Author Topic: Points locking screw... M4 x 8 mm  (Read 398 times)
Offline rdp2provia
« on: August 23, 2013, 09:33:30 AM »
Hi Gang,
I'm setting the points and stripped the locking screw pictured below. It's an M4 x 8 mm, however I've only been able to find an M4 x 6 mm and an M4 x 10 mm, locally. Is it safe to use the M4 x 10mm or is that going to protrude too far behind the points plate. TEC Points Plate on a 77 CB550F... Maybe throw on another washer? Appreciate any opinions.
The points look like they're in good shape otherwise.
Rick
Re: Points locking screw... M4 x 8 mm
« Reply #1 on: August 23, 2013, 09:49:17 AM »
Use the M4x10, turn the engine over by hand, if it turns over, leave it like that. If there is a clearance issue, shorten those screws.
Offline rdp2provia
« Reply #2 on: August 23, 2013, 10:06:52 AM »
Thanks! I'll give it a shot!
