Author Topic: Steering head beariings  (Read 14557 times)
Offline kach_me
« on: August 05, 2006, 04:35:31 PM »
I need to replace my steering head bearings.  Anyone have a simple, step-by-step of how to do so?  (with pictures?) I would like to attempt this repair as I think that I can do it, but I don't want to foul things up by just jumpin' in blind either.
I've got a 1976 CB750 and I'm thinking about using tapered bearings instead of ball bearings.  Any thoughts?  Also, will the tapered bearings make the bike handle better or will they simply wear longer?  Or am I just plain full of #$%* on my thought process?
1976 CB 750K - Stock / No mods (yet).
Offline cbjunkie
  • ...know what i'm sayin'?
Re: Steering head beariings
« Reply #1 on: August 05, 2006, 05:03:40 PM »
kach - this is a really good place to start...HONDAMAN
http://www.sohc4.us/forums/index.php?topic=7401.0
1971 750K1
1972 CB350 (deceased)
sometimes naked, sometimes mad -
now the poet, now the fool -
thus they appear on earth,
the free men.
Offline super pasty white guy
  • I'm not really a
  • 1976 750 F
« Reply #2 on: August 05, 2006, 05:19:00 PM »
I just did this-  The timkin numbers in the HondaMan post are no longer correct.  I wound up using an "All Balls" kit purchased off ebay.  Simple and easy.  If you want to go timken, contact hondaman-  he's working on making them fit correctly.
DAve
Offline cbjunkie
« Reply #3 on: August 05, 2006, 05:22:33 PM »
good call pasty - i went with ALL BALL as well - recommend you go to Z1 Enterprises for these.
1971 750K1
the free men.
Offline Bodain
  • I love the smell of fresh asphalt in the morning!
« Reply #4 on: August 05, 2006, 05:37:19 PM »
I did it. Pretty easy. I see percieve no difference from individual stock bearings so unless you really need it. Why waste the dollars.
2009 Suzuki TU250
2014 Honda Grom
1988 Yamaha FZ600
2018 Honda Ruckus
1971 Honda CB500
Offline 750goes
  • it will live
« Reply #5 on: August 05, 2006, 06:25:25 PM »
If your old balls are worn out, then it's time to change them.
Instead of stuffing around with replacing races, checking old balls, regreasing old balls, dropping old balls when removing them and taking two hours to find the rotten little buggers, it really is easy to change them to tapered bearings.
Just have all the necessary tools ready and be methodical about the process.
When I replaced mine, I had the triple clamp powdercoated, and this didn't help in pressing the bottom bearing onto the clamp.
Knocking out the old races is simple - screwdriver and hammer from the inside of the steering neck. Just work you way around the race with a couple of hits each time, it won't take long for it to fall out.
The rest is easily done, you may need someone with a hydraulic press to fit the bottom bearing on the triple clamp, don't forget your spacer washer at the bottom either.
Last of all don't forget to pack the grease into those bearings..
Go get dirty... :)
Offline Dave K
« Reply #6 on: August 05, 2006, 07:00:48 PM »
I did mine about a dozen years ago. My bike had over 40,000 miles on it and the original were getting "notchy" feeling. On a brain fart one night about midnight, I felt the urge to do it, since I had the tapered bearing kit on hand. I was riding the bike by around 2am. It was a simple straight forward job. Does the bike handle better? Well yes, better then it did with the wore out bearings. I feel it is the only way to go, if you are in need of replacing these bearings anyhow.
« Reply #7 on: August 05, 2006, 09:13:21 PM »
I'm currently making a "pictorial tutorial" of this process, for the CB750. At the moment, I have the upper beariing cups ground to size (10 sets) to use the Timken 07100 stock size bearing. I'm now working on the L45(nnn) series lower bearings, cups and races, or some combination that will work.
The parts I used to install in CB750/500 in 1972 (30mm I.D. lower bearings) are not made anymore, and the combination of parts often used in those (green-boxed) Japanese "kits" perform poorly over time. So, I'm working up a Timken "kit", or maybe FAG bearings, as they are just as tough, because mine went 90,000+ miles before developing an ever-so-slight notch.
