve guides.  Before you get too far, do some research on it;  I been there myself, got F3 engine for a good price, but it needs new guides, valves - the whole head rebuilt basically.
I am not saying yours is that way, just something to be aware off.  I could have gotten some miles out of it the way it was but I wanted to fix it for good before I put the engine back in.
Don't shoot the messenger, man  :)
Offline Old Scrambler
« Reply #6 on: May 16, 2013, 06:38:44 AM »
A good acetone bath will prevent oxidation for a short time. Do not touch with bare hands. Nice work on the dent so far. Do the filler ASAP and let it cure in a low-moisture atmosphere for several weeks before final sanding and paint. My painter uses shadow-lighting to detect small irregularities and then sprays a heavy layer of sanding-primer for the final prep to paint.  Have your decals or lettering handy so they can be sealed with the final clear-coat.
Great starting point. Even if the head needs valve-guides, its worth $200 or more by itself to anyone building a performance motor.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Offline Soko
« Reply #7 on: May 26, 2013, 08:16:35 PM »
Update over weekend,
first of all thanks Old Scrambler for tips. Gas tank been primed, after priming I noticed another little dent ( I had about 7 dings that I had to fix, this one I didn't noticed until priming), engine has been pulled out of bike. I had little bit trouble pulling it out before I removed oil filter. Also, I found out Oil filter bolt was busted but I managed to get it out.
I am planning to add a hoop and brat seat, should i be worried riding two up and tire touching seat?
« Last Edit: May 26, 2013, 08:18:59 PM by Soko »
Offline Soko
« Reply #8 on: May 28, 2013, 06:23:24 PM »
I just started to remove Valve cover and found this hole beneath breather plate, is this big issue?
Offline Stoli
« Reply #9 on: May 28, 2013, 06:29:44 PM »
I'm pretty sure that's normal. That's what makes it a "breather". If there wasn't a hole, that chamber wouldn't serve much purpose.
My Project Threads:
Project #1 - http://forums.sohc4.net/index.php?topic=117106.0  First bike
Project #2 - http://forums.sohc4.net/index.php?topic=127364.0  Something different
Project #3 - http://forums.sohc4.net/index.php?topic=123831.0  Long and Low
Offline Soko
« Reply #10 on: May 28, 2013, 06:44:50 PM »
Thanks for the quick answer!
« Reply #11 on: May 29, 2013, 03:23:40 AM »
I will check my head cover when i get home.
Offline Bankerdanny
  • Endeavor to persevere
« Reply #12 on: May 29, 2013, 09:15:52 AM »
That looks pretty ragged for a factory opening.
« Reply #13 on: May 29, 2013, 01:35:49 PM »
Got the same hole on my F3.
Offline Soko
« Reply #14 on: May 29, 2013, 05:42:16 PM »
Thanks man for the picture, saved me lot of time
« Reply #15 on: May 30, 2013, 03:21:00 AM »
Glad I could help.
Offline Frankensteins Bride
« Reply #16 on: May 30, 2013, 05:41:43 AM »
I  have the same hole on my 78 k. They are horrible looking holes that gives us unsuspecting owners heart attacks. LMAO  :P
Working on: 78 Cb750k
Waiting for arrival: 73 Cb750
Frankensteins Wolf
