Author Topic: cl350 carb sync  (Read 2926 times)
Offline cmorgan47
  • smaller, lighter, quicker
    • theundergr0und
cl350 carb sync
« on: August 09, 2006, 01:33:50 PM »
does anybody know how to do a carb sync on a cl350?  i have a friend with one, and though i haven't been able to check it out, he claims there are no ports like on all the SOHC4s to put the brass fittings into.
just curious, not my bike.
i love babies...
with a nice chianti sauce and a side of fava beans
Offline Peterbylt
Re: cl350 carb sync
« Reply #1 on: August 17, 2006, 04:01:22 PM »
I used to hold my hand over the exhaust pipes until the back pressure felt the same on each side.
1975 550F SuperSport
1975 GL1000 Goldwing
1979 CM400A Hondamatic
1981 GL1100 Goldwing
1985 CMX250C Rebel
Offline angeldeville
  • You meet the nicest people on a Honda!
Re: cl350 carb sync
« Reply #2 on: August 17, 2006, 10:31:13 PM »
I'm not sure of the procedure but it is supposed to be done by sound...
76' cb750f custom
69' cb750 sandcast
69' CT90
Amen Saviour 750 Chopper frame
and enough parts to build about 6-7 more bikes
Offline Green550F
  • Nothing is as cool as that which you made.
Re: cl350 carb sync
« Reply #3 on: August 18, 2006, 09:07:37 PM »
I briefly read it in my manual. It's kind of a set this then set that method. If you can't find the proceedure send me a message and I'll scan the manual pages for you.
93 Kawasaki Voyager XII
70 Honda CL350 Cafe
Re: cl350 carb sync
« Reply #4 on: August 20, 2006, 10:19:05 AM »
You only need to use two senses for this job, sight and sound. Adjust the cables so that both butteflies open & shut similtaneously. Continue to just barely crack the throttle and release while watching and listening that they both shut down at the same time. You should hear just one click as they shut together. Once you set the opening sync, check at full throttle they should be very close there as well.
