Author Topic: 1978 550K PD46C "parts" question  (Read 3161 times)
Offline free85
« on: July 20, 2013, 09:28:17 AM »
While working on getting my carbs cleaned I found some things I'm just not sure about. I'd appreciate your gentlemen's help with the following:
So air jets:
http://www.flickr.com/photos/99171087@N06/9326341003/#
Now, this is where a possible problem comes up: They all had springs, one of them had a washer (spacer?) and one of them had a small rubber O-ring:
http://www.flickr.com/photos/99171087@N06/9326352395/#]http://www.flickr.com/photos/99171087@N06/9326352395/#
http://www.flickr.com/photos/99171087@N06/9329150556/#]http://www.flickr.com/photos/99171087@N06/9329150556/#
I'm guessing that there should be more washers and more of the rubber O-rings. As always your help is appreciated!
Additionally the slow jet in one of my carbs is damaged. I'd love a recommendation for a replacement (the others seem savable/cleanable).
« Last Edit: July 20, 2013, 11:04:40 PM by free85 »
Offline free85
Re: 1978 550K PD46C "parts" question
« Reply #1 on: July 20, 2013, 10:21:34 AM »
Looks like the PO had #42 slow jets installed as well. Thoughts on this, gentlemen? My first thought is that the manual (I have) says #38.
Are these what we're talking about:
http://jetsrus.com/a_jets_by_carburetor_type/jets_keihin_3L_slow_pressfit.html
Also, in carb 1 and carb 4 there were, what seems to be, felt O-rings up top. Is there a way to replace these guys?
« Last Edit: July 20, 2013, 11:52:06 AM by free85 »
Offline ANDY W
« Reply #2 on: July 22, 2013, 04:20:04 PM »
42 slow jet is the stock size for those carbs
Offline Dave Voss
« Reply #3 on: July 22, 2013, 09:09:51 PM »
Yes, the 1977 model year 'K3' used size 38 slow jets, but the 1978 model year 'K4' used size 42 slow jets.  Each mixture screw should have a spring, a washer, and an o-ring.
-Dave Voss
(past) '78 CB550K4
(past) '75 CB550K1
(now) '95 R1100RSL
Offline brewsky
« Reply #4 on: July 23, 2013, 02:28:58 AM »
So air jets:
The remaining washers and o-rings are likely still in the carb bodies. They are very hard to see when in there.
You can use a thin wire with a short 90 degree bend at the end to fish them out. (guitar string etc.)
66 CA77
78 550K
78 CB750K
02 FZ1
09 GL 1800
Offline Dave Voss
« Reply #5 on: July 23, 2013, 07:30:53 AM »
Yes, when I cleaned my carburetors, all four washers and o-rings remained in the carb bodies, I had to pick each of them out, but thankfully it wasn't too difficult.
-Dave Voss
(past) '78 CB550K4
(past) '75 CB550K1
(now) '95 R1100RSL
Offline free85
« Reply #6 on: July 23, 2013, 08:57:24 AM »
Thanks for the updates and help. I had the feeling the washers and rings might still be in there but I did some fishing with a small wire and couldn't find them. I'll look for them in there some more before I go looking for replacements.
Offline lucky
« Reply #7 on: July 23, 2013, 09:01:14 AM »
The washers go on top of the O ring so the spring end does not damage the O ring.
Make sure the O rings are not damaged. USe a magnifying glass if you need to.
Offline K3Owner
« Reply #8 on: July 23, 2013, 09:40:28 AM »
It is as it is commented above for my '78 550. I used a bent paperclip to remove the o-rings that were stuck in the bores. It's the threads that stop them and they're deep down.
As for the pilots, if they're not damaged, pull and clean them. It only takes a guitar string, some Gumout, and compressed air. I'm not sure that the 3L is correct but I had been looking at it for a while as well. My 42s cleaned up nicely. If I had to purchase, I'd go to Sirius but be sure to measure yours so you can compare. A micrometer is a cheap and useful thing, especially for float height measure and it's $9.99 at Harbour Freight.
http://www.siriusconinc.com/pro-detail.php?pid=&product_id=1109
1978 CB550K4 - yeah, I'm not a K3 Owner - my bad
Offline Bankerdanny
  • Endeavor to persevere
« Reply #9 on: July 23, 2013, 11:08:43 AM »
Use a shop towel around the bottom of the jet before you blow the air through. Jets a basically invisible when compressed air shoots them across the garage, but don't ask me how I know this. LOL
Offline free85
« Reply #10 on: July 27, 2013, 11:29:07 AM »
I've got (what seems to be) clean jets now (air passes through them). I'm reassembling using the gasket kit from Honda. Only problem is I have an extra O-ring I can't figure out. I've got the ones on the air jet, the bowl gasket, the top gasket, the one on the bowl drain, around the tubes running between the carbs, and I've got an extra gasket... in each package. And there's a bag marked "A" and I can't figure out what on earth the O-ring in it is.
Additionally I am missing two of the washers for the needles. Any thoughts on where I might find them? I've look at the local tool stores, no dice.
« Last Edit: July 27, 2013, 01:42:06 PM by free85 »
Offline free85
« Reply #11 on: July 27, 2013, 01:59:28 PM »
This is kind of fun:
Offline Bankerdanny
« Reply #12 on: July 27, 2013, 07:31:22 PM »
The same exact thing happened to me 2 years ago when I did the Carbs on my 77. Just use a drill bit to make the 2nd hole.
Offline brewsky
« Reply #13 on: July 28, 2013, 03:44:41 AM »
Try here:
http://www.siriusconinc.com/pro-detail.php?pid=&product_id=2188
66 CA77
78 550K
78 CB750K
02 FZ1
09 GL 1800
Offline free85
« Reply #14 on: July 29, 2013, 08:54:45 AM »
1) I love this forum
2) The both of you are awesome
   It's nice to know that the washers aren't made out of unobtainium.