I will also be making spacers to fit these bearings. The typical installation should take about half a day, if you've never done it before and if you have the tools on hand.
Offline puppytrax
« Reply #8 on: August 06, 2006, 09:08:41 AM »
I would be interested in buying a "kit" for my CB500.  :)  I can still recall the "notchy" feeling of worn ball races on my old Triumph. Not very confidence-inspiring...   :(
...stock 1972 CB500 '500 Four' undergoing re-assembly...
...Stock 1972 CL450 'Scrambler' also being re-assembled...
« Reply #9 on: August 09, 2006, 03:44:06 PM »
If the notches get big enough, you can ride hands-off for miles in Nevada!
Offline cbjunkie
« Reply #10 on: August 09, 2006, 09:21:04 PM »
the voice of experience!  ;D ;D thanks for all the great advice, Hman - i'm re-installing the old set and  moving to Nevada!
1971 750K1
the free men.
Offline puppytrax
« Reply #11 on: August 10, 2006, 07:03:43 AM »
MR Cycles still lists the 22-1011 tapered bearing set...
MR Cycles
ALL BALLS STRG STEM BRGS
22-1011    $42.95
    * Designed as a drop-in replacement to upgrade OEM ball-type bearings to taper bearings (where ball-type bearings are used by the OEM)
    * Designed as a replacement taper bearing seat (where taper bearings are original equipment)
    * Kits come complete with both upper and lower taper bearing cups and cones and seals (both top and bottom seals are included in most kits, if applicable)
    * Tapered roller bearings decrease maintenance along with less wear and longer life
http://www.mrcycles.com/eshopprod_cat_2411-19104_product_257675_keyword_22-1011.STEERING_STEM_BEARINGS.htm
Also a very nice chart showing which bearings interchange with which models...  :D
BTW: This is the bearing set that Stephen Bottcher used in his writeup in the Suspension FAQ...
http://www.stephenbottcher.net/Honda/tapered.htm
Thank You, Sir! Good writeup!!
« Last Edit: August 10, 2006, 07:28:09 AM by puppytrax »
Offline kach_me
« Reply #12 on: August 10, 2006, 03:20:53 PM »
THANK YOU!   Just what I was looking for... $42.95 sounds pretty reasonable too!
Offline puppytrax
« Reply #13 on: August 10, 2006, 03:53:04 PM »
The writeup is excellent...but I'm a bit confused as to why Stephen thought he needed the 4mm spacer in the first place...and he was a bit unclear as to whether it actually *was* needed or not...I assume it is not...
I put in an order for some parts including the 22-1011 kit (sorry, Hondaman!)...Haven't heard from MR as to it being available, but they typically do not notify you unless it is *not* available...
It is really amazing what all is still available for these old SOHC4's...the native Japanese market must drive the continued availability of this stuff...
Offline cb650
« Reply #14 on: August 10, 2006, 04:31:52 PM »
My son likes the all balls sticker in the kit.
                      Terry
« Reply #15 on: August 13, 2006, 07:13:12 PM »
I'd be interested in knowing how the installation goes, and how the longevity pans out. Take pix, if you can. I you want, forward them to me by PM and I'll include them in the "step-by-step" thing I'm making. I can show the "standard" method alongside the All Balls method - or parts.
There is also a type of ball bearing that might drop right in: it's a side-mounted ball-loading type. Very interesting: I'm trying to get one to try it out. I have a spare frame for this little "project".
Offline puppytrax
« Reply #16 on: August 13, 2006, 07:23:00 PM »
I'd be interested in knowing how the installation goes...
... ;) ;D 8)...
