Author Topic: Connection Problems  (Read 1688 times)
Offline trueblue
Connection Problems
« on: September 08, 2013, 03:37:28 AM »
Anyone else been having problems, for a few weeks I've been getting this message
Connection Problems
Sorry, SMF was unable to connect to the database. This may be caused by the server being busy. Please try again later.
Then tonight I got this one.
Welcome to nginx!
If you see this page, the nginx web server is successfully installed and working. Further configuration is required.
For online documentation and support please refer to nginx.org.
Commercial support is available at nginx.com.
Thank you for using nginx.
« Last Edit: September 08, 2013, 03:39:25 AM by trueblue »
1979 CB650Z
Offline petercb750
Re: Connection Problems
« Reply #1 on: September 08, 2013, 03:47:40 AM »
No messages here, but slow to open, but that might be the network (using the phone).
1972 750/4 K2 (his), 1976 400/4 (hers)
1982 CB1100RC (ours)
Offline mick7504
« Reply #2 on: September 08, 2013, 03:54:34 AM »
Been getting similar things as well mate on the phone & tablet.
The last one was tonight - 405 Error or something like that.
Pisses me off.  ;D
It's been happening for a week or more.
If I was you
I'd be worried about me.
Offline bert96
  • past ride
« Reply #3 on: September 08, 2013, 04:16:36 AM »
Same thing here.
Bert
QA50 1969,ST-90 1974,mb5 1982,rz350 1983,shadow 1100 1985,vf1000f 1985,BMW K1 1990,shadow tourer 1100 2001,vfr 750 1994,vtr250 199?
Offline Glenn Stauffer
  • Administrator
    • The SOHC/4 Owners Group
« Reply #4 on: September 08, 2013, 05:22:13 AM »
Let me know if things haven't improved.  I did some tuning this weekend, which messed it up even more, then upgraded the server and did some more tuning and that seems to have resolved most of the issues; at least as far as I can tell at the moment.
« Reply #5 on: September 08, 2013, 05:39:55 AM »
Yes, same experience for last few weeks.
Thank you for all the work you do!
« Reply #6 on: September 08, 2013, 05:56:35 AM »
Seems to just stall out a lot, won't open or move, just searches. If I right a post cross the fingers it takes sometimes.
Offline simon#42
  • liverpool
« Reply #7 on: September 08, 2013, 07:17:57 AM »
yep same here , no messages but slow sometimes and stalls .
Offline trueblue
« Reply #8 on: September 09, 2013, 04:05:49 AM »
Thankyou for the work you do on this site Glenn, I'll let you know if anything pops up again ;D
1979 CB650Z
Offline mick7504
« Reply #9 on: September 09, 2013, 04:34:51 AM »
Thanks Glenn
It all seems good now mate.
Receiving loud and clear from Darwin in Oz.  ;D
If I was you
Offline petercb750
« Reply #10 on: September 09, 2013, 01:34:00 PM »
Seems ok here now, thanks Glenn.
Offline Frostyboy
  • Retired: Never was an
  • Circa 1951
« Reply #11 on: September 09, 2013, 04:31:20 PM »
I got that nginx rubbish the other day as well Andrew.
I'd like to thank Glenn as well, I just threw a donation in the tin for the work you do mate. Cheers.
Last year I joined a support group for procrastinators.
We haven't met yet.
[CB550F1]
Offline Johnie
« Reply #12 on: September 09, 2013, 05:00:41 PM »
Been getting the server error the past couple weeks. When I would get into the site it would not open...just kept searching. Has been OK the last few days now. Thanks Glenn.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline MikeKato
  • Milwaukee WI
    • TCB true life stories
« Reply #13 on: September 27, 2014, 04:41:51 AM »
"Then tonight I got this one.
Welcome to nginx!
Thank you for using nginx."
I'm getting this one also on the SOHC site.  I thought it was on my end so I did a complete AVG scan,reset browser preferences to factory,then finally a  system-restore to earlier date, all with no luck.
anyone have a solution without me having to use the DOS command prompt?
Thanks!
Mike
  • Administrator
« Reply #14 on: September 27, 2014, 05:20:10 AM »
Thanks for the report.  Generally, it looks like this happens when the server load gets high - likely when the backups kick off - they last for around 5 minutes each AM (around 5am EST).  I'll be doing some tweaking over the next couple of weeks to straighten this out.
« Reply #15 on: September 27, 2014, 05:47:38 PM »
Gday Glen, having problems with blank white screen after trying to send a PM , don't know if they are going through or not and threads missing from my "Show new replies to your posts."..?
