Author Topic: MotoGPWerks Pipe CB550 (Jetting and video)  (Read 50562 times)
Re: Jetting Recommendations? MotoGPWerks Pipe CB550
« Reply #100 on: November 04, 2013, 06:25:13 PM »
My bike is blowing fuse still, so no updates
Still?   Sounds like you might have a wire grounding our against the frame?
Offline gregripko
« Reply #101 on: November 04, 2013, 06:27:18 PM »
I blew my main fuse many times and what fixed it was using a dremel bit and lightly sanding the fuse holding clamps (BY HAND....NOT WITH DREMEL).... Just twist it in your fingers and it will remove any corrosion and you'll be back in shape :)
Offline goldarrow
  • one day, i'll be an
« Reply #102 on: November 04, 2013, 06:30:11 PM »
After 4 fuses, I have narrowed down to starter button getting shorted. Haven't have time to work on it after that.
Sorry for being off topics.
CB550 K0
Offline gregripko
« Reply #103 on: November 04, 2013, 07:07:25 PM »
Ah bummer... Hope it's not too tough to fix
« Reply #104 on: November 04, 2013, 07:12:35 PM »
Actually sounds pretty simple.  Slap a new control on
Offline lucky
« Reply #105 on: November 05, 2013, 11:20:50 AM »
When the OP says,
"Actually, I told you wrong on the needle height, it's the stock position which I believe is the 4th from top.  The last person that touched this adjustment (needle) was the Honda shop in Toledo 2.5 years ago, so I'm sure that all settings were stock except my stated mains (105) and air screws (1.25 turns out vs the stock 1.5). "
I am not convinced he actually took the carbs off and checked the needle position.
I do not care who worked on it in the past.
As a mechanic I only deal in actual facts.
Offline gregripko
« Reply #106 on: November 05, 2013, 11:23:41 AM »
Checking and changing needles takes 45min if you're good....
Offline gregripko
« Reply #107 on: November 05, 2013, 05:10:54 PM »
The coupling nuts between the air filter body and the snorkel top is working well..... Still no sputter and less lean backfire now..... Nice pull through the throttles and of course very fast :)
« Reply #108 on: November 05, 2013, 06:19:04 PM »
Great.  Check your plugs?
Offline gregripko
« Reply #109 on: November 05, 2013, 06:31:32 PM »
I'll check tomorrow :)
Offline gregripko
« Reply #110 on: November 06, 2013, 12:03:48 PM »
Plugs look good but cylinder 1 plug looks a little lean compared to the rest... :/ a lot of fuel in the bowl when I've pulled it.... Hmm when I've sprayed carb cleaner around boots there isn't an increase in rpm
« Reply #111 on: November 06, 2013, 04:08:43 PM »
Check your float level
Offline gregripko
« Reply #112 on: November 06, 2013, 05:42:27 PM »
Plugs today 1 - 4 from left to right
Offline Hannibal Smith
  • 3rd Grade Dropout
« Reply #113 on: November 06, 2013, 06:09:50 PM »
Been running the piss out of my MGPWerks all stainless pipe on my 550 and have learned some important things.
My jetting isn't relevant, as I am running CR's with my custom filters.
As stated before, you HAVE to check the float level. I got brand new CR's and slapped them on-$800 carbs, the floats have to be right.......................right? Had a tuning gremlin I couldn't chase down my first week running, then checked the floats. They were so off it was crazy.
The best exhaust gaskets for the pipe are those cylindrical hollow copper ones (mine are Vesrah). I have pulled my pipes 4 times in the last year, and the copper ones seem to definitely work better. You cannot re-use them IMO (some may disagree I suppose) as those pipes have a very small wall thickness and dig a narrow "groove" into the gasket. If you re-use/re-install the pipe you ill invariably not get it exactly at the same position and will get an exhaust leak.
I have been really playing with this neat motor, and have torn it apart quite a few times tweaking stuff. Anyway, I love the pipes.
Follow my build "P38 Racer" in Project section
Offline gregripko
« Reply #114 on: November 06, 2013, 06:16:26 PM »
Yeah I used the copper ones
« Reply #115 on: November 06, 2013, 06:20:55 PM »
The plugs look a little rich if anything to me.  I say run it!
Offline gregripko
« Reply #116 on: November 06, 2013, 07:23:16 PM »
It's very close that's forsure.... It's got a lot of power now :)
« Reply #117 on: November 06, 2013, 07:26:17 PM »
Good to hear.  I'm jealous, I want one real bad but just spent a mint on stock style pipes for my Kaw Z1.  I'll get one though...
Offline gregripko
« Reply #118 on: November 06, 2013, 08:57:20 PM »
It was really difficult to tune for me though but I think it has to do with it's sectional design with spring attachments that sorta causes a little trouble over a solid single pipe
Offline goldarrow
« Reply #119 on: November 16, 2013, 02:14:02 PM »
110 jets
38 jets
Needle clips in 3 notch
1.5 air screws turns out
Stock air box with foam filter
650 cam swap
Motogpwerks pipes
Beautiful ride!
CB550 K0
Offline b5rider
« Reply #120 on: November 16, 2013, 02:40:51 PM »
I need to hear your bike! I'm looking into getting an exhaust and some Race Tech emulator valves for my forks this Winter.
What is the difference between the MAC 4-1 and your exhaust?
Let me know when the next ride is, as I had to work on the last one you invited me to
1984 Honda Elite 150
1998 Yamaha 650
2004 Honda 750 ACE
1975 CB550
1978 CB400A
1978 CB550 now 603cc w/sidecar
The key to life is to make sure the line to put flowers on your grave is longer than the one to piss on it.
Offline gregripko
« Reply #121 on: November 16, 2013, 05:47:13 PM »
Will do... I'll have to post a video with it as well
« Reply #122 on: November 19, 2013, 05:37:14 AM »
Huge, we're talking apples and grapes.  The MotoGP is the best pipe out there
Offline Tews19
  • I am no
« Reply #123 on: November 19, 2013, 07:51:57 AM »
MotoGp looks better IMO....
Sent from my SAMSUNG-SGH-I337 using Tapatalk
1970 Honda CB750 survivor.
Offline gregripko
« Reply #124 on: November 19, 2013, 08:55:45 AM »
Looks great in black! Very nice
« Last Edit: November 19, 2013, 10:05:25 AM by gregripko »
