Author Topic: Aluminum Engine Screw Kits - Anyone used one from Probolt or Cyclex?  (Read 1315 times)
Offline vnz00
Hi all,
Im just online about to order either a stainless steel hex head engine screw kit, or one of the aluminum ones.
Im curious to know if anyone has used the aluminum kit and can report if they are a complete kit or just the engine side covers?
Im not against using SS, and understand that they need to be used with anti-seize, but the aluminum is an attractive option if it is as durable.  Its made from 7075 grade if that helps.
Thanks, appreciate all comments.
Steven.
Offline iron_worker
Re: Aluminum Engine Screw Kits - Anyone used one from Probolt or Cyclex?
« Reply #1 on: August 08, 2013, 06:37:48 AM »
I'm running the Cycle X kit in gun metal grey. It includes all the side covers and valve/breather cover but it didn't include any for the chrome covers (points plate/clutch inspection cover). The fasteners seem very strong and I had no issues with the quality but I did have to trim a couple to make them fit. They didn't come with any list of which length bolt goes where or anything so that did make installation a bit tricky. Mostly I just matched up the old with the new but I ended up with a couple that were a bit too long. Easy to cut the off with my dremel and run a die over them to clean up the end threads again.
IW
Offline vnz00
« Reply #2 on: August 08, 2013, 07:23:38 AM »
Thanks for the fast response IW.  Im really leaning toward the aluminum bolts - I dont like seeing the numbers stamped on SS bolts and wasnt after a super polished finish either.  It wouldnt suit my build.  The pics Im seeing of the aluminum bolts arent showing any number or knurling on the heads so Id say my mind is made up ;)
I might see if I can source some aluminum screws to complete the set for the clutch and points cover.  Does this mean they didnt include the bolts for the starter motor cover as well?
Thanks.
Offline lucky
« Reply #3 on: August 08, 2013, 08:27:43 AM »
I would not use the aluminum screws. Th 7075 is very strong and light weight but it is also brittle. If it does break it will break on the threaded portion.
Also when similar metals are used together like stainless with stainless the metal is subject to galling.
If you are racing and every single pound will count against you, then maybe it is worth while.
Black 750K8
« Reply #4 on: August 08, 2013, 08:29:15 AM »
What are the ones from Honda made of and grade?
Offline Elan
    • Vital Motor Parts
« Reply #5 on: August 08, 2013, 08:33:46 AM »
I would go stainless. make sure to put some antiseize on the bolts. I got mine from an ebay seller "alloyboltz" they were all organized very well in seperate little packages.
http://www.ebay.com/itm/HONDA-SOHC-CB750-CHOPPER-POLISHED-STAINLESS-BOLT-KIT-/310153665220?ssPageName=ADME:L:OU:US:1123
76 750k
Offline Muckinfuss
  • "I plan to live forever.....or die trying."
« Reply #6 on: August 08, 2013, 09:21:38 AM »
+1 on the alloyboltz.  good stuff from good seller.
1984 Sportster 1000cc XL
1988 Heritage Softail
1974 CB550
1989 Corvette
« Reply #7 on: August 09, 2013, 10:14:07 AM »
Check the part charts at cmsnl.com where the bolt sizes/lenghts are shown. I check here to be sure to use correct bolt. I was the first person taking the bike appart and I do not trust what I did 30 years ago. :-)
Offline vnz00
« Reply #8 on: August 13, 2013, 03:28:48 AM »
many thanks for all the feedback guys - I ordered a set of SS ones from alloyboltz.  they were a good price too.
if there were no concerns with aluminum into aluminum I would have gone with the probolt/cyclex kit.  they are a nice looking set but if there are long term concerns Id rather steer clear (this bike's a keeper ;)  )
Thanks.
« Reply #9 on: August 13, 2013, 06:33:58 AM »
Good choice
