Author Topic: annunciator delete, gauge change, How to??  (Read 1137 times)
Offline b5rider
« on: May 31, 2013, 06:26:13 AM »
can I switch out my 550 gauges for the ones used on the 750's?
I want to get rid of the idiot-light cluster so I can mount my phone/GPS right in the middle, and I think the 750s have the lights built into the gauge
Also, how do I disconnect the turn signal annunciator because it draws too much current at idle.
Thanks
1984 Honda Elite 150
1998 Yamaha 650
2004 Honda 750 ACE
1975 CB550
1978 CB400A
1978 CB550 now 603cc w/sidecar
The key to life is to make sure the line to put flowers on your grave is longer than the one to piss on it.
Offline RFogelsong
Re: annunciator delete, gauge change, How to??
« Reply #1 on: May 31, 2013, 06:33:39 AM »
They're (gauges are) the same size, but check on tach/speedo ratios first.  The buzzer disconnects from the harness in the headlight bucket and you can just pull it off the bike then.
-Rob
Hondas past/present:
SOHC1:'74 CB125, '78 XL125
DOHC2:'71 CB450K
SOHC4:'73 350F, '75 400F, '75 550K
DOHC4:'81 900F, '01 1100XX
V4:'85 VF1000R, '86 VF500F, '08 VFR800
Offline Xnavylfr
« Reply #2 on: May 31, 2013, 06:37:49 AM »
I'm sure the RATIO is the same for all HONDAS. The T/S buzzer can  just be disconnected. It only has 2 wires with bullet connectors about 3" from the buzzer.
Xnavylfr(CHUCK)
Offline Greggo
  • Somebody's
  • Helmets Save Lives. Period.
« Reply #3 on: May 31, 2013, 08:24:15 AM »
Xnavylfr(CHUCK)
Nope.  The tachometer ratio is different between 500/550's and 750's.  Speedometer drive ratio is the same.
Offline bjbuchanan
« Reply #4 on: May 31, 2013, 09:09:07 AM »
Take the buzzer off or disconnect brown/blue in bucket
Offline b5rider
« Reply #5 on: May 31, 2013, 09:22:34 AM »
thanks!
The buzzer seems to die off after 15 seconds at the light unless I rev the bike past 3k RPM. I really only need the neutral light. Any one know if that is included on the speedo? That way, I just need to change out the speedo and keep the tach ( I could just wire it up, but it would be nice to have it labeled correctly)
1998 Yamaha 650
2004 Honda 750 ACE
1975 CB550
1978 CB400A
Offline RFogelsong
« Reply #6 on: May 31, 2013, 10:17:16 AM »
Neutral is in the tach and your buzzer is dying at low rpm because you're not charging below, like, 2000 rpm on these bikes... voltage is just getting low enough to not fully power all the lights and buzzers and such.  It's pretty common if your battery is not charged up fully proper.
-Rob
DOHC2:'71 CB450K
« Reply #7 on: May 31, 2013, 10:43:28 AM »
That's what I use as the bikes voltmeter!  Buzzer stops as the battery volts fall.  Increase RPM to put the energy back into the battery.  Buzzer doesn't draw much power at all.
It's funny you want to eliminate the symptom rather than the cause.
"Doc, it hurts when I do this."  "Well, don't do that!"  ;D
Cb750 Tachometers have a different ratio than 550 tachometers.  I used one for years, never could get the needle to red line.  Even though I tried frequently.  Poor motor.  I still don't know exactly why it didn't fly apart.  Robust little motor, that.  Probably why it could use new rings. ::)
« Reply #8 on: May 31, 2013, 11:09:17 AM »
As to the CB750 idiot lights: only the K0 and K1 have the lights in the gauge. Then they switched to the cluster on the barclamps.
Since the in gauge style is truly rare, good ones go for more than you would want to pay, probably.
Besides the drive ratios.
Offline wowbagger
  • Not much of an
« Reply #9 on: May 31, 2013, 11:16:57 AM »
There are places that sell aftermarket gauges with integrated idiot lights that have the proper ratio like Dime City Cycles. I believe the 500/550 have a 1:7 ratio.
Alternatively, (and I hate to plug my own stuff but...) you could just relocate the bulbs somewhere else on the bike using something like the 3mm LED pilot lights I make:
http://forums.sohc4.net/index.php?topic=122234.0
Offline b5rider
« Reply #10 on: May 31, 2013, 06:41:21 PM »
thanks.
you guys are awesome
1998 Yamaha 650
2004 Honda 750 ACE
1975 CB550
1978 CB400A
bollingball
« Reply #11 on: May 31, 2013, 06:58:29 PM »
Xnavylfr(CHUCK)
I am sure that is not correct. But you are correct about just unpluging it however it will tell you your voltage is low and like TT said that can be a tool.
Ken
Offline b5rider
« Reply #12 on: June 01, 2013, 11:26:24 PM »
I'm sure my charging system is weak. I just put the battery on a trickle charger couple of days a week  and she starts right up whenever I need her to. I'll have to tackle that issue after the summer, along with a new chain, change the fork seals, and various other maintenance items. I'm just glad the carbs, tranny, and engine work well. The rest of the stuff I can deal with.
1998 Yamaha 650
2004 Honda 750 ACE
1975 CB550
1978 CB400A
