Author Topic: Mystery Wires/Blinker Issues  (Read 6235 times)
Re: Mystery Wires
« Reply #25 on: September 22, 2013, 10:20:26 PM »
I don't have any throttle cables at the moment. My new ones should be here this week. Which grey wire are you referring to?
There is only one isn't there?  It is one of the wires connected to the flasher unit, the other being black.
« Last Edit: September 23, 2013, 08:59:50 AM by TwoTired »
Offline Dr. Noisewater
Re: Mystery Wires/Blinker Issues
« Reply #26 on: September 23, 2013, 08:10:25 AM »
Yeah I'm looking at the wiring diagram now, it looks like it's near the fuse box. I'll have to check it when I get home. Should it be at 12V if the battery's fully charged?
« Reply #27 on: September 23, 2013, 09:09:10 AM »
The grey wire runs from the winker relay to the bar control switch, I believe through the junction box under the left side of the tank on the frame (F model).  Ideally, it will be at the same potential (voltage) as the battery when the signals are illuminated and zero Volts when they aren't.
Many winker relays won't get hot enough internally to separate their internal contacts when the voltage is too low, and thus remain on.  I use this feature as an interpretive voltmeter, on my bikes.
« Reply #28 on: September 23, 2013, 09:16:44 AM »
Hmm interesting. I'll have to check it out. I really just need to get those throttle cables on so I can start it. If my electric start worked I'd try working the throttle manually on the carbs while cranking, but trying to kick it while doing that doesn't paint a good picture..
« Reply #29 on: September 24, 2013, 07:54:46 AM »
Well, I got the throttle cables on last night and was able to start it this morning. The turn signals still come on and stay solid with the engine running/revved. I didn't have time to check that grey wire cause I was already late for work. Any ideas?
« Reply #30 on: September 24, 2013, 09:48:07 AM »
Any ideas?
Yes, effective use of a multimeter.
Offline tin11987
    • sohc4
« Reply #31 on: September 05, 2017, 03:54:29 PM »
Connect all the wires according to the color at the wiring harness, then remove the orange/white and light blue/white wire, you will have a good blinker
Sent from my SM-G935T using Tapatalk
Offline tin11987
    • sohc4
« Reply #32 on: September 05, 2017, 03:56:20 PM »
The orange/white and light blue/white is for the double filament. Idk what is for, but when i remove them the always on blinker is fixed.
Blinker is controlled by orange and light blue wire.
