Author Topic: Double banjo bolt?  (Read 579 times)
Offline SKTP
Double banjo bolt?
« on: June 17, 2013, 12:58:50 PM »
Ok...so I almost have all the parts for my double disk conversion.
I am missing the bolt that will go into the master and hold the 2 banjo bolts...
What is this bolt called? I'm having some trouble finding it.
Are all banjos the same so the 2 hole on the "double-bolt" will line up with out issue?
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Re: Double banjo bolt?
« Reply #1 on: June 17, 2013, 01:06:03 PM »
slingshot cycles...
http://slingshot-cycles.com/products-page/bolts-washers-switches/double-banjo-bolt-m10x1-25-most-hondas/
Offline SKTP
« Reply #2 on: June 17, 2013, 01:14:55 PM »
BOOM!
Thanks...exactly what I need. I bought my lines there already, wish they had gone for the up-sell/add-on
ordering now
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
« Reply #3 on: June 17, 2013, 01:52:09 PM »
I made my own double banjo bolt, because I am a cheapa$$, but you can't go wrong with anything from slingshot cycles.  Get copper washers too, if you are placing order now, and more than you need, they tend to get lost in the shop - don't ask :)