I'm sure whoever does it will post bearing manufacturer and part numbers, as well as any problems or concerns in installation. Longevity...I don't know about you, but if they last as long as the OEM bearings, then I'll be long gone before these even wear in...   ::)
BTW: Z1 has tapered stem bearings also; K&L (?) brand -
Steering Bearing SSH750 26x48.5x15.2 30x50x14.4
KL31-5830
K&L
Steering Bearing SSH750 26x48.5x15.2mm 30x50x14.4mm
Fits Honda CB350/F/F1/G/K2-K4 CL350/K2-K4 SL350/K2/K3 CB360/G/T CJ360T CL360/K1 CB400A/F/T1/T2/T CM400A/C/E/T CB450/K1-K7/SC/T CL450/K2-K6 CM450A/C/E CB500/K1/K2/T CX500/C/D FT500 GB500 GL500/I VT500C/FT CB550F/K/K1/SC CB650/SC CX650C GL650/I VT700C CB750A/F/K GL1000/L
$43.16
http://z1enterprises.com/detail.aspx?ID=1503
I included the All Balls kit with an order of Honda parts from MR Cycles, but the Z1 kit is comparably priced (if not the same kit)...
« Last Edit: August 13, 2006, 07:36:40 PM by puppytrax »
« Reply #17 on: August 14, 2006, 08:08:41 PM »
Yep, that's what I'm trying to do. On the lowers, they've had someone grind the OD on a 55mm bearing cup to 50mm, then bored the 29mm ID to 30mm. It's expensive! The uppers weren't so bad, since only the OD of the cup had to be ground.
Offline GoatBaSS
  • Could someone find an
  • To weird to live, to rare to die.
« Reply #18 on: August 14, 2006, 09:01:46 PM »
You teknikal jar gone confuse Goatbass. Not smart like others. Partsnmore.com send taper kit. Used 1" around pipe and hammer. Tinkle.  All done now...
Leethal # 3046?
1972 CB750K/900CC Red Headed Dunstall, 1975CB750FSS Gone BNF: 1974CB500T, 1976CB750K X 2
benny365
« Reply #19 on: September 13, 2006, 07:39:36 AM »
does anyone know the dimensions for the steering stem bearing for a 1973 cb750.
will this fit a 73 750 also?
Basically I'm looking for the dimensions so I can just go to a local store and buy the bearings
thanks
Offline pelicanwheel
« Reply #20 on: September 13, 2006, 10:59:03 AM »
perfect timing for this post today!  I plan to install my all balls kit tonight!  I have a question though.  I have the kit as pictured in the "puppytrac" post on page one of this thread.  My kit also came with two additional washers of two different thicknesses.  The weak instructions says to measure the stacked height of the lower stem with the original bearings to determine if I need the washers with their kit.  Well the problem is that it's too late to measure!  I also don't know where they mean to use the washers, although I'm pretty sure.
Question:
Why would one Honda 750 of a given year need a washer, but another in that same year would not?  Aren't they all the same in those dimensions?
Are the stems different between years, hence the reason for possibly needing the spacer?
So do the cups get pressed in as far as it will go inside the frame?  There appears to be a ridge that would allow it to bottom out on top of...is this correct?
I will take plenty of pics and post tomorrow - hopefully I'll get response before tonight.
Pelican
« Reply #21 on: September 13, 2006, 11:01:56 AM »
one more thing..the washers with the rubber ring around it (as pictured on page one of this tread), are they suppose to go on the triple tree FIRST, followed by the roller bearings, then the whold thing fit into the frame that has the cups pressed in?
And if I need a space, I assume it goes on the triple tree bottom first, then the washer with the rubber ring, then the bearings, then install into the frame with the cups pressed in.
Does this sound right?
  • I'm not really a
  • 1976 750 F
« Reply #22 on: September 13, 2006, 12:03:27 PM »
That's how I did it when I did mine.
Dave
benny365
« Reply #23 on: September 13, 2006, 01:04:13 PM »
Does your kit give dimensions of the bearing and or could you measure them for me?
« Reply #24 on: September 13, 2006, 08:37:22 PM »
ok benny365 and Hondaman:
Here are the pics with measurements as well as markings on the all balls kit:
On the cups:
kml 26-485h
(the smaller bearing of the two and the "4" looks funny but I think its a "4")
kml 30-50H (the larger bearing)
Its the same numbers on the bearings as the cups they fit in.
